February 19, 2016, 01:11 |
correct pressure boundary condition
Elham
Rep Power: 16 |
Hi everyone,
I have simulated a single droplet falling in a chamber by interDyMFoam. I can see the drop is falling properly in the chamber. Then in order to study the effect of turbulence on the droplet, I have added a horizontal plate inside the chamber. I have set B.Cs of the plate similar to the other walls. But this time the droplet doesn't move. I think the plate B.Cs especially the bottom part of it make the trouble. I will appreciate for any suggestion for other kind of B.Cs that may solve the problem. I have attached mesh view. p-rgh boundary conditions are as following: internalField uniform 0; boundaryField { plateWall { type fixedFluxPressure; value uniform 0; } leftWall { type fixedFluxPressure; value uniform 0; } rightWall { type fixedFluxPressure; value uniform 0; } down { type fixedFluxPressure; value uniform 0; } up { type totalPressure; p0 uniform 0; U U; phi phi; rho rho; psi none; gamma 1; value uniform 0; } front { type fixedFluxPressure; value uniform 0; } back { type fixedFluxPressure; value uniform 0; } } Thanks. Elham |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Boundary Condition for pressure and velocity | mecman | OpenFOAM Pre-Processing | 1 | May 7, 2014 16:51 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
pressure boundary condition in fractional step | Jean-François Corbett | Main CFD Forum | 3 | January 10, 2006 08:49 |
