April 21, 2016, 08:55 |
LTS - interFoam - problems
Rep Power: 16 |
I have a free-surface flow that is similar to the waterchannel tutorial. I am using Local Time Stepping (LTS) but I have convergence problems. I will below go through my case step by step and provide the case files if someone is interested to take a look and give me some pointers. A schematic of the geometry can be seen below I have used cfMesh to create the mesh, here is the output of the checkMesh -allGeometry -allTopology: Code:
Create time Create polyMesh for time = 0 Enabling all (cell, face, edge, point) topology checks. Enabling all geometry checks. Time = 0 Mesh stats points: 385360 internal points: 288677 edges: 1074519 internal edges: 882306 internal edges using one boundary point: 93367 internal edges using two boundary points: 0 faces: 994222 internal faces: 898692 cells: 305063 faces per cell: 6.20499 boundary patches: 5 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 268418 prisms: 2112 wedges: 0 pyramids: 5269 tet wedges: 0 tetrahedra: 2336 polyhedra: 26928 Breakdown of polyhedra by number of faces: faces number of cells 6 6170 7 3188 8 599 9 11939 10 1 12 3697 13 1 15 1273 16 1 18 54 21 4 24 1 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Topological cell zip-up check OK. Face-face connectivity OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology Bounding box atmo 29308 30048 ok (non-closed singly connected) (34.1243 215.677 108.957) (71.5834 236.001 114) inlet 3800 4181 ok (non-closed singly connected) (51.0844 217.546 107.302) (71.5835 226.81 110.267) outlet 3283 3598 ok (non-closed singly connected) (21.1025 219.023 104.886) (25.9396 238.029 108.5) sula-fleyti 9304 9450 ok (non-closed singly connected) (31.7173 224.968 105.022) (35.0795 226.499 108.936) walli 49835 51290 ok (non-closed singly connected) (21.1025 215.677 104.886) (71.5835 238.029 110.267) Checking geometry... Overall domain bounding box (21.1025 215.677 104.886) (71.5835 238.029 114) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (1.89714e-16 1.40128e-15 1.1662e-15) OK. Max cell openness = 3.27551e-16 OK. Max aspect ratio = 10.2315 OK. Minimum face area = 0.000174025. Maximum face area = 3.46417. Face area magnitudes OK. Min volume = 1.50399e-06. Max volume = 8.48143. Total volume = 3955.37. Cell volumes OK. Mesh non-orthogonality Max: 64.2831 average: 9.91544 Non-orthogonality check OK. Face pyramids OK. Max skewness = 2.10038 OK. Coupled point location match (average 0) OK. ***Error in face tets: 16 faces with low quality or negative volume decomposition tets. <<Writing 16 faces with low quality or negative volume decomposition tets to set lowQualityTetFaces Min/max edge length = 0.00357058 1.46541 OK. *There are 2062 faces with concave angles between consecutive edges. Max concave angle = 63.3745 degrees. <<Writing 2062 faces with concave angles to set concaveFaces Face flatness (1 = flat, 0 = butterfly) : min = 0.80978 average = 0.999301 All face flatness OK. Cell determinant (wellposedness) : minimum: 0.0415301 average: 12.492 Cell determinant check OK. ***Concave cells (using face planes) found, number of cells: 2444 <<Writing 2444 concave cells to set concaveCells Face interpolation weight : minimum: 0.0647744 average: 0.45461 Face interpolation weight check OK. Face volume ratio : minimum: 0.0177947 average: 0.801404 Face volume ratio check OK. Failed 2 mesh checks. End Here is an image showing some of the lowQualityTetFaces in the domain This is a list of how I set the boundary conditions, provided by patchSummary Code:
Valid fields: volScalarField nut volScalarField alpha.water volVectorField U volScalarField k volScalarField alpha.water.org volScalarField p_rgh volScalarField omega patch : atmo scalar nut calculated scalar alpha.water inletOutlet scalar k inletOutlet scalar alpha.water.org inletOutlet scalar p_rgh totalPressure scalar omega inletOutlet vector U pressureInletOutletVelocity patch : inlet scalar nut calculated scalar alpha.water variableHeightFlowRate scalar k fixedValue scalar alpha.water.org variableHeightFlowRate scalar p_rgh fixedFluxPressure scalar omega fixedValue vector U variableHeightFlowRateInletVelocity patch : outlet scalar nut calculated scalar alpha.water zeroGradient scalar k inletOutlet scalar alpha.water.org zeroGradient scalar p_rgh fixedFluxPressure scalar omega inletOutlet vector U zeroGradient group : wall scalar nut generic scalar alpha.water zeroGradient scalar k generic scalar alpha.water.org zeroGradient scalar p_rgh fixedFluxPressure scalar omega generic vector U fixedValue End I have basically adopted the fvSchemes and fvSolution from the DTCHull tutorial that uses localEuler (LTS) as its ddt scheme. I squeezed down the tolerances on the solvers to lower the continuity error in each timestep and also played with the damping/smoothing coefficients. You can find the controlDict, fvSchemes and fvSolution files attached to this post. I am confused now if the mesh, B.C. or schemes/solvers are causing the divergence. If you can give me comments on this case that would be appreciated. You can find the case files here: case-files Last edited by fusij; April 21, 2016 at 13:47. |
May 4, 2016, 02:30 |
Kate Bradbrook
Rep Power: 10 |
What type of divergence appears first?
