-   OpenFOAM Community Contributions (https://www.cfd-online.com/Forums/openfoam-community-contributions/)
-   -   [ImmersedBoundary] Parallel computation(mpiexec) of immersed boundary (https://www.cfd-online.com/Forums/openfoam-community-contributions/164523-parallel-computation-mpiexec-immersed-boundary.html)
Gerwang December 24, 2015 04:26
Hello everyone,
I'm trying to use parallel computation(mpiexec) and immersed boundary method to simulate wind turbines.
I did succeed when I submit a case that use 16 cores,which is very stable:
mpiexec -n 16 windPlantSolverFAST
But I failed when I submit it using 32 cores:
mpiexec -n 32 windPlantSolverFAST
The result of slurm standard output (#SBATCH -o log.xxx)told me that there was something wrong with the address, whose output was:
[TUMWHST-WE102:23004] *** Process received signal ***
[TUMWHST-WE102:23004] Signal: Segmentation fault (11)
[TUMWHST-WE102:23004] Signal code:  (-6)
[TUMWHST-WE102:23004] Failing at address: 0x76f93000059dc
[TUMWHST-WE102:23013] *** Process received signal ***
[TUMWHST-WE102:23010] *** Process received signal ***
[TUMWHST-WE102:23010] Signal: Segmentation fault (11)
[TUMWHST-WE102:23010] Signal code:  (-6)
[TUMWHST-WE102:23010] Failing at address: 0x76f93000059e2
[TUMWHST-WE102:23013] Signal: Segmentation fault (11)
[TUMWHST-WE102:23013] Signal code:  (-6)
[TUMWHST-WE102:23013] Failing at address: 0x76f93000059e5
[TUMWHST-WE102:23013] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x10340) [0x7f4b41da0340]
[TUMWHST-WE102:23010] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x10340) [0x7f3f839b0340]
[TUMWHST-WE102:23010] [ 1] /lib/x86_64-linux-gnu/libpthread.so.0(raise+0x2b) [0x7f3f839b020b]
[TUMWHST-WE102:23010] [ 2] /lib/x86_64-linux-gnu/libpthread.so.0(+0x10340) [0x7f3f839b0340]
[TUMWHST-WE102:23010] [ 3] /home/HT/ga96zob/openmpi-1.6.5/build/lib/libmpi.so.1(+0xf8c63) [0x7f3f84908c63]
[TUMWHST-WE102:23010] [ 4] /home/HT/ga96zob/openmpi-1.6.5/build/lib/libmpi.so.1(opal_memory_ptmalloc2_int_malloc+0x103) [0x7f3f8490b183]
[TUMWHST-WE102:23010] [ 5] /home/HT/ga96zob/openmpi-1.6.5/build/lib/libmpi.so.1(opal_memory_ptmalloc2_int_memalign+0x55) [0x7f3f8490db55]
[TUMWHST-WE102:23010] [ 6] /home/HT/ga96zob/openmpi-1.6.5/build/lib/libmpi.so.1(opal_memory_ptmalloc2_memalign+0xbc) [0x7f3f8490df9c]
[TUMWHST-WE102:23010] [ 7] /usr/lib/x86_64-linux-gnu/libstdc++.so.6(_Znwm+0x1d) [0x7f3f83e36f2d]
[TUMWHST-WE102:23010] [ 8] /usr/lib/x86_64-linux-gnu/libstdc++.so.6(_Znam+0x9) [0x7f3f83e37029]
[TUMWHST-WE102:23010] [ 9] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam4ListINS_4PairIiEEE7setSizeEi+0x2a) [0x7f3f8977922a]
[TUMWHST-WE102:23010] [10] /home/HT/ga47lap/foam/ga47lap-3.1/lib/linux64GccDPOpt/libimmersedBoundary.so(_ZNK4Foam23immersedBoundaryFvPatch15makeIbCellCellsEv+0x1af8) [0x7f3f8755f548]
[TUMWHST-WE102:23010] [11] /home/HT/ga47lap/foam/ga47lap-3.1/lib/linux64GccDPOpt/libimmersedBoundary.so(_ZNK4Foam23immersedBoundaryFvPatch11ibCellCellsEv+0x1d) [0x7f3f8755f88d]
[TUMWHST-WE102:23010] [12] windPlantSolverFAST(_ZNK4Foam28immersedBoundaryFvPatchFieldINS_6TensorIdEEE22imposeNeumannConditionEv+0x3e) [0x4d7f5e]
