Having various problems simulating a multiphase channel flow |
July 24, 2016, 17:29 |
faride.bahrami
Rep Power: 10 |
Hi everyone :
When I try to run my case i get this error in terminal: Code:
--> FOAM FATAL IO ERROR: keyword PIMPLE is undefined in dictionary "/home/a/Desktop/Tfinal/system/fvSolution" file: /home/a/Desktop/Tfinal/system/fvSolution from line 81 to line 74. From function dictionary::subDict(const word& keyword) const in file db/dictionary/dictionary.C at line 648. Code:
solvers { alpha.water { nAlphaCorr 1; nAlphaSubCycles 2; cAlpha 1; } pcorr { solver PCG; preconditioner DIC; tolerance 1e-10; relTol 0; } p_rgh { solver PCG; preconditioner DIC; tolerance 1e-07; relTol 0.05; } p_rghFinal { $p_rgh; relTol 0; "pcorr.*" { $p_rghFinal; tolerance 0.0001; } "(U|k|epsilon)" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-8; relTol 0.1; } "(U|k|epsilon)Final" { $U; relTol 0; } } PIMPLE { momentumPredictor no; nCorrectors 3; nNonOrthogonalCorrectors 0; pRefPoint (0.51 0.51 .51); pRefValue 0; } Best regards! Faride. Last edited by wyldckat; September 11, 2016 at 08:01. Reason: Added [CODE][/CODE] markers |
July 25, 2016, 03:24 |
Amelie Rohlfs
Rep Power: 13 |
Hello Faride,
you should check your brackets, there might be missing something at p_rghFinal. Greetings, Amelie |
July 25, 2016, 06:56 |
faride.bahrami
Rep Power: 10 |
Thanks Amelie for your reply.ur right.I checked my fvsolution and I missed a " } " .
July 25, 2016, 15:54 |
OpenFOAM Running
faride.bahrami
Rep Power: 10 |
when i run case like weiroverflow with interDyMFoam in 2D, the follownig contents occured in the terminal,but when I use interfoam there is no problem.
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?#0 #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/opt/openfoam30/platforms/linuxGccDPInt32Opt/lib/libOpenFOAM.so" #3 ? at tensorField.C:? #4 ? at ??:? #5 ? at ??:? #6 ? at ??:? #7 ? at ??:? #8 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #9 ? at ??:? Floating point exception (core dumped) I attach my files .Any help is much appreciated. Thank you, Best Regards Faride Last edited by mf3; July 26, 2016 at 10:42. |
July 27, 2016, 06:00 |
Rep Power: 11 |
Hi mf3,
obviously it crashes in the p_rgh solving process. Not sure why. Mabe this helps? Are you sure about your relaxation factors? regards, teuk |
July 27, 2016, 13:06 |
faride.bahrami
Rep Power: 10 |
Hi Teuk,
Thank u for your reply. but I check my relaxationfactors and changed it like this: relaxationFactors { fields { p 0.3; } equations { "U.*" 0.7; "k.*" 0.7; "epsilon.*" 0.7; } } but it doesn't work .I don't know what should I do? Is that coz I use interDyMFoam for 2D case?Anyone know how can I change the codes for using inerDyMFoam in 2D? |
August 16, 2016, 17:41 |
OpenFOAM Running
faride.bahrami
Rep Power: 10 |
Hi Friends:
My case is quit easy,its a rectangular channel of dimension 6*.3*.4 (length ,height , width) that a profile located in the bottom of the channel with length 2.5 m.I should imposed a supercritical flow inlet and subcritical floe outlet.I mean i should have a constant flow depth y1= .053 m at the inlet and a constant flow depth y2=.158 m at the outlet.I used this B.C but when i run whit interFoam i get this error: Invalid wall function specification Patch type for patch inlet-2 must be wall Current patch type is genericPatch I attached my case .I dont know whats wrong, so any kind of help would be wonderfull! Thanks. blockMesh: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v3.0+ | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 0 0)//0 (6 0 0)//1 (6 .053 0) //2 (0 .053 0)//3 (0 0 .5)//4 (6 0 .5)//5 (6 .053 .5)//6 (0 .053 .5)//7 (0 .158 0)//8 (6 .158 0)//9 (6 .158 .5)//10 (0 .158 .5)//11 (0 .3 0)//12 (6 .3 0)//13 (6 .3 .5)//14 (0 .3 .5)//15 ); blocks ( hex (0 1 2 3 4 5 6 7) (400 4 1) simpleGrading (1 1 1) hex (3 2 9 8 7 6 10 11) (400 7 1) simpleGrading (1 1 1) hex (8 9 13 12 11 10 14 15) (400 10 1) simpleGrading (1 1 1) ); edges ( ); boundary ( outlet-1 { type patch; faces ( (1 2 6 5) (2 9 10 6) ); } outlet-2 { type wall; faces ( (9 13 14 10) ); } inlet-1 { type patch; faces ( (0 3 7 4) ); } inlet-2 { type * wall; faces ( (3 8 11 7) (8 12 15 11) ); } atmosphere { type patch; faces ( (12 15 14 13) ); } bottom { type wall; faces ( (0 4 5 1) ); } front { type patch; faces ( (5 6 7 4) (6 10 11 7) (10 14 15 11) ); } back { type patch; faces ( (1 2 3 0) (2 9 8 3) (9 13 12 8) ); } ); mergePatchPairs ( ); // ************************************************************************* // Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (0.0001 0 0); boundaryField { atmosphere { type zeroGradient; } inlet-1 // mghale1:f(y) mghale2:fixedValue { type fixedValue; value uniform (1.76 0 0); } inlet-2 { type fixedValue; value uniform (0 0 0); } outlet-1 //maghale1:f(y) maghale 2: zeroGradient { type zeroGradient; } outlet-2 { type fixedValue; value uniform (0 0 0); } front { type empty; } back { type empty; } profile { type fixedValue; value uniform (0 0 0); } bottom { type fixedValue; value uniform (0 0 0); } } Code:
dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0.0001; boundaryField { atmosphere { type fixedValue; value uniform 0; } inlet-1 { type zeroGradient; } inlet-2 { type zeroGradient; } outlet-1 //f(y) dota maghele { type fixedValue; value uniform 774.2; } outlet-2 { type zeroGradient; } front { type empty; } back { type empty; } bottom { type zeroGradient; } profile { type zeroGradient; } } Code:
dimensions [0 0 0 0 0 0 0]; internalField uniform 0.0001; boundaryField { atmosphere { type zeroGradient; } inlet-1 { type fixedValue; value uniform 1; } inlet-2 { type zeroGradient; } outlet-1 { type fixedValue; value uniform 1; } outlet-2 { type zeroGradient; } bottom { type zeroGradient; } front { type empty; } back { type empty; } bottom { type zeroGradient; } profile { type zeroGradient; } } // ************************************************************************* // Last edited by wyldckat; September 11, 2016 at 08:04. Reason: Added [CODE][/CODE] markers |
September 7, 2016, 04:43 |
openFoam runing
faride.bahrami
Rep Power: 10 |
Hi
I want to simulate the open-channel flow over a transition structure over that's located at the bottom of the channel. above this profile water level changes from sup to sub-critical flow without hydraulic jump.in my simulation the water level drops but in experimental result shouldn't drop.I dont know what B.C should use to simulate the correct result.in the picture in attache file I showed my result. Code:
FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (1.76 0 0); boundaryField { atmosphere { type pressureInletOutletVelocity; value uniform (0 0 0); } outlet-1 { type zeroGradient; } outlet-2 { type fixedValue; value uniform (0 0 0); } inlet-1 { type fixedValue; value uniform (1.76 0 0); } inlet-2 { type fixedValue; value uniform (0 0 0); } front { type empty; } back { type empty; } bottom { type fixedValue; value uniform (0 0 0); } profile { type fixedValue; value uniform (0 0 0); } } Code:
FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { atmosphere { type totalPressure; p0 uniform 0; } inlet-1 { type fixedFluxPressure; value uniform 0; } inlet-2 { type fixedFluxPressure; value uniform 0; } outlet-1 { type totalPressure; p0 uniform 0; // type fixedFluxPressure; //value uniform 0; } outlet-2 { type fixedFluxPressure; value uniform 0; } front { type empty; } back { type empty; } bottom { type fixedFluxPressure; value uniform 0; } profile { type fixedFluxPressure; value uniform 0; } } FoamFile { version 2.0; format ascii; class volScalarField; object alpha.water; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0.0001; boundaryField { atmosphere { // type zeroGradient; type inletOutlet; inletValue uniform 0; value uniform 0; } inlet-1 { type fixedValue; value uniform 1; } inlet-2 { type zeroGradient;//fixedValue; // value uniform 0; } outlet-1 { type zeroGradient; // type fixedValue; //value uniform 1; } outlet-2 { type zeroGradient; } bottom { type zeroGradient; } front { type empty; } back { type empty; } bottom { type zeroGradient; } profile { type zeroGradient; } } // ************************************************************************* // Code:
FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 0 0.1)//0 (4.5 0 0.1)//1 (4.5 .053 0.1) //2 (0 .053 0.1)//3 (0 0 .115)//4 (4.5 0 .115)//5 (4.5 .053 .115)//4.5 (0 .053 .115)//7 (0 .2 0.1)//8 (4.5 .2 0.1)//9 (4.5 .2 .115)//10 (0 .2 .115)//11 (0 .3 0.1)//12 (4.5 .3 0.1)//13 (4.5 .3 .115)//14 (0 .3 .115)//15 ); blocks ( hex (0 1 2 3 4 5 6 7) (400 4 1) simpleGrading (1 1 1) hex (3 2 9 8 7 6 10 11) (400 10 1) simpleGrading (1 1 1) hex (8 9 13 12 11 10 14 15) (400 7 1) simpleGrading (1 1 1) ); edges ( ); boundary ( outlet-1 { type patch; faces ( (1 2 6 5) (2 9 10 6) ); } outlet-2 { type wall; faces ( (9 13 14 10) ); } inlet-1 { type patch; faces ( (0 3 7 4) ); } inlet-2 { type wall; faces ( (3 8 11 7) (8 12 15 11) ); } atmosphere { type patch; faces ( (12 15 14 13) ); } bottom { type wall; faces ( (0 4 5 1) ); } front { type empty; faces ( (5 6 7 4) (6 10 11 7) (10 14 15 11) ); } back { type empty; faces ( (1 2 3 0) (2 9 8 3) (9 13 12 8) ); } ); mergePatchPairs ( ); // ************************************************************************* // Last edited by wyldckat; September 11, 2016 at 08:05. Reason: Added [CODE][/CODE] markers |
