February 22, 2016, 07:08 |
keyword delta is undefined... but it is!
Rep Power: 17 |
I'm using OF3.0 with RASModel kOmegaSSTSAS which used to be classified as an LES model. When I run pimpleFoam it complains about delta not being defined. The case worked fine with OF2.3.1. Any thoughts what I'm doing wrong here?
--> FOAM FATAL IO ERROR: keyword delta is undefined in dictionary "/0_solid_10ms_OF3/constant/turbulenceProperties.RAS.kOmegaSSTCoeffs" file: /0_solid_10ms_OF3/constant/turbulenceProperties.RAS.kOmegaSSTCoeffs from line 0 to line 0. From function dictionary::lookupEntry(const word&, bool, bool) const in file db/dictionary/dictionary.C at line 442. FOAM exiting My turbulenceProperties files is: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object turbulenceProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // simulationType RAS; RAS { RASModel kOmegaSSTSAS; turbulence on; printCoeffs on; delta vanDriest; cubeRootVolCoeffs { deltaCoeff 1; } PrandtlCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } smoothCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } maxDeltaRatio 1.1; } Cdelta 0.158; } vanDriestCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } smoothCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } maxDeltaRatio 1.1; } Aplus 26; Cdelta 0.158; } smoothCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } maxDeltaRatio 1.1; } } // ************************************************************************* // |
February 22, 2016, 11:28 |
If you read error message: Code:
delta is undefined in dictionary .../turbulenceProperties.RAS.kOmegaSSTCoeffs |
Second Derivative Zero - Boundary Condition | fu-ki-pa | OpenFOAM | 11 | March 27, 2021 04:28 |
LEMOS InflowGenerator | r_gordon | OpenFOAM Running, Solving & CFD | 103 | December 18, 2018 00:58 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 12:38 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