[TUMWHST-WE102:23010] [13] windPlantSolverFAST(_ZN4Foam28immersedBoundaryFvPatchFieldINS_6TensorIdEEE12updateCoeffsEv+0x45) [0x4d92f5]
[TUMWHST-WE102:23010] [14] windPlantSolverFAST(_ZN4Foam28immersedBoundaryFvPatchFieldINS_6TensorIdEEE8evaluateENS_7Pstream10commsTypesE+0xa) [0x484c6a]
[TUMWHST-WE102:23010] [15] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam14GeometricFieldINS_6TensorIdEENS_12fvPatchFieldENS_7volMeshEE22GeometricBoundaryField8evaluateEv+0x132) [0x7f3f894c4cb2]
[TUMWHST-WE102:23010] [16] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam2fv9gaussGradINS_6VectorIdEEE4gradERKNS_14GeometricFieldIS3_NS_13fvsPatchFieldENS_11surfaceMeshEEE+0x800) [0x7f3f8976f290]
[TUMWHST-WE102:23010] [17] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libfiniteVolume.so(_ZNK4Foam2fv9gaussGradINS_6VectorIdEEE4gradERKNS_14GeometricFieldIS3_NS_12fvPatchFieldENS_7volMeshEEE+0x4e) [0x7f3f8976f43e]
[TUMWHST-WE102:23010] [18] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam3fvc4gradINS_6VectorIdEEEENS_3tmpINS_14GeometricFieldINS_12outerProductIS3_T_E4typeENS_12fvPatchFieldENS_7volMeshEEEEERKNS5_IS7_SA_SB_EE+0xb0) [0x7f3f894d48c0]
[TUMWHST-WE102:23010] [19] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libincompressibleLESModels.so(_ZN4Foam14incompressible9LESModels11SmagorinskyC1ERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS3_IdNS_13fvsPatchFieldENS_11surfaceMeshEEERNS_14transportModelE+0x16b) [0x7f3f86bbc2fb]
[TUMWHST-WE102:23010] [20] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libincompressibleLESModels.so(_ZN4Foam14incompressible8LESModel31adddictionaryConstructorToTableINS0_9LESModels11SmagorinskyEE3NewERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS6_IdNS_13fvsPatchFieldENS_11surfaceMeshEEERNS_14transportModelE+0x32) [0x7f3f86bbcc52]
[TUMWHST-WE102:23010] [21] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libincompressibleLESModels.so(_ZN4Foam14incompressible8LESModel3NewERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS2_IdNS_13fvsPatchFieldENS_11surfaceMeshEEERNS_14transportModelE+0x317) [0x7f3f86b4e317]
[TUMWHST-WE102:23010] [22] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libincompressibleLESModels.so(_ZN4Foam14incompressible15turbulenceModel36addturbulenceModelConstructorToTableINS0_8LESModelEE18NewturbulenceModelERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS5_IdNS_13fvsPatchFieldENS_11surfaceMeshEEERNS_14transportModelE+0x10) [0x7f3f86b503d0]
[TUMWHST-WE102:23010] [23] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libincompressibleTurbulenceModel.so(_ZN4Foam14incompressible15turbulenceModel3NewERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS2_IdNS_13fvsPatchFieldENS_11surfaceMeshEEERNS_14transportModelE+0x617) [0x7f3f872b4927]
[TUMWHST-WE102:23010] [24] windPlantSolverFAST(main+0x180f) [0x47617f]
[TUMWHST-WE102:23010] [25] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7f3f835f9ec5]
[TUMWHST-WE102:23010] [26] windPlantSolverFAST() [0x4814b6]
[TUMWHST-WE102:23010] *** End of error message ***
[TUMWHST-WE102:23013] [ 1] /lib/x86_64-linux-gnu/libpthread.so.0(raise+0x2b) [0x7f4b41da020b]
[TUMWHST-WE102:23013] [ 2] /lib/x86_64-linux-gnu/libpthread.so.0(+0x10340) [0x7f4b41da0340]
