"No such file or directory exists" error
Hey guys!
Just installed OpenFOAM-3.0.0 in Ubuntu 14.04 in my PC. Then, I tried running the Lid Driven Cavity Flow tutorial. But this error keeps getting in the way and prevents the following line from getting executed on Terminal: Code:
cd $FOAM_RUN/tutorials/incompressible/icoFoam/cavity bash: cd: /tutorials/incompressible/icoFoam/cavity: No such file or directory I checked the files in the directory and made sure they are in proper order. I've included the screenshot of the directory. (http://imgur.com/Od6O5CE)http://imgur.com/Od6O5CE http://imgur.com/Od6O5CE Can someone help me with setting this right?:confused: Thanks |
Quick answer: It seems like the OpenFOAM shell environment is not active. My guess is that you followed these instructions: https://openfoamwiki.net/index.php/I...u#Ubuntu_14.04
If you did, then whenever you start a new terminal you should run: Code:
of300 Code:
source $HOME/OpenFOAM/OpenFOAM-3.0.0/etc/bashrc |