If bounding message for turbulence parameters - in my experience, this implies grid problems - look at grid in area of high turbulence parameters. If you quickly get strange velocity vectors or alpha behavious at/near boundaries, then it is probably a BC issue. At outlet you have fixedFluxPressure for P and zeroGradient for U. Whilst this can be consistent for simple cases, there is also the potential for small inconsistencies (particularly -ve velocities) to feedback into strange behaviour. Especially when starting from a zero velocity condition with LTS. Try a fixed value for one of them (e.g. calculate U based on inflow/area at outlet for your initial water level and keep P as fixedFluxPressure; or use a free-outfall (P=0) or hydrostatic pressure condition and keep U as zeroGradient) - at least to get a stable solution and then you can adjust later.... Hope these thoughts help. If things blow up quickly it IS normally grid, BC, or initial conditions - changing solution schemes or parameters in my experience only delays divergence if there is an underlying issue with problem specification, so best to go back to less restrained tolerances and know more quickly if it is going to work or not! |
May 11, 2016, 21:30 |
Rep Power: 16 |
Hey Kate, thank you for your answer.
After fixing the pressure at the outlet, everything started to run smoothly. Now I converge in 10000-12000 timesteps using LTS with Co=10. So having few lowQualityTetFaces in your domain is not prohibiting convergence. My issues came from the BC's. Letting the pressure float at the outlet and only fixing pressure for atmosphere BC was not enough. |
May 25, 2016, 05:22 |
#4 | |
Principal Developer of cfMesh and CF-MESH+ www.cfmesh.com Social media: LinkedIn, Twitter, YouTube, Facebook, Pinterest, Instagram |
May 25, 2016, 05:59 |
#5 | |
Rep Power: 16 |
I really like using cfMesh, especially the ease of use compared to other OS meshers. It gives you good meshes in a much shorter time, both because of easy setup and quick run-times. |
May 7, 2019, 10:17 |
Error
walid
Rep Power: 7 |
Hello everyone,
I am running a simulation based on the tutorial "/tutorials/multiphase/interFoam/laminar/waveExampleStokesI". When I run simulation, I have a similar ERROR /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1812 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : v1812 OPENFOAM=1812 Arch : "LSB;label=32;scalar=64" Exec : interFoam -dry-run-write Date : May 07 2019 Time : 14:03:22 Host : default PID : 1007 I/O : uncollated Case : /home/ofuser/workingDir/OpenFoam/tests/case5 nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Operating in 'dry-run' mode: case will run for 1 time step. All checks assumed OK on a clean exit Selecting simplified mesh model staticFvMesh Creating simplified mesh using "/home/ofuser/workingDir/OpenFoam/tests/case5/constant/polyMesh" Mesh bounds: (0 0 0) (10 0.04 30) PIMPLE: Operating solver in PISO mode Reading field p_rgh Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Selecting laminar stress model Stokes Reading g Reading hRef Calculating field g.h No MRF models present No finite volume options present DICPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0, global = 0, cumulative = 0 Courant Number mean: 0 max: 0 Starting time loop Courant Number mean: 0 max: 0 Interface Courant Number mean: 0 max: 0 Time = 0.01 PIMPLE: iteration 1 Selecting waveModel StokesI #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in /lib64/libc.so.6 #3 Foam::waveModel::initialiseGeometry() at ??:? #4 Foam::waveModel::readDict(Foam::dictionary const&) at ??:? #5 Foam::waveModels::waveGenerationModel::readDict(Fo am::dictionary const&) at ??:? #6 Foam::waveModels::irregularWaveModel::readDict(Foa m::dictionary const&) at ??:? #7 Foam::waveModels::regularWaveModel::readDict(Foam: :dictionary const&) at ??:? #8 Foam::waveModels::StokesI::readDict(Foam::dictiona ry const&) at ??:? #9 Foam::waveModels::StokesI::StokesI(Foam::dictionar y const&, Foam::fvMesh const&, Foam:olyPatch const&, bool) at ??:? #10 Foam::waveModel::addpatchConstructorToTable<Foam:: waveModels::StokesI>::New(Foam::dictionary const&, Foam::fvMesh const&, Foam:olyPatch const&) at ??:? #11 Foam::waveModel::New(Foam::word const&, Foam::fvMesh const&, Foam:olyPatch const&) at ??:? #12 Foam::waveModel::lookupOrCreate(Foam:olyPatch const&, Foam::fvMesh const&, Foam::word const&) at ??:? #13 Foam::waveAlphaFvPatchScalarField::updateCoeffs() at ??:? #14 Foam::fvPatchField<double>::evaluate(Foam::UPstrea m::commsTypes) at ??:? #15 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary::evaluate() at ??:? #16 ? at interFoam.C:? #17 ? at ??:? #18 __libc_start_main in /lib64/libc.so.6 #19 ? at ??:? Floating point exception Can anyone help me with it please? |
Benchmarking interFOAM -- problems... | einatlev | OpenFOAM Running, Solving & CFD | 6 | March 19, 2015 10:16 |
interFoam simulation yields inconsistent results for alpha1 surface | Ralinus | OpenFOAM Running, Solving & CFD | 8 | January 13, 2014 08:54 |
Pressure convergence problems with sloped bottom in interFoam | gradylemoine | OpenFOAM Running, Solving & CFD | 0 | November 18, 2013 18:33 |
Problems with interFoam usage | vrecha | OpenFOAM Running, Solving & CFD | 4 | January 5, 2008 03:34 |
Problems starting new case interFoam | billy | OpenFOAM Running, Solving & CFD | 3 | June 21, 2006 10:18 |