[TUMWHST-WE102:23013] [ 3] /home/HT/ga96zob/openmpi-1.6.5/build/lib/libmpi.so.1(+0xf8caf) [0x7f4b42cf8caf]
[TUMWHST-WE102:23013] [ 4] /home/HT/ga96zob/openmpi-1.6.5/build/lib/libmpi.so.1(opal_memory_ptmalloc2_int_malloc+0x103) [0x7f4b42cfb183]
[TUMWHST-WE102:23013] [ 5] /home/HT/ga96zob/openmpi-1.6.5/build/lib/libmpi.so.1(opal_memory_ptmalloc2_int_memalign+0x55) [0x7f4b42cfdb55]
[TUMWHST-WE102:23004] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x10340) [0x7fb8ccf10340]
[TUMWHST-WE102:23004] [ 1] /lib/x86_64-linux-gnu/libpthread.so.0(raise+0x2b) [0x7fb8ccf1020b]
[TUMWHST-WE102:23004] [ 2] /lib/x86_64-linux-gnu/libpthread.so.0(+0x10340) [0x7fb8ccf10340]
[TUMWHST-WE102:23004] [ 3] /home/HT/ga96zob/openmpi-1.6.5/build/lib/libmpi.so.1(+0xf8caf) [0x7fb8cde68caf]
[TUMWHST-WE102:23004] [ 4] /home/HT/ga96zob/openmpi-1.6.5/build/lib/libmpi.so.1(opal_memory_ptmalloc2_int_malloc+0x103) [0x7fb8cde6b183]
[TUMWHST-WE102:23004] [ 5] /home/HT/ga96zob/openmpi-1.6.5/build/lib/libmpi.so.1(opal_memory_ptmalloc2_int_memalign+0x55) [0x7fb8cde6db55]
[TUMWHST-WE102:23004] [ 6] /home/HT/ga96zob/openmpi-1.6.5/build/lib/libmpi.so.1(opal_memory_ptmalloc2_memalign+0xbc) [0x7fb8cde6df9c]
[TUMWHST-WE102:23004] [ 7] /usr/lib/x86_64-linux-gnu/libstdc++.so.6(_Znwm+0x1d) [0x7fb8cd396f2d]
[TUMWHST-WE102:23004] [ 8] /usr/lib/x86_64-linux-gnu/libstdc++.so.6(_Znam+0x9) [0x7fb8cd397029]
[TUMWHST-WE102:23004] [ 9] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam4ListINS_4PairIiEEE7setSizeEi+0x2a) [0x7fb8d2cd922a]
[TUMWHST-WE102:23004] [10] /home/HT/ga47lap/foam/ga47lap-3.1/lib/linux64GccDPOpt/libimmersedBoundary.so(_ZNK4Foam23immersedBoundaryFvPatch15makeIbCellCellsEv+0x1af8) [0x7fb8d0abf548]
[TUMWHST-WE102:23004] [11] /home/HT/ga47lap/foam/ga47lap-3.1/lib/linux64GccDPOpt/libimmersedBoundary.so(_ZNK4Foam23immersedBoundaryFvPatch11ibCellCellsEv+0x1d) [0x7fb8d0abf88d]
[TUMWHST-WE102:23004] [12] windPlantSolverFAST(_ZNK4Foam28immersedBoundaryFvPatchFieldINS_6TensorIdEEE22imposeNeumannConditionEv+0x3e) [0x4d7f5e]
[TUMWHST-WE102:23004] [13] windPlantSolverFAST(_ZN4Foam28immersedBoundaryFvPatchFieldINS_6TensorIdEEE12updateCoeffsEv+0x45) [0x4d92f5]
[TUMWHST-WE102:23004] [14] windPlantSolverFAST(_ZN4Foam28immersedBoundaryFvPatchFieldINS_6TensorIdEEE8evaluateENS_7Pstream10commsTypesE+0xa) [0x484c6a]
[TUMWHST-WE102:23004] [15] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam14GeometricFieldINS_6TensorIdEENS_12fvPatchFieldENS_7volMeshEE22GeometricBoundaryField8evaluateEv+0x132) [0x7fb8d2a24cb2]
[TUMWHST-WE102:23004] [16] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam2fv9gaussGradINS_6VectorIdEEE4gradERKNS_14GeometricFieldIS3_NS_13fvsPatchFieldENS_11surfaceMeshEEE+0x800) [0x7fb8d2ccf290]
[TUMWHST-WE102:23004] [17] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libfiniteVolume.so(_ZNK4Foam2fv9gaussGradINS_6VectorIdEEE4gradERKNS_14GeometricFieldIS3_NS_12fvPatchFieldENS_7volMeshEEE+0x4e) [0x7fb8d2ccf43e]
[TUMWHST-WE102:23004] [18] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam3fvc4gradINS_6VectorIdEEEENS_3tmpINS_14GeometricFieldINS_12outerProductIS3_T_E4typeENS_12fvPatchFieldENS_7volMeshEEEEERKNS5_IS7_SA_SB_EE+0xb0) [0x7fb8d2a348c0]
