AMI dynamic mesh and Lagrangian Particle Clouds |
March 3, 2016, 08:26 |
Frank Bos
Rep Power: 18 |
Dear all,
Currently, I am studying the capabilities of using OpenFOAM for tracking lagrangian particles (kinematic clouds) and their interaction with a rotating object, such as propellors. To combine a kinematicCloud and pimpleDymFoam, we modified the code, which is fairly straightforward, kinematicCloud.evolve() should do the trick. I am currently solving the mixerVesselAMI2D tutorial by specifying particle injection outside of the AMI region. Everything start fine, until at some instance suddenly some particles are going through the wall and a bunch of particles are accelerating to reach velocities larger than the rotating regions, which is not physical. Did anyone do something similar (resolve particle clouds combined with AMI regions) and encounter similar problems? Thanks in advance! Cheers, Frank
Frank Bos |
March 4, 2016, 13:26 |
Thomas Boucheres
Rep Power: 12 |
I have worked on particle cloud + AMI a long time ago. I don't remember everything today
Ok, to start, are you running your cases in sequential or parallel mode? The last one currently don't implement particles crossing the AMI interfaces. |
March 5, 2016, 07:48 |
#3 | |
Frank Bos
Rep Power: 18 |
Thanks for your reply. Well, to start with i have implemented the evolve cloud routine in pimpleDyMFoam of openfoam-3.0.x and running in serial only as a start. Even in serial when particles cross the ami interface some particles get lost and some particles are going to get wild and they will escape the domain.This all occurs for a simple mixerAMI2d tutorial..... The GGI implementation of foam extend works well in parallel but it does not support particles to cross the GGI, all particles crossing are removed from the simulation. It seems that there are several severe bugs in the official ESI release of Openfoam related to AMI and particle clouds..... Regards, Frank
Frank Bos |
May 3, 2016, 07:30 |
Moritz
Rep Power: 10 |
Hi there,
are there any news on this topic? I am currently simulating particle injection wiht sprayFoam using a moving rotor with AMI interfaces in OF-3.0.x which works fine but I really need to decompose the case. My question: Is there a possibility of doing both particle tracking with GGI/AMI interfaces together with particle tracking? Thanks a lot and greets Moritz |
March 1, 2017, 06:18 |
Gogo
Rep Power: 10 |
Dear all,
I coupled the pimpleDyMFoam with kinematicCloud lib. in order to track the particle moving inside stirring tank. UNfortunately, I faced the same problem which you had. The interaction between particle and rotating wall does not work well in OpenFOAM. Also the particles goes through the wall at some time steps and they are not able to recognize that there is a wall here. That's why, I would like to ask if you find a solution for this problem. Best regards, Amjad |
January 16, 2018, 02:07 |
#6 | |
liyuan
Rep Power: 10 |
January 16, 2018, 02:20 |
#7 | |
liyuan
Rep Power: 10 |
January 26, 2018, 02:17 |
Rep Power: 10 |
I'm struggling with the same problem...
I was able to successfully run a case for a certain configuration of particles + mesh + solver settings. Then I wanted to run the same configuration for particles with a higher density, but the error mentioned above appeared again... PS. OpenFoam Version 5.0 |
February 28, 2018, 08:21 |
#9 | |
liyuan
Rep Power: 10 |
February 28, 2018, 09:35 |
#10 |
Rep Power: 10 |
Hi yuanlee2011,
first I have to emphasize that I'm definitely not an expert in lagrangian simulations. Maybe I was just lucky to find a physical solution for a certain configuration. For my calculations I used OF-5.0 and the standard DPMDyMFoam. I made the following observations: (Anyone who is more skilled than me is invited to correct or to explain these points)
Good Luck Q.E.D. |
Lagrangian Mesh | e.abedini | Main CFD Forum | 1 | May 27, 2015 05:03 |
Lagrangian particle tracking and cell size | Julian K. | CFX | 4 | May 27, 2014 11:35 |
Fluent Dynamic Mesh query | Subodh21 | FLUENT | 0 | March 19, 2014 17:31 |
Update of the variables after dynamic mesh motion. | gtg258f | OpenFOAM Programming & Development | 9 | January 18, 2014 10:08 |
Does lagrangian track model support moving mesh with topological changes?? | su_junwei | OpenFOAM Running, Solving & CFD | 3 | October 18, 2012 03:53 |
