Solid displacement due to calculated velocity/pressure distribution
Old   July 5, 2016, 04:20
Default Solid displacement due to calculated velocity/pressure distribution
Amelie Rohlfs
AmRo is on a distinguished road
my intitial goal was to perform fsi for turbomachinery to check runner blade displacement. Due to an unexpected (as always) lack of time I am forced to simplify my problem a bit. What I want to do now:
Apply a simulated (with MRFSimpleFoam) flow distribution as load for a stress model. I am not very familiar with the OpenFoam stress solvers, so maybe somebody could give me a hint to some useful tutorial.
My geometry can be seen in the attached picture. The runner blade is the only solid part.
I am grateful for any advice!
Cheers, Amelie
AmRo is offline   Reply With Quote
Old   July 5, 2016, 09:49
Amelie Rohlfs
I've made some research and found solidEquilibriumDisplacementFoam and the tutorial beamEndLoad (I am using foam-extend-3.2)
Is it possible to apply the calculated pressure or velocity distribution from another case as the initial load to the solid runner blade?
dsmcFoam setup hherbol OpenFOAM Pre-Processing 1 November 19, 2021 01:52
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
Immersed solid, vs solid-fluid interaction to determine forces on a submerged solid amrbekhit CFX 0 January 8, 2015 16:39
dynamicMesh - move surface due to velocity/pressure Tobi OpenFOAM Running, Solving & CFD 5 November 1, 2014 14:18
Spanwise load distribution due to change in twist! mimi Main CFD Forum 1 June 6, 2007 10:57
