point flottant (core dumped)
Old   April 22, 2016, 09:55
Default point flottant (core dumped)
Mehdi
MehdiCFD is on a distinguished road
helo everyone i have the same probleme, i would like to simulate an airflow around an airfoil i used rhosimplefoam like a solver and when i'm compiling its apear this message:
| \\ / O peration | Version: 3.0.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 3.0.1-d8a290b55d28
Exec : rhoSimpleFoam
Date : Apr 19 2016
Time : 15:10:30
Host : "mehdi-HP-250-G4-Notebook-PC"
PID : 7408
Case : /home/mehdi/OpenFOAM/mehdi-3.0.1/run/airfoil/airfoil_rhoSimpleFoam
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
SIMPLE: convergence criteria
field p tolerance 0.01
field U tolerance 0.0001
field e tolerance 0.001
field "(k|epsilon|omega)" tolerance 0.001
Reading thermophysical properties
Selecting thermodynamics package
type hePsiThermo;
mixture pureMixture;
transport const;
thermo hConst;
equationOfState perfectGas;
specie specie;
energy sensibleEnthalpy;
Reading field U
Creating turbulence model
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
C3 -0.33;
sigmak 1;
sigmaEps 1.3;
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/home/mehdi/OpenFOAM/OpenFOAM-3.0.1/platforms/linuxGccDPInt32Opt/lib/libOpenFOAM.so"
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4 Foam:perator/(Foam::tmp<Foam::Field<double> > const&, Foam::tmp<Foam::Field<double> > const&) at ??:?
#5 Foam::fluidThermo::nu(int) const at ??:?
#6 Foam::TurbulenceModel<Foam::geometricOneField, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>, Foam::compressibleTurbulenceModel, Foam::fluidThermo>::nu(int) const at ??:?
#7 Foam::nutkWallFunctionFvPatchScalarField::calcNut( ) const at ??:?
#8 Foam::nutWallFunctionFvPatchScalarField::updateCoe ffs() at ??:?
#9 Foam::fvPatchField<double>::evaluate(Foam::UPstrea m::commsTypes) at ??:?
#10 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate() at ??:?
#11 Foam::RASModels::kEpsilon<Foam::EddyDiffusivity<Fo am::ThermalDiffusivity<Foam::CompressibleTurbulenc eModel<Foam::fluidThermo> > > >::correctNut() at ??:?
#12 Foam::RASModels::kEpsilon<Foam::EddyDiffusivity<Fo am::ThermalDiffusivity<Foam::CompressibleTurbulenc eModel<Foam::fluidThermo> > > >::kEpsilon(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&, Foam::word const&) at ??:?
#13 Foam::RASModel<Foam::EddyDiffusivity<Foam::Thermal Diffusivity<Foam::CompressibleTurbulenceModel<Foam ::fluidThermo> > > >::adddictionaryConstructorToTable<Foam::RASMode ls ::kEpsilon<Foam::EddyDiffusivity<Foam::ThermalDiff usivity<Foam::CompressibleTurbulenceModel<Foam::fl uidThermo> > > > >::New(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) at ??:?
#14 Foam::RASModel<Foam::EddyDiffusivity<Foam::Thermal Diffusivity<Foam::CompressibleTurbulenceModel<Foam ::fluidThermo> > > >::New(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) at ??:?
#15 ? at ??:?
#16 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
#17 ? at ??:?
Exception en point flottant (core dumped)
mehdi@mehdi-HP-250-G4-Notebook-PC:~/OpenFOAM/mehdi-3.0.1/run/airfoil/airfoil_rhoSimpleFoam$
if someone can help me please it's for my master project, thank you
MehdiCFD is offline   Reply With Quote
Old   April 22, 2016, 18:18
Mehdi
paradox is on a distinguished road
Dear Mehdi,
I guess your zero conditions 0/k or 0/epsilon are making floating point exception.
make sure internalField of these two files are not equal to zero.
Regards,
Mehdi
paradox is offline   Reply With Quote
Old   April 22, 2016, 20:03
Mehdi
thank u for replying, my k and epsilon aren't 0 I did everything, no results. I guess that this solver rhosimplefoam are not for external fluid or there's a mesh errors because I don't have a checkmesh command I have OF 3.0.1
solving a conduction problem in FLUENT using UDF Avin2407 Fluent UDF and Scheme Programming 1 March 13, 2015 02:02
ERROR : Floating point exception (core dumped) sam.ho OpenFOAM Running, Solving & CFD 4 November 14, 2013 06:03
Segmentation fault (core dumped) when changing pressure BC jptorol OpenFOAM Running, Solving & CFD 0 September 25, 2013 18:05
Floating point error (core dumped) sihaqqi OpenFOAM Post-Processing 1 April 17, 2013 06:57
Exception en point flottant thomasse OpenFOAM 3 August 9, 2011 00:50
