Home > Forums > OpenFOAM Running, Solving & CFD
Solution diverges at the corner of orthogonal mesh
Like Tree2Likes
  • 1 Post By tomf
  • 1 Post By Akshay
Old   January 3, 2016, 21:07
Default Solution diverges at the corner of orthogonal mesh
Amir Abbas Aliabadi
amir.a.aliabadi is on a distinguished road
Hello Dear FOAMers,
I have been benefiting from this forum a lot, and would like to seek your help in my problem. I am simulating air flow in an urban canyon by establishing a pressure differential (0.5 divided by density) across the canyon and implementing cyclic boundary conditions on inlet/outlet as well as front/back of my domain. See pictures attached. I have a heated bottom (street) to 352.15 K, adiabatic walls, and ambient temperature and roof temperatures equal to 293.15 K.
I have compiled a solver to combine functionalities of buoyant boussinesq approximation, LES turbulence model, Pimple algorithm, and passive scalar transport. The mesh is generated using blockMesh and y+ is close to 1 to ensure the boundaries are resolved.
The code works fine except that in one cell in a corner, and only one corner of my orthogonal mesh, the solution for temperature starts diverging. The solver operates under PISO model, and I have tried under-relaxing pressure. But this problem persists no matter how hard I try.
Would anyone please make a suggestion? I have attached pictures of the mesh and the diverging corner. I have also attached all files from the solver as well as the case files...
I appreciate your help...
Amir
File Type: jpg Diverging Temperature at the Corner.jpg (34.2 KB, 35 views)
File Type: gz passiveScalarBuoyantBoussinesqPimpleLESFoam.tar.gz (2.8 KB, 1 views)
amir.a.aliabadi is offline   Reply With Quote
Old   January 6, 2016, 06:45
Tom Fahner
tomf is on a distinguished road
Send a message via MSN to tomf Send a message via Skype™ to tomf
I suspect it may be related to the pRefCell that you set in fvSolution. Since you use cyclics on inlet and outlet you need to have a reference pressure somewhere. I guess your diverging cell is cell 0. Maybe it helps to use a pRefPoint somewhere in the center of the domain or in a location where the pressure is steady.
PIMPLE
    momentumPredictor no;
    nOuterCorrectors 1;
    nCorrectors     2;
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
amir.a.aliabadi likes this.
tomf is offline   Reply With Quote
Old   January 6, 2016, 11:10
Amir Abbas Aliabadi
Hello Dear Tom,
Thank you for your effective suggestion and I appreciate your time. I changed the pRefCell to a middle point on the topLid of the domain with pRefValue of 0. The solution in the corner at pRefCell = 0 is now well behaved. However, the solution at and around the new pRefCell shows similar effect to the old corner cell. Again I get some cooling in the cell with starts to propagate in the neighbouring cells. I am wondering why this is happening at the pRefCell.
My colleague suggested having maximum temperature range in the entire domain up to 15 K for the use of Boussinesq approximation to be valid. I also ensure that for the PISO algorithm the Courant number is around 0.2. Do you think this may be cause by pRefCell being at the boundary? Shall I move this point to the centre of the domain somewhere?
Regards,
Amir
Old   January 6, 2016, 11:56
Tom Fahner
Dear Amir,
Well at least we know that the error stems from the pRefCell. I suspect that if you change it to the middle of the domain you will have similar behavior. I know this has been discussed before on the forum (google site:cfd-online.com temperature anomaly pressure reference cell).
Best solution would probably to fix the pressure on a boundary, so the reference cell pressure is not set during the computation, but this may interfere with your cyclic pressure jump. I have not done something like this myself so unfortunately all I can do is give some pointers.
Regards,
Tom
Old   January 6, 2016, 15:54
Amir Abbas Aliabadi
Hello Dear Tom,
Thank you for the follow up and referring me to other discussions. I found them very useful.
Regards,
Amir
Old   January 7, 2016, 10:38
Akshay Kumar
Akshay is on a distinguished road
Hello Amir
I think Tom has pointed in the right direction. I would also suggest trying to run this case using a compressible solver. This would take out the Pressure referencing adjustment at the matrix level.
Akshay is offline   Reply With Quote
Old   January 12, 2016, 17:19
Amir Abbas Aliabadi
Hello Dear Colleagues,
Let me thank you all for making such effective comments. So I moved to a compressible solver "buoyantPimpleFoam" provided by OpenFOAM with a tutorial under heatTransfer folder. This solver has the capability to be adapted to LES, which I successfully implemented. In order to get the cyclic inlet/outlet with a pressure jump working, I had to use the cyclic boundary condition "fixedJump" in OpenFOAM 3.0.1. Surprisingly the "fan" boundary condition does not work properly in this version of OpenFOAM, but the "fixedJump" is working suitably. I will post any other updates that I may find useful to other users with the same problem.
Regards,
Amir
Thread Tools
Trackbacks are On
sliding mesh problem in CFX Saima CFX 45 September 22, 2015 10:53
Converging the solution aja1345 FLUENT 10 June 26, 2015 18:00
Star CCM Overset Mesh Error (Rotating Turbine) thezack CD-adapco 3 December 11, 2013 04:09
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
Layers:problem with curvature giulio.topazio OpenFOAM Native Meshers: snappyHexMesh and Others 10 August 22, 2012 09:03
