Home > Forums > OpenFOAM Running, Solving & CFD
Multiphase flow
Old   November 10, 2015, 16:19
Default Multiphase flow
Tiko
mchehab2 is on a distinguished road
Hi All,
i need help in understanding the boundary conditions for Multiphase flow.
Thank you,
[ Moderator note: moved this post to this thread, as cutter mentioned in post #4 about it being related. ]
mchehab2 is offline   Reply With Quote
Old   November 10, 2015, 17:26
Tiko
I am trying to perform twophaseEulerFoam simulation on a simple geometry. i need help in setting up the boundary condition in the 'o' folder for pressure and velocity at the inlet, walls, outlet.
Appreciate it!
Old   November 11, 2015, 07:37
cutter is on a distinguished road
please be more specific. It's impossible to provide sane boundary conditions without knowing the problem you're trying to solve (which phase, velocities, geometry, mesh). Please have a look at How to give enough info to get help.
Did you study the tutorial cases? You jump to the twoPhaseEulerFoam tutorial cases using the following command within the shell (assuming a working OF installation):
foamTuts && cd multiphase/twoPhaseEulerFoam/
Cutter
cutter is offline   Reply With Quote
Old   November 11, 2015, 07:39
BTW: please avoid duplicate posts (http://www.cfd-online.com/Forums/ope...-openfoam.html)
Old   November 11, 2015, 10:58
Tiko
Sorry for any inconvenience. I have attached a picture of my example. i have two inlets, one outlet and walls. I am trying to understand what kinda code should i have for boundary conditions to run the simulation ( e.g to have flow coming from two inlets and leaving from one outlet.). if you can provide with a brief explanation about the boundary conditions functions that would be awesome.
Thank you,
Moe,
Old   November 11, 2015, 11:05
Tiko
for Meshing, the group of faces which i have are: { Inlet1, Inlet2, Outlet, Wall}
Thread Tools
Trackbacks are On
Multiphase Flow with NIST Real Gas Model Annka FLUENT 6 July 8, 2016 06:27
Capillary pressure in multiphase flow in porous media Lalit FLUENT 0 March 21, 2013 02:24
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 5 March 2, 2013 15:02
Review: Reversed flow CRT FLUENT 0 July 20, 2012 13:03
multiphase flow ,mass and volume fraction imbalance sope111 CFX 11 July 15, 2012 08:20
