CDS vs UDS fvScheme
Old   November 20, 2015, 09:25
Default CDS vs UDS fvScheme
TehHO is on a distinguished road
Hi there. I'm trying to simply solve the steady-state convection-diffusion problem for a global peclet number of 10, and investigate the effects of various finite volume schemes, by doing a convergence analysis of the schemes and compute the rate of convergence for each scheme.
I know that a CDS scheme should have a rate of convergence of 2, in a loglog plot, and a UDS should be of order 1 (because of points in stencil).
I've set up the model in OpenFOAM, but when I investigate my results there seems to be somthing wrong. The error, that is max[abs(t_numerical-T_analytical)], of the two schemes seem to lie (almost right on top of each other, see: http://i.imgur.com/eNyYUDj.jpg).
The scalarTransportFoam tutorial is modified for the exampled of interest.
I've included my two fvSchemes files for the model below, if someone could please tell me why the results are almost identical, that would be very sweet! Thank you!
fvScheme-file for UDS case
| \\ / O peration | Version: 2.1.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
grad(phi,T) Gauss upwind;
// change : div(phi,T) Gauss upwind ; to
// div (phi,T) Gauss linearUpwind ;
divSchemes
default none;
div(phi,T) Gauss upwind;
laplacianSchemes
default none;
laplacian(DT,T) Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
T ;
fvScheme-file for CDS case
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
gradSchemes
divSchemes
default none;
div(phi,T) Gauss linear ;
laplacianSchemes
default none;
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
T ;
TehHO is offline   Reply With Quote
When to use User-defined Scalar (UDS) for concentration? THC FLUENT 1 May 30, 2019 09:04
Can you explain me how to use UDS? Tleja Fluent UDF and Scheme Programming 0 July 14, 2015 01:52
Set UDS on wall... fivos Fluent UDF and Scheme Programming 2 July 25, 2014 05:57
Calculate UDS flux through the wall ananth_01 FLUENT 0 August 5, 2013 07:33
Doubts UDS Flux, UDS Unsteady for VOF model kel85uk FLUENT 0 March 17, 2010 08:53
