March 11, 2013, 08:10 |
OF 2.2.x and v2f model
Y.LANCE
Rep Power: 13 |
I test the implementation of the model v2f in openfoam 2.2.0. I launched the hotRoom tutorial of the solveur buoyantSimpleFoam with the model v2f. I have this error message: --> FOAM FATAL ERROR: temporary deallocated From function T& Foam::tmp<T>:perator()() in file /home/etudes/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude/tmpI.H at line 190. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) in "/home/etudes/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/home/etudes/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >:perator()() in "/home/etudes/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #3 Foam::compressible::RASModels::v2f::correct() in "/home/etudes/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so" #4 in "/home/etudes/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/bin/buoyantSimpleFoam" #5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #6 in "/home/etudes/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/bin/buoyantSimpleFoam" Abandon Has anyone already tested this model and knows where my problem? Thank. Last edited by Yoann; March 12, 2013 at 04:28. |
April 2, 2013, 10:25 |
Phillip
Rep Power: 14 |
What is your intention to solve this case with the v2f model?
What is with your bc's? please post the bcs and your assumptions... |
April 3, 2013, 03:06 |
Y.LANCE
Rep Power: 13 |
It was a bug in version 2.2.
This is modified. |
January 13, 2016, 08:57 |
error in v2f
hamide hayati
Rep Power: 10 |
hello all
i'm new in openfoam and wanna modeling turbulence with v2f model. i did it, but i faced an error: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0-5be49240882f Exec : pisoFoam Date : Jan 13 2016 Time : 16:45:08 Host : "hamide-HP-ProBook-4530s" PID : 2792 Case : /home/hamide/run/tutorials/incompressible/pisoFoam/ras/aaaaV2f nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RASModel Selecting RAS turbulence model v2f bounding v2, min: 0 max: 0.0625 average: 0.0625 v2fCoeffs { Cmu 0.22; CmuKEps 0.09; C1 1.4; C2 0.3; CL 0.23; Ceta 70; Ceps2 1.9; sigmaK 1; sigmaEps 1.3; } Starting time loop Time = 5e-05 Courant Number mean: 0.0003125 max: 0.529571 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 3.21506e-06, No Iterations 9 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 3.76836e-06, No Iterations 11 DICPCG: Solving for p, Initial residual = 1, Final residual = 0.098316, No Iterations 541 time step continuity errors : sum local = 6.14801e-05, global = -8.04276e-07, cumulative = -8.04276e-07 DICPCG: Solving for p, Initial residual = 0.023492, Final residual = 9.11666e-07, No Iterations 585 time step continuity errors : sum local = 1.4079e-06, global = -1.61994e-09, cumulative = -8.05896e-07 #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so" #5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so" #6 Foam::incompressible::RASModels::v2f::correct() in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so" #7 in "/opt/openfoam220/platforms/linux64GccDPOpt/bin/pisoFoam" #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 in "/opt/openfoam220/platforms/linux64GccDPOpt/bin/pisoFoam" Floating point exception (core dumped) would you please help me to solve it? |
v2f model implementation for airfoil in FLUENT | Sunil | FLUENT | 4 | December 7, 2016 18:17 |
v2f Turbulence Model (and others?) | Travis | FLUENT | 4 | January 7, 2009 01:18 |
v2f model? | dh | Main CFD Forum | 3 | October 22, 2008 04:55 |
V2F turbulence model | Karunakaran | FLUENT | 1 | June 10, 2004 13:19 |
V2F - Turbulence Model | Computational Dynamics | Siemens | 3 | April 13, 2001 11:49 |
