June 12, 2016, 09:55 |
mean water level increase
#21 |
Theo Moura
Rep Power: 9 |
Hi all,
I've been trying to simulate bichromatic wave groups propagating over a sloping beach using the irregular waveType. The problem I am having is the water level that is constantly increasing. I have in the waveDict both absGen true and absDir 0. Tried different combination with no success. Any hint will be appreciated. Best Regards, Theo |
June 12, 2016, 21:13 |
#22 |
Pablo Higuera
Rep Power: 19 |
Hi Theo,
absorption does work with irregular waves. Check your variables, absGen does not exist, it should be genAbs. If your waves are propagating in the +X direction, then absDir 0 is fine. Just to be safe, you can always set it to a value > 360 Best, Pablo |
June 13, 2016, 13:07 |
#23 |
Theo Moura
Rep Power: 9 |
Hi Pablo,
thank you for your reply, I've tested two cases with the same setup, but different waveDict. In the first one irregular waveType was used and the water level is constantly increasing. In the second case, I used regular waveType with no visible changes in the water level. Not sure what I am doing wrong. Best Regards, Theo WaveDict Case 1 waveType irregular; genAbs 1; absDir 0.; nPaddles 1; tSmooth 3.; secondOrder 1; wavePeriods 2 ( 1.0776 0.9756 ); waveHeights 2 (0.05 0.05 ); wavePhases 2 ( 1.977467 2.549666 ); waveDirs 2 {0.}; // ** WaveDict Case 2 waveType regular; waveTheory cnoidal; genAbs 1; absDir 0.0; nPaddles 1; waveHeight 0.15; wavePeriod 2; waveDir 0.0; wavePhase 4.71238898; |
June 14, 2016, 01:55 |
#24 |
Pablo Higuera
Rep Power: 19 |
Hi Theo,
maybe it is an issue with 2nd order generation, I will take a look, thanks for reporting. Best, Pablo |
June 14, 2016, 22:59 |
#25 |
Pablo Higuera
Rep Power: 19 |
Hi again,
I have done some tests and ended up changing the code. I tested your bichromatic sea state with second order for 150 s and the mass is not increasing now. Please update the code, recompile and try again. Best, Pablo |
June 15, 2016, 09:20 |
#26 |
Isabelle Schmidt
Rep Power: 9 |
Hi there,
I'm trying to simulate a wave that flows into a channel that is below the watersurface. I can see the movement of the wave by Ux. But Ux does't change in the channel, it seems as if the wave just moves on, as if there isn't any obstacle. Is Ux appropriate to observate the movement of the wave? |
June 15, 2016, 22:58 |
#27 |
Pablo Higuera
Rep Power: 19 |
HI Isabelle,
I cannot picture your problem correctly with your short description. Maybe an issue with the mesh not being fine enough? Maybe due to incompressible phases? Just guessing... Best, Pablo |
June 17, 2016, 04:38 |
Validation of wave run-up height
#28 |
Martin Silkens
Rep Power: 9 |
Dear Pablo,
like you told me, I should validate the run-up height of my waves on a dike. I did the post-processing with paraview and exported my results to excel. There I noticed, that my wave run-up heights are to high. I tried now to produce friction with the k-epsilon-function on the ground and on the dike, that the waves will run-up less. But the results are still the same. Isn't it possible to use k-epsilon-function in olaFoam? Should I use another wave theory (now I am using cnoidal), maybe it is not good enough for shallow water. Or do I have to change something in the solver? Thank you for an answer and your efforts! Best regards Martin |
June 19, 2016, 08:49 |
#29 |
Isabelle Schmidt
Rep Power: 9 |
Hey Pablo,
Thank you for your reply. I tried to figuer out what exactly my problem is. 1. why is the velocity across the depth that low? The values for Ux are between 10^(-6)-10^(-7)? 2. I tried to run a simulation with momentumPredictor on but it didn't work: "keyword Ufinal is undefined" I used one of the examples as waveDict: waveType regular; waveTheory cnoidal; genAbs 1; absDir 0.0; nPaddles 1; waveHeight 0.10; wavePeriod 3; waveDir 0.0; wavePhase 4.71238898; Thank you very much for your help, Isabelle |
June 19, 2016, 22:23 |
#30 |
Pablo Higuera
Rep Power: 19 |
@Martin,
k-epsilon does work in olaFoam and depending on the case, it can have quite affect quite a lot. Dynamics and mesh size/shape can have an impact on that and you can also introduce rough wall functions, but if you don't know if you should be using cnoidal theory, you definitely need to study more. @Isabelle, Are you sure that you are measuring the X component and not the Y component? Check this video, the top panel shows exactly that wave conditions (baseWaveFlume): https://www.youtube.com/watch?v=dNffOs-1Esw At t = 15 s, water velocities in the X direction vary from 0.6 to -0.17 m/s. If you want to use momentumPredictor, you need to define the solver and convergence criteria for Ufinal in fvSolution. Look for Ufinal word in the tutorials folder to have a better idea. Best, Pablo |
June 20, 2016, 02:05 |
Can the Olafoam be used to simulate the longshore currents?
