August 24, 2016, 06:05 |
How to add and select solver in Helyx
Alex_Han
Rep Power: 9 |
Dear Foamers:
I am now using Helyx to conduct OpenFoam tutorials. I wonder how to add or modify the solver in the Helyx. Because even the application in controlDict is modified, it will not reflect in the GUI of Helyx. Moreover, after I performed one tutorial through Helyx, I checked the controlDict file. There is no application command. Does anyone explain this for me? Thank you in advance! Best, Alex |
April 18, 2017, 14:46 |
Joshua
Rep Power: 9 |
han0459,
HELYX-OS only allows users to use a small group of solvers inside the GUI. If you want to use other solvers or setting form OpenFOAM, one must do these outside the GUI. You can still use HELYX-OS to create your geometry and mesh, but all of your boundary conditions and setting must then be done by hand via the text files. Joshua |
New solver for two-phase flows with phase-change heat transfer | liquidspoon | OpenFOAM Programming & Development | 41 | July 1, 2022 11:11 |
How to select some variables not to be written into files? | ripperjack | OpenFOAM Programming & Development | 12 | August 7, 2020 11:15 |
CFX SOLVER parallel error | Manol | CFX | 10 | July 5, 2016 11:43 |
Cfd to ansys thermal to ansys structural interface | ssixr | ANSYS | 17 | July 31, 2015 15:18 |
[snappyHexMesh] Add additional boundary layers to complex stl surface | tobijingles | OpenFOAM Meshing & Mesh Conversion | 1 | October 26, 2011 10:45 |
