December 20, 2015, 12:05 |
Solving interFoam 3D flow around cylinder
Niels D
Rep Power: 10 |
I'm trying to solve a self-made case for the uniform flow around a cylinder. My boundary conditions are the following: left: one face of 3m with inlet with second face of 1m atmosphere right: same as left but then outlet bottom: no-slip wall sides: slip wall cylinder: no-slip wall top: atmosphere But when solving a strange thing happens at the outlet. I use an inlet velocity of 1m/s but the water height seems to be decreasing in the end (see figure). What can be the cause of this? |
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 14:26 |
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 05:07 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