#31 |
chunping ren
Rep Power: 9 |
Hi there,
I think the Olafoam can be used to simulate the longshore currents whatever in practical field and laboratory. But I did not find any publications or reports about this in recent days. Could you give me some suggestions how to use the Olafoam to calculate the 2D or 3D longshore currents ? Best regards Chunping |
June 20, 2016, 02:33 |
#32 |
Pablo Higuera
Rep Power: 19 |
Hi Chunping,
it is possible, just match your experimental facility. For field conditions you would need to be more careful with the lateral boundary conditions. Best, Pablo |
June 20, 2016, 05:24 |
#33 |
chunping ren
Rep Power: 9 |
Hi Pablo,
Thank your reply quickly very much. I will focus on the simulation of longshore currents using Olafoam due to your suggestions. And I would like to share with you about this in the future. Cheers Chunping |
June 29, 2016, 04:08 |
#34 |
Pablo Higuera
Rep Power: 19 |
Dear all,
I have updated olaFoam to work under the newly released OpenFOAM 4.0. You can find all the details here: https://sites.google.com/site/olafoa...edtoopenfoam40 Best regards, Pablo |
July 4, 2016, 05:15 |
#35 |
Isabelle Schmidt
Rep Power: 9 |
Dear Pablo,
For my case I have to simulate irregular waves, is that possible with olaFoam? I looked at the tutorial irreg45degTank, but I do not really understand how you built that waveDict ?! Thank you very much for your help, best regards isabelle |
July 4, 2016, 05:26 |
#36 |
Pablo Higuera
Rep Power: 19 |
Hi Isabelle,
please check the additional materials included in the zip file, there is a complete guide that can help you. An irregular sea state is just the summation of N individual components, as Theo showed in a previous post (with just 2 components). The way to calculate the components is up to you and your sea state requirements. Best, Pablo |
July 8, 2016, 05:50 |
#37 |
Isabelle Schmidt
Rep Power: 9 |
Dear Pablo,
I plotted my residuals and I have 2 questions about it: 1. There are no residuals/information about U, neither x,y,z. Do you know why? 2. The residuals for alpha.water and p_rgh are increasing, what can be the problem? My case is a 2D channel with waveDict as following: waveType regular; waveTheory StokesI; genAbs 1; absDir 0.0; nPaddles 1; waveHeight 2.3; wavePeriod 8.36; waveDir 0.0; wavePhase 4.71238898; Thank you very much for your support, Best regards, Isabelle |
July 10, 2016, 05:17 |
#38 |
Pablo Higuera
Rep Power: 19 |
Hi Isabelle,
there is no problem at all, you are not running a steady-state solver, you are running a transient one. Therefore, the numbers that you see do not mean that your simulation is diverging, only that it is evolving in time. Each time step your solutions is iteratively calculated until the tolerances defined are met. Best, Pablo |
July 10, 2016, 19:06 |
Implementing dynamic floating box
#39 |
Abigail Stehno
Rep Power: 10 |
First of all- thank you for creating the olaFoam solver! It is very helpful and easy to understand. I am trying to implement a floating box using the waveFlume tutorial. I have modified the tutorial so the dynamic motion is in the floating box. The case works fine when the floating box is not added. According to checkMesh, mesh is good with and without the floating box. Below is the error I am receiving: In serial: Code:
#0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 in "/lib64/libc.so.6" #3 Foam::PhiScheme<double, Foam::interfaceCompressionLimiter>::limiter(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const at ??:? #4 Foam::limitedSurfaceInterpolationScheme<double>::weights(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const at ??:? #5 Foam::surfaceInterpolationScheme<double>::interpolate(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const at ??:? #6 Foam::fv::gaussConvectionScheme<double>::interpolate(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const at ??:? #7 Foam::fv::gaussConvectionScheme<double>::flux(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const at ??:? #8 at ??:? #9 at ??:? #10 __libc_start_main in "/lib64/libc.so.6" #11 at ??:? ./runCase: line 19: 8567 Floating point exceptionolaDyMFoam > olaDyMFoam.log Code:
[0] #0 Foam::error::printStack(Foam::Ostream&)[1] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [0] #1 Foam::sigFpe::sigHandler(int) at ??:? [1] #1 Foam::sigFpe::sigHandler(int) at ??:? [0] #2 at ??:? [1] #2 in "/lib64/libc.so.6" [0] #3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) in "/lib64/libc.so.6" [1] #3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:? [0] #4 at ??:? [1] #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&)Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:? [1] #5 at ??:? [0] #5 [1] at ??:? [1] #6 __libc_start_main[0] at ??:? [0] #6 __libc_start_main in "/lib64/libc.so.6" [1] #7 in "/lib64/libc.so.6" [0] #7 Also, why am I getting two different errors between serial and parallel? Code is attached- Thank you in advance! Abbie |
July 11, 2016, 03:06 |
#40 |
Pablo Higuera
Rep Power: 19 |
Hi Abigail,
remember that your solution is as good as your mesh. OpenFOAM reporting "mesh OK" does not guarantee that it really is suitable for your case, and floating body simulations are really (REALLY) sensitive to the mesh. Your resolution in the y direction is simply not enough, try refining. Best, Pablo |
generation, ihfoam, olafoam, waves |
Display Modes | |
Divergence detected in AMG solver: k when udf loaded | google9002 | Fluent UDF and Scheme Programming | 3 | November 7, 2019 23:34 |
udf problem | jane | Fluent UDF and Scheme Programming | 37 | February 20, 2018 04:17 |
UDF velocity profile | willroca | Fluent UDF and Scheme Programming | 2 | January 10, 2016 03:13 |
Error messages | atg | enGrid | 7 | August 30, 2013 11:16 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
