reactingParcelFoam - thermodynamic/liquid modelling of injection of h2o2/h2o solution |
October 30, 2015, 07:51 |
Ferdinand Pfender
Rep Power: 12 |
hi everyone!
i hope my problem is not to stupid, but im new to simulations of multiphase-multimixtures. im doing calculations with evaporating droplets in an airflow. at the moment im using only h2o for injection, but i want to switch to a solution of h2o2/h2o (35/100). i think i got everything i need: chemkin tables, also converted to foamchemistry-format (janaf/sutherland). if i use janaf, sutherland and chemkin OR foamchemistryreader, OF complains about mising liquidProperties for H2O2. if use polynomial and chemkin, OF complains about unkonwn chemistryreader chemkinReader. if i use polynomial and foamchemistryreader, OF complains about unkown chemistryreader foamChemistryReader. What am i doing wrong? i dont really get it... Do i really need to implement liquidproperties for H2O2 like in $FOAM_SRC/thermophysicalModels/properties/liquidProperties/ ? i attached all files. Would be nice if someone could give me a hint. Thanks a lot in purpose! Ferdinand |
October 30, 2015, 07:55 |
Ferdinand Pfender
Rep Power: 12 |
here is the whole case;
you wont be able to run it, because i do some things in further calculations. (gmsh-mesh, mapping of fully developped flow, field mapping...) Thanks for takin a look into it |
October 30, 2015, 11:10 |
Ferdinand Pfender
Rep Power: 12 |
i copied the liquidProperties of h2o and changed everything from h2o to h2o2 (via sed, just for trying).
now its working, so it seems i have to implement my own liquidproperties library for h2o2. If someone knows how to determine the different values or where to get em, it will be great if you share them with me. ill take a look to NSRDS and maybe try to calculate them via CoolProp. Greetings, Ferdi |
November 3, 2015, 07:29 |
Ferdinand Pfender
Rep Power: 12 |
now i got it. Overseen to take a look into liquidProperties.H... Only viewed H2O.H/H2O.C and got confused. Can be closed here! |
CFL Condition | Matt Umbel | Main CFD Forum | 19 | June 30, 2020 08:20 |
Error modelling for a nonconverged solution | martapajon | OpenFOAM Running, Solving & CFD | 2 | August 16, 2007 13:13 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
