Example of use of the solidParticlesolidParticleCloud classes |
June 14, 2007, 20:23 |
Hello, is there any example of
Alberto Passalacqua
Rep Power: 36 |
Hello, is there any example of how to use the solidParticle/solidParticleCloud classes of OpenFOAM 1.4?
Regards, Alberto
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
February 27, 2008, 10:18 |
Hi Alberto
I am also trying
Andreas Mehrle
Hi Alberto
I am also trying to include the solidParticle/solidParticleCloud classes in OpenFOAM 1.4.1 with moderate success. Whenever I call solidParticleCloud's constructor I receive a compile error "undefinded reference". Did you procceed any further? br Andreas |
October 4, 2008, 07:42 |
Any news on how to use
Håkan Nilsson
Rep Power: 18 |
Any news on how to use the solidParticle class? I made a grep on the entire OpenFOAM-1.5 installation, and it seems like there is no example. There seems to be some problem since a copy of icoFoam will not compile if I simply add a link to the solidParticle and lagrangian classes in Make/options: EXE_LIBS = \ -lfiniteVolume \ -llagrangian \ -lsolidParticle No other modifications are made to icoFoam! The error message is: /home/hani/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libsolidParticle.so: undefined reference to `Foam::Cloud<foam::solidparticle>::typeName' The same error occurs also without the -llagrangian, and with other combinations of added libraries, so the problem seems to be related to -lsolidParticle. I tried re-compiling the solidParticle class, which went through nicely, but the problem is still there. Any idea? Håkan. |
October 4, 2008, 13:00 |
Make sure you use 1.5.x, 1.5 i
Mattijs Janssens
Rep Power: 26 |
Make sure you use 1.5.x, 1.5 is missing a few bits.
1) #include "solidParticleCloud.H" 2) In the main create a cloud solidParticleCloud particles(mesh); and the gravity g. (readEnvironmentalProperties.H) 3) Somewhere in your time loop do a particles.move(g); |
October 7, 2008, 05:20 |
Thanks a lot Mattijs!
I hav
Håkan Nilsson
Rep Power: 18 |
I have added a code and case at the following location for anyone who would like to test the solidParticleCloud class: http://openfoamwiki.net/index.php/Contrib_solidParticleFoam Håkan |
October 7, 2008, 10:15 |
Splendid!
/Niklas
Niklas Wikstrom
Splendid!
/Niklas |
October 14, 2008, 14:13 |
Hi All,
The wikipage explains
Sachin Kanetkar
Hi All,
The wikipage explains that solver is only for demo purpose, can anyone help me out how to use it for real world simulation. Shall i try and compare this one with deiselEngineFoam...am i correct ? if not is there any other way ? Sachin |
October 14, 2008, 16:26 |
Hi Sachin,
The purpose of t
Håkan Nilsson
Rep Power: 18 |
Hi Sachin,
The purpose of that case was just to set up something for people to start with, so that you know what is needed to have something running. If you have a look at it you will see that it does not solve for any fluid motion, so if your 'real world' simulation has a need for that you must include it. I did not check every detail of the solidParticleCloud class yet, but at least I know that the particles do not interact and there is only one-way coupling. Again, if your 'real world' simulation requires this you must include it. For some 'real world' simulations the case set-up and its assumptions might be alright, the question is how you define your 'real world'. We always do assumptions of different kinds. My advice: Use anything any way you like, but remember that you are responsible for the conclusions you draw from those results yourself. In other words - make sure what the code does, and validate it as much as you can before you draw any important conclusions. dieselEngineFoam is of course much more developed, but it is also much more complicated. Also, it is not an example of the solidParticleCloud class, which was the purpose of the present test case. Good luck! Håkan |
October 17, 2008, 10:54 |
Thanks Håkan,
I now want to k
Sachin Kanetkar
Thanks Håkan,
I now want to know what is e and mu in solidParticleCloud class...I am not even able to guess these values .... sachin |
October 17, 2008, 11:11 |
Hi Sachin,
Check the follow
Håkan Nilsson