September 13, 2016, 15:46 |
#9 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: I received the PM you sent me. I don't have enough time to look into your case, so the best I can do is suggest that you study the course presentation and cases that are provided here: http://www.openfoamworkshop.org/courses - look for the presentation "Learning how to use free surface flows in OpenFOAM 3.0" and click on the download link to the right of the entry "Training Material".
November 8, 2016, 01:47 |
Problem modeling hydraulic jump in an open channel with interFoam (VoF)
#10 |
faride.bahrami
Rep Power: 10 |
Hi
i want to simulate a hydraulic jump in a rectangular channel .. U Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (1.01937 0 0); boundaryField { atmosphere { type pressureInletOutletVelocity; value uniform (0 0 0); } outlet-1 { type inletOutlet; inletValue uniform (0 0 0); } outlet-2 { type fixedValue; value uniform (0 0 0); } inlet-1 { type fixedValue; value uniform (1.355544 0 0); } inlet-2 { type fixedValue; value uniform (0 0 0); } front { type empty; } back { type empty; } bottom { type fixedValue; value uniform (0 0 0); } upWall { type fixedValue; value uniform (0 0 0); } profile { type fixedValue; value uniform (0 0 0); } } Code:
dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { atmosphere { type totalPressure; p0 uniform 0; } inlet-1 { type fixedFluxPressure; value uniform 0; } inlet-2 { type fixedFluxPressure; value uniform 0; } outlet-1 { type fixedFluxPressure; value uniform 0; } outlet-2 { type fixedFluxPressure; value uniform 0; } front { type empty; } back { type empty; } bottom { type fixedFluxPressure; value uniform 0; } upWall { type fixedFluxPressure; value uniform 0; } profile { type fixedFluxPressure; value uniform 0; } } Do you have any suggestion for obtaining the stationary hydraulic jump? Thanks in advance. -Faride Last edited by wyldckat; November 13, 2016 at 11:37. Reason: Added [CODE][/CODE] markers |
November 13, 2016, 11:42 |
#11 |
Bruno Santos
Rep Power: 128 |
Quick answer: Sorry, without images, it's not clear to me what you mean by "stationary hydraulic jump"
November 14, 2016, 05:49 |
#12 | |
faride.bahrami
Rep Power: 10 |
Dear mr.santos Thanks a lot for you consideration. My case is a rectangular channel of dimension 4.5*.3*.4 (length ,height , width) that a transition structure is located at the bottom of it with length 2.5 m.This transition was designed based on the energy principle and the singular point theory to gradually increase the flow depth,thereby eliminating the hydraulic jump. I should imposed a supercritical flow inlet and subcritical floe outlet.I mean i should have a constant flow depth y1= .053 m at the inlet and a constant flow depth y2=.158 m at the outlet. EXPERIMENT: A weak hydraulic jump is formed at the transition downstream end, which then moves upstream by increasing the tailwater. The hydraulic jump weakens during its move towards the crest of the structure. By further increase in the tailwater, once it reaches y2opt, the hydraulic jump for the upstream design Froude number is avoided completely and this is steady state. At this stage, the flow depth, which is close to the crest, is identical to the critical depth. In my simulation is formed a weak hydraulic jump and moves towards upstream .when it reaches at crest of the transition ,it becomes weak and we don't see hydraulic jump but this isn't steady state and after some seconds is formed a wave and moved towards inlet and level of the water is increased. I want to have a steady state like experiment. Also I like to know how can we impose y2(desired water depth at the outlet)? I use try and error ant it's time consuming . Thanks in advanced. |
November 14, 2016, 17:32 |
#13 |
Bruno Santos
Rep Power: 128 |
Quick answer: I've gotten a better sense of what you're trying to simulate, but it would help if you had a few pictures or movie or animation of the real life experiment.
