GAMG solver in OpenFOAM 14
Like Tree3Likes
  • 2 Post By eugene
  • 1 Post By akidess
Old   May 29, 2007, 13:51
Default In OF 1.3, we used the followi
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
In OF 1.3, we used the following syntax in the fvSolution file:
p AMG 1e-06 0 25;
If I were to translate the same into OF 1.4, I would expect the following syntax:
p GAMG
tolerance 1e-06;
relTol 0;
nCellsInCoarsestLevel 25;
My question is whether we need to specify nPreSweeps, nPostSweeps and nFinestSweeps? Also, can someone explain the use of mergeLevels?
Also what smoothers are available?
Many thanks!
msrinath80 is offline   Reply With Quote
Old   May 31, 2007, 11:55
Default mergeLevels is the number of m
Eugene de Villiers
eugene is on a distinguished road
mergeLevels is the number of merge operations to do between grid levels. mergeLevel 1 is equivalent to what is hard coded in AMG and is what I normally use.
agglomerator faceAreaPair; seems to work best
smoother options are: GaussSeidel, DIC and DICGausSeidel. GausSeidel seems to work best, but DICGaussSeidel might be better for more difficult problems. It is more expensive though.
nPreSweeps, nPostSweeps, nFinestSweeps: I use 0,2,2 and this should work for most problems. Feel free to experiment though.
Yage and Narcasi like this.
eugene is offline   Reply With Quote
Old   May 31, 2007, 15:28
Default Many thanks for that clear exp
Many thanks for that clear explanation Eugene!
Old   November 9, 2015, 11:16
KateEisenhower is on a distinguished road
Hello Eugene,
can you or someone else please explain what merging means in this context?
Kind regards,
Kate
KateEisenhower is offline   Reply With Quote
Old   November 10, 2015, 01:59
akidess's Avatar
Anton Kidess
AFAIK merging is the coarsening of the grids. On a structured 2D grid, a standard geometric merge would make one cell out of four. If you'd specify mergeLevel 2, the solver would skip that level and make one cell out of 16. While that saves some work, typically mergeLevel 1 should give you optimal convergence.
KateEisenhower likes this.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
GAMG Solver tutlhino OpenFOAM Running, Solving & CFD 5 January 26, 2013 16:01
DSMC solver in OpenFoam flatorre OpenFOAM 7 July 28, 2010 20:04
Some Questions about GAMG bastil OpenFOAM Running, Solving & CFD 2 March 2, 2009 03:21
Useing GAMG sivakumar OpenFOAM Running, Solving & CFD 1 October 20, 2008 06:40
AMG solver in Openfoam gonski Main CFD Forum 0 November 25, 2007 05:20