[TUMWHST-WE102:23004] [19] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libincompressibleLESModels.so(_ZN4Foam14incompressible9LESModels11SmagorinskyC1ERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS3_IdNS_13fvsPatchFieldENS_11surfaceMeshEEERNS_14transportModelE+0x16b) [0x7fb8d011c2fb]
[TUMWHST-WE102:23004] [20] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libincompressibleLESModels.so(_ZN4Foam14incompressible8LESModel31adddictionaryConstructorToTableINS0_9LESModels11SmagorinskyEE3NewERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS6_IdNS_13fvsPatchFieldENS_11surfaceMeshEEERNS_14transportModelE+0x32) [0x7fb8d011cc52]
[TUMWHST-WE102:23004] [21] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libincompressibleLESModels.so(_ZN4Foam14incompressible8LESModel3NewERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS2_IdNS_13fvsPatchFieldENS_11surfaceMeshEEERNS_14transportModelE+0x317) [0x7fb8d00ae317]
[TUMWHST-WE102:23004] [22] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libincompressibleLESModels.so(_ZN4Foam14incompressible15turbulenceModel36addturbulenceModelConstructorToTableINS0_8LESModelEE18NewturbulenceModelERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS5_IdNS_13fvsPatchFieldENS_11surfaceMeshEEERNS_14transportModelE+0x10) [0x7fb8d00b03d0]
[TUMWHST-WE102:23004] [23] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libincompressibleTurbulenceModel.so(_ZN4Foam14incompressible15turbulenceModel3NewERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS2_IdNS_13fvsPatchFieldENS_11surfaceMeshEEERNS_14transportModelE+0x617) [0x7fb8d0814927]
[TUMWHST-WE102:23004] [24] windPlantSolverFAST(main+0x180f) [0x47617f]
[TUMWHST-WE102:23004] [25] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7fb8ccb59ec5]
[TUMWHST-WE102:23004] [26] windPlantSolverFAST() [0x4814b6]
[TUMWHST-WE102:23004] *** End of error message ***
[TUMWHST-WE102:23013] [ 6] /home/HT/ga96zob/openmpi-1.6.5/build/lib/libmpi.so.1(opal_memory_ptmalloc2_memalign+0xbc) [0x7f4b42cfdf9c]
[TUMWHST-WE102:23013] [ 7] /usr/lib/x86_64-linux-gnu/libstdc++.so.6(_Znwm+0x1d) [0x7f4b42226f2d]
[TUMWHST-WE102:23013] [ 8] /usr/lib/x86_64-linux-gnu/libstdc++.so.6(_Znam+0x9) [0x7f4b42227029]
[TUMWHST-WE102:23013] [ 9] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam4ListINS_4PairIiEEE7setSizeEi+0x2a) [0x7f4b47b6922a]
[TUMWHST-WE102:23013] [10] /home/HT/ga47lap/foam/ga47lap-3.1/lib/linux64GccDPOpt/libimmersedBoundary.so(_ZNK4Foam23immersedBoundaryFvPatch15makeIbCellCellsEv+0x1af8) [0x7f4b4594f548]
[TUMWHST-WE102:23013] [11] /home/HT/ga47lap/foam/ga47lap-3.1/lib/linux64GccDPOpt/libimmersedBoundary.so(_ZNK4Foam23immersedBoundaryFvPatch11ibCellCellsEv+0x1d) [0x7f4b4594f88d]
[TUMWHST-WE102:23013] [12] windPlantSolverFAST(_ZNK4Foam28immersedBoundaryFvPatchFieldINS_6TensorIdEEE22imposeNeumannConditionEv+0x3e) [0x4d7f5e]
[TUMWHST-WE102:23013] [13] windPlantSolverFAST(_ZN4Foam28immersedBoundaryFvPatchFieldINS_6TensorIdEEE12updateCoeffsEv+0x45) [0x4d92f5]
[TUMWHST-WE102:23013] [14] windPlantSolverFAST(_ZN4Foam28immersedBoundaryFvPatchFieldINS_6TensorIdEEE8evaluateENS_7Pstream10commsTypesE+0xa) [0x484c6a]
