Is it possible to use fsiFoam in parallel?
Hello
Is it possible to use fsiFoam in parallel? I tried to do this in base case: beamInCrossFlow but it failed. What modification did I do in case? I modified Allrun file like this: Code:
#!/bin/sh numberOfSubdomains 2 n (2 1 1); Then I run this case in standard way: Code:
sed -i s/tcsh/sh/g *Links Code:
/*---------------------------------------------------------------------------*\ Code:
./Allrun: 55: ./Allrun: makeLinks: not found I'm still a new Linux user so I suppose that I made a mistake somewhere so thank you in advance for you help. |
did you find any solution.
I am also facing similar trouble. |
Unfortunately I didn't find any information how to use fsiFoam in parallel :(
Probably it is necessary to modify the source code or wait for new version |
Hi Wojciech, I am also facing the same problem too...Just wandering do you have any solutions now?
For anyone still having this problem, there is an example of parallel runs in the tutorial examples, fsiFoam/beamInCrossFlow. in foam-extended 4.0
You need to decompose both the solid and fluid domains Code:
runApplication -l log.blockMesh.solid blockMesh -case ../solid and make sure that you use Code:
./makeLinks fluid solid Code:
./makeSerialLinks fluid solid Code:
Cannot find file "points" in directory "constant/solid/polyMesh". |
Please need urgent help
I am trying to solve FSI-foam in Parallel. I have done:
1) decomposePar for fluid and solid. (two subdomains each by scotch Method) 2) ./makeLinks fluid and solid 3) updated ./Allrun to ./AllrunPar using the tutorial fsiFoam/beamInCrossFlow. But the case doesn't run log.fsiFoam : HTML Code:
Hello Guys,
Thanks for posting to this forum. Yes it can be run. 0) After blockMesh and setToZones command, run decomposePar separately from inside fluid/ and solid/ 1) make a separate .sh file in fluid/ Eg: linkParallel.sh 2) Paste this inside it for proc in processor0 processor1 processor2 .... processorN do echo $proc cd $proc cd 0 ln -s ../../../$2/$proc/0 solid cd ../constant ln -s ../../../$2/$proc/constant solid cd ../.. done 3) If your makeSerialLinks.sh is one directory higher. Do >> cd .. >> ./makeSerialLinks.sh fluid solid >> cd fluid/ 4) Then execute the following >> ./linkParallel.sh fluid solid" This should create the links for individual processor domains. 5) Execute parallel run >> mpirun -np <num_sub_domains> fsiFoam -parallel I tested this myself. Hope this works for you too. Please let me know! Cheers :-) |
Can you please share your decomposeParDict file for solid and fluid (urgent requirement). and regarding the file "makeLinks" there is some syntax error in the code. I have corrected it makeLinks previously at line 20 Code:
foreach proc(processor*) Code:
for proc in processor* |
