February 24, 2016, 05:28 |
implementation with OF2.3.0
Arsalan
Rep Power: 11 |
Dear Foamers,
I'm trying to use swak4Foam libraries in my new solver that compiled completely and runs successfully without swak implementation, my simulation is a gas-liquid two phase flow with solid body motion mesh. My swak expression that i have added to the controlDict dictionary is shown below : Code:
libs ( "libOpenFOAM.so" "libtwoPhaseInterfaceProperties.so" "libinterfaceProperties.so" "libsimpleSwakFunctionObjects.so" "libswakFunctionObjects.so" "libotransitionalParabolicVelocityFvPatchVectorField.so" "libswakTopoSources.so" "libgroovyBC.so" ); functions ( createInterface { type createSampledSurface; outputControl timeStep; outputInterval 1; surfaceName interface; surface { type isoSurface; isoField alpha1; isoValue 0.5; interpolate true; } } Yheight { type swakExpression; valueType surface; surfaceName interface; verbose true; expression "pos().y"; accumulations ( min max ); } ) Code:
It seems that the method simpleFunctionObject::movePoints is not properly implemented (neither in the class or any appropriate subclasses). If you think that it should work anyway add the entry ignore_unimplemented_simpleFunctionObject::movePoints true; to the dictionary ".Yheight" and we will go on. Alternativly properly implement the method. Anyway: I'll go die now --> FOAM FATAL ERROR: Not implemented From function simpleFunctionObject::movePoints in file helpers/switchableNotImplemented.C at line 85. FOAM aborting Code:
--> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : libtwoPhaseInterfaceProperties.so: cannot open shared object file: No such file or directory --> FOAM Warning : From function dlLibraryTable::open(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99 could not load "libtwoPhaseInterfaceProperties.so" --> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : libotransitionalParabolicVelocityFvPatchVectorField.so: cannot open shared object file: No such file or directory --> FOAM Warning : From function dlLibraryTable::open(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99 could not load "libotransitionalParabolicVelocityFvPatchVectorField.so" swak4Foam: Allocating new repository for sampledSurfaces --> FOAM Warning : From function simpleFunctionObject::simpleFunctionObject in file simpleFunctionObject/simpleFunctionObject.C at line 109 'outputControlMode' not found in Yheight Assuming: timeStep --> FOAM Warning : From function simpleFunctionObject::simpleFunctionObject in file simpleFunctionObject/simpleFunctionObject.C at line 117 'outputInterval' not found in Yheight Assuming: 1 swak4Foam: Setting default mesh Any comments and discussion is greatly appreciated ! Apologies for the long post. Thank you. Best Regards, Arsalan. |
of230, swak4foam |
Free CFD code with implementation of Menter's k-omega SST model | nikola_m | Main CFD Forum | 2 | May 8, 2020 12:13 |
Issues in FGM combustion model implementation | Lisandro Maders | OpenFOAM Programming & Development | 15 | April 22, 2020 19:18 |
a little confused with the implementation of compressibleInterFoam | su_junwei | OpenFOAM Running, Solving & CFD | 2 | May 7, 2014 17:33 |
Implementation issues of fvSchemes / laplacianScheme, in particular gaussLaplacianSch | thomek | OpenFOAM Programming & Development | 0 | October 18, 2010 05:10 |
Please explain the implementation of species transport Eqn in reactingFoam | kallipygian | OpenFOAM Running, Solving & CFD | 0 | October 13, 2008 07:29 |
