Possibility to run several calculations at the same time with OpenFoam?
Old   March 7, 2016, 06:22
Default Possibility to run several calculations at the same time with OpenFoam?
mqsim is on a distinguished road
Hi everyone,
I am wondering if there is a possibility to run at least two calculations at the same time. I have 8 processors that I am using to run a case. I am currently using around 8Go of RAM and I have 32Go of RAM.
Do you think it is possible to run two run two calculations at the same time without any negative impact on the calculation time?
Regards,
mqsim
mqsim is offline   Reply With Quote
Old   March 13, 2016, 07:34
Artur's Avatar
Artur
Artur will become famous soon enough
Don't suppose there's a definite answer since a lot will depend on your mesh size, decomposition, whether running steady or unsteady simulations, and hardware setup (8 physical cores or 4 with 2 threads as on intel i7, how many memory channels per processor, etc.). Best suggestion is probably to try it and see
When I run stuff on my local machine (intel i7, 16 GiB RAM) I find that for moderate mesh sizes I achieve faster solutions when only using 4 cores over all 8, which I suspect has something to do with the memory channels and how the processor handles dual threads per physical core. I suppose you could run into similar problems when running multiple simulations on the same machine at the same time but perhaps even if the individual simulations run slower you can still save time by running them in parallel?
All the best,
A
Artur is offline   Reply With Quote
Old   March 16, 2016, 09:28
Hi Arthur,
Indeed, the best way to know is to try. But I wanted to know different experiences so thank you for yours!
It is true if I run several calculations at the same time, simulations run slower. I have not yet tried to use only 4 cores over all 8, I have also an intel core i7 so it could be a way to run two simulations at the same time without any negative impact on the calculation time.
Regards,
mqsim
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 07:56
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