I ask this because if I'm understanding things correctly, the problem you are having has to do with how the boundary conditions are affecting both the air phase and the water phase at the same time. Because of that, you also get air drag against the water surface, which is possibly helping to cause the instability. For example, take a look at the U file and you have this: Code:
internalField uniform (1.01937 0 0); My advice is that you start with an empty channel, filled with air that is stationary. Then inject water into the channel with a gradually increasing velocity. I believe the tutorial "incompressible/pimpleFoam/TJunction" has the example for a single phase simulation, but you should be able easily adapt this to the multiphase simulation. The reason why starting from an empty tank is important is so that you can at least see how the air phase is disturbed when you start injecting fluid. By the way, I also suggest that since this a type of simulation that takes a long time to run, first run a pseudo-2D case like the "damBreak" from the User Guide, to see what to expect. As for imposing the water height at the exit... use the "fixedValue" boundary condition at the outlet and then use setFields to enforce the value on that outlet. See here: https://github.com/OpenFOAM/OpenFOAM...FieldsDict#L38 |
November 15, 2016, 06:57 |
#14 | |
faride.bahrami
Rep Power: 10 |
Thanks a lot for your reply. when I forced the outlet water depth imposing a given value of alpha,my simulations crashed.I know I have to impose an outlet velocity or (hydrostatic)pressure that cause the desired water depth to accrue.but I dont know which boundary conditions for U or p should I use? I use inletOutlet for U and FixedFluxepressure for p-rgh at the outlet. In attached file you can see the movies of real life experiment. let me explain how to do my simulation i divided the outlet in 2 segment: outlet--1 patch y1 outlet-2 wall y2 and I do my simulation in 3 step: step-1: y1=.1 y2=.2 with this setting I have supercritical flow all over the channel.like picture1. step-2: when I want ( for example close the gate )I set outlet like this: y1=.053 y2=.247 and use mapfields from step-1. In this step is formed a weak hydraulic jump and moves to upstream. step -3:when hydraulic jump is formed after some second before the wave reaches to transition I changes the outlet B.C like this: y1=.15 y2=.15 and use mapfeilds frome step-2 I have to use try and error to get the desired water depth at outlet.But in experiment by setting the gate we can get desired water depth at outlet. Please let me know whether this method is correct or not? For the high capacity of movies and animations,it's not impossible to uplode them.I try to show them in images that are attached. In step-3 with try and error I get good result in some seconds but after that is formed a wave again and moves towards upstream.I don't want to have this wave . Thanks a lot. |
Calculating mass flow rate at multiphase flows | Kuslo187 | OpenFOAM Post-Processing | 1 | August 21, 2015 18:11 |
Gravitational water flow in closed channel. | Szymon85 | CFX | 7 | September 3, 2013 16:28 |
Periodic channel flow with time dependent mass flow rate | QBeast | FLUENT | 3 | May 10, 2013 13:14 |
Multiphase flow problems | Shane Gillis | FLUENT | 2 | August 10, 2000 01:06 |
compressible channel flow.. | R.D.Prabhu | Main CFD Forum | 0 | July 17, 1998 17:23 |
