April 11, 2016, 06:43 |
Floating point exception
Cristian Ariza
Rep Power: 10 |
Hello all,
I am relatively new to OpenFoam and I am trying to simulate a photoreactor on incompressible turbulent flow at steady-state. I copied most of the code of the pitzDaily model from the tutorials adjusting all the parametres for my case. When running the case in parallel I get the following error: Code:
mpirun noticed that process rank 7 with PID 3333 on node XXXXX exited on signal 8 (Floating point exception). Code:
decomposePar mpirun -n 16 renumberMesh -overwrite -parallel mpirun -np 16 simpleFoam -parallel reconstructPar -latestTime
I believe there is some bad boundary condition but I cannot find where it is. Here is a 7z file with the case: https://mega.nz/#!Z1JTjZoY!YSOBNCHdW..._ArkRD3O1SmzvU Last edited by cristian.arbe; April 22, 2016 at 05:43. |
April 11, 2016, 11:27 |
Cristian Ariza
Rep Power: 10 |
Succeeded by simulating the case in laminar flow but turbulent still does not work.
April 12, 2016, 05:26 |
Tobias Holzmann
Rep Power: 51 |
you can try to use the laminar pre-calculation for your turbulent calculation. Normally, I suppose that you made a mistake in the set-up of your turbulence variables k, epsilon or omega. For your 7z file we need some key! "To access this folder/file, you will need its Decryption key. If you do not have the key, contact the creator of the link."
Keep foaming, Tobias Holzmann |
April 12, 2016, 06:38 |
Cristian Ariza
Rep Power: 10 |
April 12, 2016, 07:00 |
Cristian Ariza
Rep Power: 10 |
I am sorry, what do you mean by using the correct boundary conditions? This is how my k and epsilon files look like respectively:
internalField uniform 8.7277e-006; boundaryField { fluidInlet { type fixedValue; value uniform 0.0090220; } fluidOutlet { type zeroGradient; } fluidCylinder { type kqRWallFunction; value uniform 8.7277e-006; } fluidRefinement { type kqRWallFunction; value uniform 0.0090220; } } Code:
internalField uniform 3.0534e-006; boundaryField { fluidInlet { type fixedValue; value uniform 0.33827; } fluidOutlet { type zeroGradient; } fluidCylinder { type epsilonWallFunction; value uniform 3.0534e-006; } fluidRefinement { type epsilonWallFunction; value uniform 0.33827; } } Last edited by cristian.arbe; April 22, 2016 at 05:43. |
April 14, 2016, 09:44 |
#8 | |
Cristian Ariza
Rep Power: 10 |
mpirun noticed that process rank 6 with PID 2520 on node XXXX exited on signal 8 (Floating point exception). Last edited by cristian.arbe; April 22, 2016 at 05:43. |
April 14, 2016, 10:32 |
#10 |
Tobias Holzmann
Rep Power: 51 |
some hints:
k 0.2 epsilon 0.2 U 0.4 p 0.3 Try again you will see it should work and then you will find the problem cells You sill will get a bounding problem: Code:
bounding epsilon, min: -0.00074722 max: 1053.16 average: 1.14941 Thats due to your mesh. The inlet and outlet patches are not good. Also your nCellsBetweenLevels should be increased and the inlet and outlet patch should be refined 1 level more. The transition between inlet/outlet patches to your refine walls should be smooth. I did not check if you also have layers in the refinement walls - skip that at the beginning. Cheers.
April 15, 2016, 04:47 |
#11 |
Cristian Ariza
Rep Power: 10 |
I'm trying to do all the changes you suggested, although I wanted to ask, when you talk about inlet and outlet, you refer to the tubes or the actual patches? Since the inlet/outlet patches only refer to the surface of I/O not the whole inlet tube.
Thank you very much for your time! |
April 15, 2016, 05:02 |
#12 | |
Tobias Holzmann
Rep Power: 51 |
I refer only to the patches. The outlet and inlet patches have some "bad" faces at the connection between your refinement patch and inlet/outlet patch. These faces are not aligned correct.
April 15, 2016, 05:11 |
#13 |
Tobias Holzmann
Rep Power: 51 |
SNAP controls.
increase the nSolveIter decrease tolerance decrease nFeatureIter CASTELLATED controls. increase nCellsBetween At least I am not a fan of featureEdge refinement. I think there was some new keyword about tolerance etc. Using this, you could get troubles (see tutorial on my homepage) if the backgroundMesh is aligned with one patch/feature edge - I think in your case it is okay. TRIANGULATED SURFACE (STL) I will never use STL's that will not be closed or exported by CAD software. The triangulation is very bad. In your case the STL is not waterproof. My experience after 6 years: Never use an non-waterproofed STL and snappyHexMesh. It could work or otherwise you could get some unexpected results (sometimes) especially if the gaps are bigger than the cells. So a few things to do.
April 15, 2016, 05:16 |
#14 |
Tobias Holzmann
Rep Power: 51 |
One thing left.
surfaceFeatureEdges... please check it before using them. See attachment. Due to the fact that your STL's are not identical at the interfaces (same amount of points at the same locations) the featureEdges will also be different (attachment). So my question to you, which one should snappy use now? In addition, some feature edges are not closed etc... Correct this too!
April 15, 2016, 05:40 |
#15 |
Cristian Ariza
Rep Power: 10 |
The STL files are exported from a model from SolidWorks I made myself and it was fine before exporting. What is your suggestion to import the geometry then?
April 15, 2016, 05:48 |
#16 |
Tobias Holzmann
Rep Power: 51 |
CAD files are okay. But after exporting single surfaces you will never get a closed surface. Just open paraview and load your STL. Show the edges and you wlil see.
April 15, 2016, 06:23 |
#17 |
Cristian Ariza
Rep Power: 10 |
So should I stick with the STL files even if there are some errors or is there something I can do to fix it?
April 15, 2016, 06:26 |
#18 |
Tobias Holzmann
Rep Power: 51 |
Export your geometry as STEP, open it with SALOME, create your different patches (create groups), go to mesh module and mesh the different patches like you want. Keep in mind that the interfaces should be identical triangulated. Export the surfaces as STL and combine them like
cat *.stl > mySTL.stl surfaceCheck mySTL.stl PS: If you stick your STL together, you would end up with a non closed STL -> bad. This happens always if you export out of CAD software (ALWAYS). You can export the whole geometry, then you get a closed STL but then you do not have regions // single patches (thats the problem).
April 15, 2016, 09:37 |
#19 | |
Cristian Ariza
Rep Power: 10 |
I tried installing and running SALOME but I get the error
Edit: solved by downloading the generic binaries instead of Ubuntu ones. |
April 15, 2016, 10:12 |
#20 |
Cristian Ariza
Rep Power: 10 |
So what you are saying is to export the STL geometry from SALOME or to actually mesh the model on SALOME and export the mesh?
icoFoam floating point exception (8) | leizhao512 | OpenFOAM Running, Solving & CFD | 7 | November 1, 2018 11:43 |
A floating point exception - SEM Model | yansheng | STAR-CCM+ | 1 | April 4, 2016 04:57 |
Floating point exception from twoPhaseEulerFoam | openfoammaofnepo | OpenFOAM Running, Solving & CFD | 1 | March 19, 2016 13:56 |
floating point exception [invalid operation] | jubair073 | STAR-CCM+ | 5 | April 24, 2015 13:05 |
Inlet Velocity Profile BC - Floating Point exception during solution initialization | Janshi | STAR-CCM+ | 4 | March 14, 2012 10:21 |
