October 20, 2016, 15:33 |
potentialFoam error
gereksiz
Rep Power: 11 |
I have been trying to initialize the flow field by using potentialFoam, however, I can't do it because of the following error. Before this I tried to do it a couple of times and I received the same error but I didn't push much. Anyways I've searched a bit, but I couldn't find anything about it.
I'm using Openfoam 2.4.0 and my distro is ubuntu 14.04. This is the error, and I attached controlDict, fvSolution, fvSchemes and fvOptions. Any help appreciated. Code:
Create time Create mesh for time = 0 Reading velocity field U Constructing pressure field p Constructing velocity potential field Phi Creating finite volume options from "system/fvOptions" Calculating potential flow --> FOAM FATAL ERROR: object of type N4Foam9DataEntryIdEE is not allocated From function Foam::autoPtr<T>::operator->() in file /home/taygun/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude/autoPtrI.H at line 176. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