[TUMWHST-WE102:23013] [15] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam14GeometricFieldINS_6TensorIdEENS_12fvPatchFieldENS_7volMeshEE22GeometricBoundaryField8evaluateEv+0x132) [0x7f4b478b4cb2]
[TUMWHST-WE102:23013] [16] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam2fv9gaussGradINS_6VectorIdEEE4gradERKNS_14GeometricFieldIS3_NS_13fvsPatchFieldENS_11surfaceMeshEEE+0x800) [0x7f4b47b5f290]
[TUMWHST-WE102:23013] [17] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libfiniteVolume.so(_ZNK4Foam2fv9gaussGradINS_6VectorIdEEE4gradERKNS_14GeometricFieldIS3_NS_12fvPatchFieldENS_7volMeshEEE+0x4e) [0x7f4b47b5f43e]
[TUMWHST-WE102:23013] [18] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam3fvc4gradINS_6VectorIdEEEENS_3tmpINS_14GeometricFieldINS_12outerProductIS3_T_E4typeENS_12fvPatchFieldENS_7volMeshEEEEERKNS5_IS7_SA_SB_EE+0xb0) [0x7f4b478c48c0]
[TUMWHST-WE102:23013] [19] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libincompressibleLESModels.so(_ZN4Foam14incompressible9LESModels11SmagorinskyC1ERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS3_IdNS_13fvsPatchFieldENS_11surfaceMeshEEERNS_14transportModelE+0x16b) [0x7f4b44fac2fb]
[TUMWHST-WE102:23013] [20] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libincompressibleLESModels.so(_ZN4Foam14incompressible8LESModel31adddictionaryConstructorToTableINS0_9LESModels11SmagorinskyEE3NewERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS6_IdNS_13fvsPatchFieldENS_11surfaceMeshEEERNS_14transportModelE+0x32) [0x7f4b44facc52]
[TUMWHST-WE102:23013] [21] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libincompressibleLESModels.so(_ZN4Foam14incompressible8LESModel3NewERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS2_IdNS_13fvsPatchFieldENS_11surfaceMeshEEERNS_14transportModelE+0x317) [0x7f4b44f3e317]
[TUMWHST-WE102:23013] [22] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libincompressibleLESModels.so(_ZN4Foam14incompressible15turbulenceModel36addturbulenceModelConstructorToTableINS0_8LESModelEE18NewturbulenceModelERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS5_IdNS_13fvsPatchFieldENS_11surfaceMeshEEERNS_14transportModelE+0x10) [0x7f4b44f403d0]
[TUMWHST-WE102:23013] [23] /home/HT/ga47lap/foam/foam-extend-3.1/lib/linux64GccDPOpt/libincompressibleTurbulenceModel.so(_ZN4Foam14incompressible15turbulenceModel3NewERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS2_IdNS_13fvsPatchFieldENS_11surfaceMeshEEERNS_14transportModelE+0x617) [0x7f4b456a4927]
[TUMWHST-WE102:23013] [24] windPlantSolverFAST(main+0x180f) [0x47617f]
[TUMWHST-WE102:23013] [25] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7f4b419e9ec5]
[TUMWHST-WE102:23013] [26] windPlantSolverFAST() [0x4814b6]
[TUMWHST-WE102:23013] *** End of error message ***
mpiexec noticed that process rank 10 with PID 23013 on node TUMWHST-WE102 exited on signal 11 (Segmentation fault).
I suppose that the reason for the crash is that the immersed boundary was "cut". That means, one immersed boundary was divided into two pieces by mpiexec, the two pieces were calculated by different cores -- then it crashed. But, it is only my guess. Does anyone have some ideas? Thanks very much!
Best regards!
Gerwang
