mapFields error
Old   September 27, 2016, 13:22
Default mapFields error
Francesco
phemt84 is on a distinguished road
Hi guys,
i'm trying to map a mesh from a mesh made using the Adaptive mesh refinement, to a mesh with uniform cell to export and analyse into matlab.
The two domains have the same patch, so i've tried to use this command:
star@NEW153:/mnt/g/OF/test_mapField$ mapFields /mnt/g/OF/interDyMFoam_32um_turb_60 -consistent -sourceTime 5e-6
but i have this output:
HTML Code:
|  \\    /   O peration     | Version:  v1606+                                |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
Build  : v1606+
Exec   : mapFields /mnt/g/OF/interDyMFoam_32um_turb_60 -consistent -sourceTime 5e-6
Date   : Sep 27 2016
Time   : 19:16:56
Host   : "NEW153"
PID    : 222
Case   : /mnt/g/OF/test_mapField
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Source: "/mnt/g/OF" "interDyMFoam_32um_turb_60"
Target: "/mnt/g/OF" "test_mapField"
Create databases as time
Source time: 5e-06
Target time: 0
Create meshes
Source mesh size: 463182        Target mesh size: 3932095
Consistently creating and mapping fields for time 5e-06
    interpolating nut
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigSegv::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  ? at ??:?
#4  ? at ??:?
#5  ? at ??:?
#6  ? at ??:?
#7  ? at ??:?
#8  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#9  ? at ??:?
Errore di segmentazione (core dump creato)
Can anyone help me??
Thx
Francesco
phemt84 is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
