February 16, 2016, 18:33 |
Divergence of DILUPBiCG
#1 | ||
Rep Power: 10 |
I've been using OpenFOAM to simulate combustion. I began by simulating with the combustion model inactive, and then turned it on. Around 20 time steps after activating combustion, this happened:
solvers { Yi { solver PBiCG; preconditioner DILU; tolerance 1e-09; relTol 0; } } At first I thought that my chemistry model had malfunctioned and given non-physically large reaction rates, but then if this were the case then I would also expect the initial residual of H2O to be extremely large. This suggests to me that the problem is numerical. I'm wondering how to remedy this situation; specifically:
February 17, 2016, 02:08 |
Matvey Kraposhin
Rep Power: 21 |
Try to use smoothSolver Or BiCGStab , which is present in foam-extend
MDPI Fluids (Q2) special issue for OSS software: https://www.mdpi.com/journal/fluids/..._modelling_OSS GitHub: https://github.com/unicfdlab Linkedin: https://linkedin.com/in/matvey-kraposhin-413869163 RG: https://www.researchgate.net/profile/Matvey_Kraposhin |
March 7, 2016, 14:35 |
Rep Power: 10 |
Thanks mkraposhin, this was helpful. I think that the real problem turned out to be my inlet conditions, however: I have a turbulentInlet BC and the magnitude of the fluctuations was far too large (over 0.1). My simulation has not diverged in this way since I've reduced the fluctuations (to more like 0.01).
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
Simulation seems to converge but crashes suddenly | xxxx | OpenFOAM | 16 | September 12, 2014 08:07 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
