July 26, 2016, 19:10 |
Simulation Stopped half way
#1 | |
Zhifang Hu
Rep Power: 10 |
Hi there I was doing a simulation, but it stopped at 0.6s
and Here is the error message. Quote:
Can I conclude that the simulation get dumped because the max Courant Number is bigger than 1? |
July 27, 2016, 06:41 |
Rep Power: 11 |
July 28, 2016, 08:58 |
Yes the max Courant number
eu sou cfd
Rep Power: 13 |
I am not really experienced with multiphase simulations on OpneFOAM, but I hear from experts that the maxCo should be under 0.5 or sometimes even under 0.1.
July 28, 2016, 09:21 |
Bruno
Rep Power: 9 |
I think <1 should be fine, so that it passes through each cell. The OF tutorials on heatTransfer do have maxCo set to 0.6 or 0.7.
July 28, 2016, 20:37 |
#5 | ||
Zhifang Hu
Rep Power: 10 |
July 29, 2016, 02:45 |
Bruno
Rep Power: 9 |
What exactly are you trying to solve? You could try a different solver for p in stead of GAMG, such as PCG.
July 29, 2016, 11:03 |
#7 | ||
Rep Power: 11 |
Hi ce73stargazer,
Can't tell you why... Quote:
regards, teuk |
July 31, 2016, 19:07 |
#8 | ||
Zhifang Hu
Rep Power: 10 |
Thanks for the reply, I do believe its the mesh's problem. Thats why what i did initially is changing the dx size to make the Courant number small, however, that doesnot work either. here is the output of the checkMesh Quote:
July 31, 2016, 19:47 |
#9 |
Rep Power: 11 |
Hi ce73stargazer,
Your chekMesh is looking really nice to me besides your aspect ratio. But I think this is not the problem here. You should try to write your solution for the last time steps when it crashes beginning from moderate courant-number to blow up. If you investigate your fields over time in some postprocessing-software (f.e paraview) you should be able to find the cell(s) which causes the trouble. There sould be one or a few cells where your p- or U-fields show an unexpected behaviour. regards, teuk |
restarting paused transient simulation using reactingFoam | JMDag2004 | OpenFOAM Running, Solving & CFD | 1 | August 10, 2015 10:15 |
Convergence of jet flow simulation | MiraLisa | FLUENT | 0 | August 15, 2013 04:44 |
continue LES simulation after it stopped | holand_us | OpenFOAM | 9 | April 5, 2010 12:52 |
continue LES simulation after it stopped | holand_us | OpenFOAM Running, Solving & CFD | 1 | March 29, 2010 03:50 |
3d half model airplane simulation | Loh | FLUENT | 2 | January 17, 2006 22:36 |
