Axisymmetric Thermal Jet using buoyantBoussinesqPimpleFoam |
November 1, 2016, 12:45 |
Dear Foamers,
I am trying to simulate an axisymmetric thermal jet and for that I am using buoyantBoussinesqPimpleFoam solver. I am having trouble with the boundary conditions. I kept the temperature difference between inlet flow and surroundings as 20K so as to satisfy the Boussinesq condition. What solver is suggested if I were to use a larger temperature difference. The case is running fine for few time steps and suddenly I am getting 'nan' values. Timestep is adjustable and max Co number is set to '0.5'. ddt scheme is 'CrankNicolson 1.0'; and 'Gauss linear' for div schemes In post-processing I saw that my velocity has reached the sides when 'nan' starts coming. Ay help is highly appreciated. My case set-up is as follows: 1) I have 4 parts, Inlet,Walls,Outlet-Patch type and Base is of wall type. Generated msh file using ICEM and has around 1 million cells. 2) I am using k-e model as of now 3) My inlet velocity is around 1m/s and details from 0/ directory: Code:
p_rgh file: internalField uniform 0; boundaryField { INLET { type fixedFluxPressure; rho rhok; value uniform 0; } OUTLET { type zeroGradient; } WALLS { //type fixedFluxPressure; //rho rhok; //value uniform 0; type totalPressure; p0 uniform 0; gamma 1.4; value uniform 0; } BASE { type fixedFluxPressure; rho rhok; value uniform 0; } } p file: internalField uniform 0; boundaryField { INLET { type calculated; value $internalField; } OUTLET { type calculated; value $internalField; } WALLS { type calculated; value $internalField; } BASE { type calculated; value $internalField; } } U file: internalField uniform (0 0 0); boundaryField { INLET { type fixedValue; value uniform (0 0.98 0); } OUTLET { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); } WALLS { //type inletOutlet; //inletValue uniform (0 0 0); type pressureInletOutletVelocity; value uniform (0 0 0); } BASE { type fixedValue; value uniform (0 0 0); } } T file: internalField uniform 300; boundaryField { INLET { type fixedValue; value uniform 320; } OUTLET { type inletOutlet; value uniform 300; inletValue uniform 0; } WALLS { type inletOutlet; value uniform 300; inletValue uniform 0; } BASE { type zeroGradient; } } -Sudheer |
April 21, 2021, 07:11 |
Similiar problem
Rep Power: 5 |
Hi! I'm trying to solve a similar problem. Could you finally solve your boundary conditions' problem?
Simulation of Axisymmetric jet flow in openfoam | gunvirs | OpenFOAM | 0 | July 4, 2016 04:08 |
Virtual Origin. Axisymmetric Jet | Christine | Main CFD Forum | 0 | July 20, 2005 17:22 |
Virtual Origin. Axisymmetric Jet | Christine | Main CFD Forum | 0 | July 20, 2005 17:20 |
Axisymmetric Jet | Abdul Basit | FLUENT | 3 | April 7, 2005 12:32 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
