icoFoam: ill defined primitiveEntry starting at Keyword 'value'
Hi friends!
I am modeling a very simple example of laminar flow using OpenFoam. there is no problem in blockMesh. but when I type "icoFoam" to solve the problem, solver stops when is reading the "U field" the error is : ill defined primitiveEntry starting at Keyword 'value' on line .... I've seen this message before, cause of bad definition in using small and capital letter in typing the words. but here there is no such problem I guess! all the best! |
Quick answer: icoFoam is telling you something is wrong with the line that has a broken "value" description/definition. If you do not show us what that line has got, we cannot diagnose the problem either. Therefore, we also cannot see what you are not seeing.
the contents of U file that icoFoam exiting when is reading that, are:
... boundryField { fixedwalls { type fixedValue; value uniform(0 0 0); } inlet { type fixedValue; value uniform(1 0 0); } . . . that was the part contain of "value" word all the best |
thank u very much!
that was correct, my fault was that missing space between uniform and (0 0 0) all the best |
