-   OpenFOAM Running, Solving & CFD (https://www.cfd-online.com/Forums/openfoam-solving/)
-   -   LES solver with variable density for incompressible liquids (https://www.cfd-online.com/Forums/openfoam-solving/57768-les-solver-variable-density-incompressible-liquids.html)
matthias March 15, 2009 07:36
Hi, I'm looking for a LES s
I'm looking for a LES solver which is able to calculate density fluctuations in liquid-liquid mixtures. The densitiy fluctuations are caused due to chemical reactions of the liquids and/or mixing of the liquids. Typically, you can make the assumption of constant density in liquids (especially in water) but that applies not to all chemical reactions and mixtures.
Until now, I did only calculations with constant density using the oodles solver and simple chemical models depending on the mixture fraction.
So, which solver is the best choice ? (After reacting/mixing there is still one incompressible liquid, no multiphase flow). My favourite solver would be coodles!
Best regards.
Matthias
gaby April 26, 2010 05:46
Hi Matthias,
Did you find out something for solving density fluctuations in liquids??
I’m very interested. I also think that coodles would be a good approach …
Please let us know if you were able to solve it
Regards…
Gaby
