August 31, 2018, 16:33 |
Specify Temperature of Inflowing Mass Source
Jeff Anon
Hi All,
Relatively new to FOAM - I have a scenario using reactingFoam in which I have set up a mass source at an injection location. I have prescribed the mass flow rate and momentum at this location, but do not know how to prescribe the temperature of the inflowing mass. I ran a test ignoring temperature, and as expected, the temperature within my domain plummeted due to the inflowing mass lacking any energy. Is there a simple way to prescribe the temperature of the inflowing source? Or, do I need to prescribe this is another way, e.g., as a separate heat source at the same location? My code in fvOptions.. Code:
massSource1 { type scalarSemiImplicitSource; scalarSemiImplicitSourceCoeffs { $injector1; volumeMode absolute; injectionRateSuSp { rho (0.31397 0); // kg/s Chemical1 (0.31397 0); // kg/s } } } momentumSource1 { type vectorSemiImplicitSource; vectorSemiImplicitSourceCoeffs { $injector1; volumeMode absolute; injectionRateSuSp { U ((0 -44.64 0) 0); // kg*m/s^2 } } } |
September 1, 2018, 11:04 |
Rep Power: 14 |
Have you tried using an energy source at the same location? It would be a simple addition of h with some value to your scalarSemiImplicitSource. For reference, check out this tutorial -- It looks like it's doing the same thing :
https://github.com/OpenFOAM/OpenFOAM...tant/fvOptions Caelan |
mass source term, temperature |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
