Best way for different flow directions |
November 5, 2015, 01:45 |
Anderd
Rep Power: 10 |
Hello
I'm simulating a case with flow over a couple of buildings and want to change the wind direction between 0 and 360 degrees. What would be the best way to do this? Is it to rotate the STL file and make a new mesh for each wind direction, or should I change the inflow and outflow BC locations, and if so how to deal with all angles except 0 90 180 and 270 where the flow will be angled towards the boundaries. For a westerly flow I now have an inflow and outflow boundary and symmetry conditions on the south and north wall. Thanks in advance, Anders Last edited by strofse; November 5, 2015 at 01:46. Reason: Misspelled title |
November 5, 2015, 02:19 |
#2 | |
Anton Kidess
Rep Power: 29 |
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
November 5, 2015, 02:32 |
Anderd
Rep Power: 10 |
Dear akidess,
Thanks for your reply. But how would I change the BC conditions in an angled flow as essentially there will be two inflow boundaries and two outflow boundaries (see my poorly drawn figure). It appears to me that angled flows can't have symmetry conditions on the walls? Would this not affect the solution? (see attached fig) bc.png Last edited by strofse; November 5, 2015 at 02:36. Reason: changed to figure instead |
November 5, 2015, 02:58 |
Anderd
Rep Power: 10 |
Well, that is a valid question I guess. My thought was that at a flow nearly orthogonal to the inflow it would be a strange setting, but maybe I am wrong? for a strictly northerly flow for example, it would be purely orthogonal to the inflow and outflow? Would it then not make more sense to move the inflow and outflow BC to the southern and northern wall?
November 5, 2015, 03:15 |
Anton Kidess
Rep Power: 29 |
Orthogonal = Normal = 90 degree to the wall. Do you mean parallel to the boundary? If you like you can move the boundaries in that case, but there is nothing particularly strange about it. People use that for lid driven cavities all the time.
November 5, 2015, 03:25 |
Anderd
Rep Power: 10 |
Yeah, sorry, parallell to the boundary, in a case as my picture below. Would this not be a very strange placement of the inflow and outflow boundary and would in not give a different solution compared to if I moved the BCs? After this point I would also need to switch position of the inflow and outflow of course.
bc2.png Last edited by strofse; November 5, 2015 at 03:26. Reason: wrong figure |
November 5, 2015, 04:49 |
#8 | |
Anton Kidess
Rep Power: 29 |
November 5, 2015, 05:03 |
#9 |
Anderd
Rep Power: 10 |
Well, I guess it is my view of an inflow is that something is actually flowing in a direction normal to the boundary. In this case there would be no flow through the outflow boundary, but maybe I have the wrong impression of the symmetry boundary condition.
But say if I switch the sym-bc to solid walls, my impression is that if I would want to simulate an angled flow, it will give a very different solution in my pictured case if I had the inflow outflow bc at the in the west-east direction compared to south-north. Please correct me if I'm wrong. |
November 5, 2015, 07:22 |
#10 | |
Anton Kidess
Rep Power: 29 |
Indeed I wouldn't call it inflow any more, but if you specify a fixed value for U it wouldn't be a major difference compared to other angles.
Something else I just realized is that you probably do not want to use a symmetry boundary condition, but a periodic one? Quote:
November 5, 2015, 08:16 |
#11 |
Anderd
Rep Power: 10 |
OK, I've made another wonderful drawing with my question to try to illustrate what I perceive as the problem. Please see below.
scene.png Also, what I mean by the the north-south inflow outflow vs west-east I tried to illustrate in the picture below. scene2.png Thanks for your efforts to help me with this, it might just be the case that I don't fully understand how to set up the simulation. |
November 5, 2015, 13:31 |
#12 |
Anton Kidess
Rep Power: 29 |
About the first image - you still didn't explain why you apply symmetry instead of periodic.
About the second image - the two setups are not equivalent. The first case would lead to two counter-rotating vortices, the second one to something like a pipe flow (thinking in 2D).
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 05:36 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Different flow patterns in CFX and Fluent | avi@lpsc | FLUENT | 4 | April 8, 2012 06:12 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 08:42 |
