Home > Forums > OpenFOAM Running, Solving & CFD
Courant number explodes
Old   December 24, 2015, 08:37
Default Courant number explodes
Evangelos
Danath is on a distinguished road
Hello Foamers!
i am trying to simulate the bifurcation that is depicted in the bifurcation.png file. There is one inlet in the right of the geometry and three outlets at the right.
I use icoFoam to solve the flow problem. the deltaT is 1e-4. The courant number at first is very small but is increased with a small step after each iteration. After 10000 iterations the courant number is getting too big so the simulation stops.
The mesh is ok after checkMesh.
I calculate the Dp in order to have the desired mean velocity in the pipe before the bifurcation and then i divide with density.
0/p File
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type fixedValue;
value uniform 0.012957446;
outlet_internal
type fixedValue;
value uniform 0;
outlet_externalbig
type fixedValue;
value uniform 0;
outlet_externalsmall
type fixedValue;
value uniform 0;
walls
type zeroGradient;
0/U File
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type pressureInletVelocity;
value uniform (0 0 0);
outlet_internal
type zeroGradient;
outlet_externalbig
type zeroGradient;
type zeroGradient;
walls
type fixedValue;
transportproperties
transportModel Newtonian;
nu nu [ 0 2 -1 0 0 0 0 ] 0.000002057;
Can anyone help me to solve the problem ? I stuck over 15 days
Danath is offline   Reply With Quote
Old   December 24, 2015, 11:49
Akshay Kumar
Akshay is on a distinguished road
Hey
Why are you running a transient simulation for this case?
Akshay is offline   Reply With Quote
Old   December 24, 2015, 14:33
Evangelos
I know that Poiseuille flow is treated as steady state.
But i have developed a code based on transient solver and i need to evaluate the results of my case with experimental data
Old   December 25, 2015, 05:06
Akshay Kumar
Ahh okay. Did you try running adjustable time stepping? Also, try pimplefoam solver : use higher outerCorrectors and relax the solution
Old   December 25, 2015, 23:36
Alberto Passalacqua
If you know the desired velocity at the inlet, just impose that, rather than the pressure at the inlet (it seems you use that to find the pressure drop?).
Also, as a suggestion, I would not recommend icoFoam. You could use pimpleFoam, and have better control on the solution process (outer correctors, adaptive time-step, under-relaxation, ...).
Alberto Passalacqua
GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats.
Thread Tools
Trackbacks are On
decomposePar no field transfert Jeanp OpenFOAM Pre-Processing 0 June 20, 2014 05:59
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
--> foam fatal error: lillo763 OpenFOAM Native Meshers: blockMesh 0 March 5, 2014 11:27
Newbie Question IcoFoam - Courant Number explodes sprobst76 OpenFOAM Running, Solving & CFD 10 November 19, 2010 12:22
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
