Oscillating Cylinder with mesh topology change
Old   November 16, 2015, 18:49
Default Oscillating Cylinder with mesh topology change
Enrico
terry88 is on a distinguished road
Dear community,
I am studying the problem of a cylinder oscillating, in vertical direction, in a steady flow. The cylinder has a diameter of 0.1 m, oscillates with a KC of 8 with a period of 300 s, in water. The model is attached here. I cannot attach the mesh because it exceed the maximum file size. If someone is interested, ask me that by mail.
To obtain the cylinder movement I am using the library from the OpenFOAM tutorial "movingCone", including the mesh topology change.
I am looking for the calculation of the forces, particularly the vertical ones.
I have some questions to discuss:
- for this case, what is the best combination for solution schemes;
- how the software calculates the viscous force (considering that the turbolence model has not been implemented);
- if the topology change method is adeguate for this analysis;
- the best boundary condition and the domain dimension.
Waiting for your suggestion.
Regards,
Enrico
terry88 is offline   Reply With Quote
[ICEM] Meshing inclined cylinder with PBC tetra mesh ICEM shashi_soman ANSYS Meshing & Geometry 0 September 26, 2015 18:27
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[blockMesh] mesh generation inside/around 3D cylinder Cloudy1988 OpenFOAM Meshing & Mesh Conversion 10 August 23, 2012 14:13
rotating cylinder using sliding mesh Tim Daly FLUENT 1 November 9, 2008 23:02
