Interesting Flow Problem - after a while the solution gets totally destroyed |
July 1, 2021, 09:52 |
Tobias Holzmann
Rep Power: 51 |
Hey foam community,
I might ask you an interesting question. I attached a case (nothing special) a room with a window. The window does not play a big role right now. The top wall (ceiling) is heated to 300 K. The bottom is set to 295 K. Hence, I expect a uniform temperature layering from bottom to top and almost no flow. The only interesting point is that the room is a closed volume (no inlets/outlets). The facts are:
Case is given for v8. https://Holzmann-cfd.com/forum/room.tar.gz Any ideas?
Keep foaming, Tobias Holzmann |
July 1, 2021, 10:43 |
Rep Power: 6 |
Have you tried to use a different equation of state?
I haven't looked deeply into your case, but at first glance I'd say incompressible perfect gas might cause some problems in a closed system, because it calculates density independent from pressure. |
July 1, 2021, 11:27 |
Yann
Rep Power: 26 |
Hi Tobias,
I think your 0 Pa pressure is related to the pRefValue in fvSolution: Code:
SIMPLE { nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; [...] } Not sure how it affects the solution though. Yann |
July 1, 2021, 12:02 |
Tobias Holzmann
Rep Power: 51 |
Hey both.
So ... thank you!
July 1, 2021, 12:16 |
Tobias Holzmann
Rep Power: 51 |
Okay now we are ready to go to discuss. By using the case provided and changing the EOS to perfectGas, everything works (even though the velocity field looks weirdo - probably based on the steady-State analysis).
However, if we deactivate the turbulence model and calculate in a laminar manner, the temperature goes to 350 K. I have no idea why. That`s actually something I am not sure about.
Will the results of steady state solver and transient solver be same? | carye | OpenFOAM Running, Solving & CFD | 9 | December 28, 2019 05:21 |
Mass flow rate history over solution step- rhoSimpleFoam | gian93 | OpenFOAM Post-Processing | 0 | December 8, 2019 10:20 |
Two Mass flow inlet bc convergence problem | nabidinhomessi | Main CFD Forum | 5 | December 14, 2015 07:11 |
Newbie to compressible, viscous flow. Advice on approach to problem? | bzz77 | Main CFD Forum | 4 | December 4, 2012 07:59 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
