October 30, 2015, 10:21 |
Consistency between RAM and CPU
Hossein
Rep Power: 10 |
Hi foamers,
I am currently working on simulation of a surface-piercing propeller. I use snappyHexMesh for generating the cells on propeller surface. my problem is the slow simulation speed. I am parallel-runing a case with about 1 million cells using a RANS simulation with k-omega SST model in a computer with following specs: CPU: intel core i7, 3.4GHz with 6 cores and 12 threads. RAM: 6 GB DDR3. my simulation is very slow such that it takes about 48 hours to reach to time t=0.02 seconds, while I need that the simulations reach to time t=0.5 seconds, at least. I am using parallel run with 10 processes. my question is that, how can I speed up my simulation? is it a good idea to increase the RAM up to 32 GB? what is the efficient amount of RAM needed for grid size of 1 million for aforementioned cores? Thanks. |
November 2, 2015, 07:32 |
Rep Power: 12 |
a few questions you, I and hopefully someone else can think about: 1) "6 cores and 12 threads" Are we speaking of hyperthreading here? I wouldn't recommend this. 2) The 6 cores are on one socket? 3) How many memory channels do you have? Is the memory equally distributed? 4) As a rule of thumb: One million cells roughly equals 1 GB of memory. So this shouldn't be an issue here. 5) Do you use adjustable time-stepping? 6) Out of curiosity: How did you calculate the t=0.5 s.? 7) Have you tried core-binding? Best regards, Kate ps.: Did you try serial run? What acceleration rate did you achieve with parallel? Last edited by KateEisenhower; November 2, 2015 at 08:25. Reason: addition |
November 4, 2015, 16:30 |
Hossein
Rep Power: 10 |
Hi Kate and thank you for your response,
your questions responses are listed as below: 1) yes. I used hyperthreading. but, now, as you mentioned, I think it isn't a good idea. Anyway, I will not use it. 2) yes. the 6 cores are on one socket. 3) the memory is dual-channels and I don't know if it is equally distributed. how can I find it? 5) yes. I used adjustable time stepping. 6) by my previous experiences. I have simulated some cases in coarser grids and I found that when time reaches to t=0.5 s the value of drag and torque coefficients would converge. 7) no, I didn't try it. I will do it and report the result. I didn't compare the parallel run with serial. I will do it and inform you. Best Regards, Hossein |
November 5, 2015, 05:03 |
Rep Power: 12 |
some remarks: 3) I'm sure you can find it out using the terminal, but I don't know how. For sure you could open your machine and find out which RAM-modules sit in which slots. For example, if you have 3*2 GB of RAM, your simulation might run faster when only using 3 of your 6 cores. Otherwise 2 cores would have to share one memory channel. This could be a bottleneck when using slow DDR3 RAM. 6) I have not much experience with transient simulations. But shouldn't a transient simulation converge for every timestep? Maybe some other user could make this clear? I'd say your next step should be a simulation on 1 core with besides that unchanged input files. Then we can see if it is a parallel-computing issue at all. Best regards, Kate |
November 5, 2015, 14:41 |
Hossein
Rep Power: 10 |
Hi again,
thank you for your response, as I know, a transient simulation convergence in each time step is depended on the number of iterations in pimple algorithm. I mean the nCorrector and nOuterCorrector parameters. although this parameters should have optimized values. for more clarification, I refer to following link: https://openfoamwiki.net/index.php/O...hm_in_OpenFOAM Bests, Hossein |
November 6, 2015, 02:40 |
Rep Power: 12 |
Hi Hossein,
this is still a little mystery to me. For clarification I asked Tobi who wrote this very usefule guide: http://www.cfd-online.com/Forums/blo...m-part-ii.html See the last comment! Best regards, Kate |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
New workstation for different usage scenarios - CPU and RAM | natem | Hardware | 6 | August 7, 2013 02:47 |
Messhing in Parallel: CPU <5% Ram > 90% Allrun Sleeping | stark22 | OpenFOAM Running, Solving & CFD | 0 | December 2, 2012 10:28 |
Increasing RAM decreases CPU time!!! | Melih GULEREN | FLUENT | 2 | April 5, 2004 06:21 |
more RAM or faster CPU?? | Fabrizio Grieco | Siemens | 11 | January 23, 2001 07:35 |