Rep Power: 18 |
Hi Sachin,
Check the following ang get back with a detailed explanation: OpenFOAM-1.5.x/src/lagrangian/solidParticle/solidParticle.C For instance: void Foam::solidParticle::hitWallPatch ( const wallPolyPatch& wpp, solidParticle::trackData& td ) { vector nw = wpp.faceAreas()[wpp.whichFace(face())]; nw /= mag(nw); scalar Un = U_ & nw; vector Ut = U_ - Un*nw; if (Un > 0) { U_ -= (1.0 + td.spc().e())*Un*nw; } U_ -= td.spc().mu()*Ut; } Have a nice weekend! Håkan. |
October 17, 2008, 18:00 |
Hi Håkan,
Infact i should hav
#11 |
Sachin Kanetkar
Hi Håkan,
Infact i should have mentioned in previous post...i was thinking whether it is related to elasticity factor and reflection...is it correct ? i m trying to model dusty jet flow and i m not really sure which approach should i follow 1-As taken in this example 2-or the one taken in the sample code of icoLagrangianFoam (available on wikipages) If 2 one is better somebody please explain me these lines (from IncompressibleCloud.c) vector tmp=(random.vector01()-vector(0.5,0.5,0.5))*2; vector pos=center+tmp*r0; tmp=vector(random.GaussNormal(),random.GaussNormal (),random.GaussNormal())/sqrt( 3.); vector vel=tmp*vel0+vel1; scalar d=fabs(random.GaussNormal())*d1+d0; label cellI=mesh_.findCell(pos); ...Are particle diameter,position,velocity generated randomly ....in that case..i think approach 1 would be nice as my particle would be injected from inlet boundary (i.e. position would be predefined) Also is there any papers over implementation of lagrangian libraries in OpenFOAM...just to give some idea about it sachin |
October 23, 2008, 14:12 |
Håkan,
Thanks for that wiki
#12 |
Scott Ripplinger
Håkan,
Thanks for that wiki page! I'm hoping that it provides a good starting point for my thesis simulations. I plan on integrating some surface forces (van der waals, and double layer) into the solver to simulate a colloidal suspension. I will also be adding two-way coupling and inter-particle collisions. Perhaps I'll post a new solver with just these as an intermediate step. |
November 15, 2008, 17:44 |
I just added a new exam
#13 |
Håkan Nilsson
Rep Power: 18 |
I just added a new example in the Wiki, where I modify the interFoam solver and the damBreak tutorial so that the solidParticles are included in that case. You have a step-by-step description at: http://openfoamwiki.net/index.php/Contrib_solidParticleFoam#solidParticleDamBrea k By coincidence the splash hits one of the particles so that it hits the wall. The other particle falls to the surface, decelerates in the heavy fluid due to buoyancy, and follows the fluid motion. Have a nice evening! Håkan. |
March 13, 2009, 08:27 |
I have just checked in some up
#14 |
Hrvoje Jasak
Rep Power: 33 |
I have just checked in some updates - my fault (out of sync).
Please update and try again - works now. Hrv P.S. Impressive work, Hakan!
March 13, 2009, 09:36 |
Hrv, Thanks. That fixed it.
#15 |
Hrv, Thanks. That fixed it. I'm putting a bunch of the community developments off the Wiki into a openSuse + OpenFOAM-1.5-dev virtual machine for a training class, and a few were broken.
March 28, 2009, 04:51 |
still undefined reference problem
#16 |
Hi Håkan,
I have followed the following step: 1. git clone git://repo.or.cz/OpenFOAM-1.5.x.git, so that I can get OF 1.5.x; 2. svn checkout http://openfoam-extend.svn.sourcefor...dParticleFoam/ 3. cd solidParticleFoam/solidParticleFoam 4. wmake 5. However, I get the same error as in OpenFOAM 1.5 when I compile icoLagrantiamFoam solver: Make/linuxGccDPOpt/solidParticleFoam.o: In function `Foam::Cloud<Foam::solidParticle>::type() const': solidParticleFoam.C.text._ZNK4Foam5CloudINS_13so lidParticleEE4typeEv[Foam::Cloud<Foam::solidParticle>::type() const]+0x11): undefined reference to `Foam::Cloud<Foam::solidParticle>::typeName' collect2: ld returned 1 exit status make: *** [/home/zhou/OpenFOAM/zhou-1.5/applications/bin/linuxGccDPOpt/solidParticleFoam] Error 1 Would you please test it? Thank you for attention. Bin |
March 30, 2009, 14:04 |
#17 |
Håkan Nilsson
Rep Power: 18 |
I don't see in your steps that you compiled 1.5.x. Did you?
Håkan. |
March 30, 2009, 14:12 |
#18 |
Hi, Håkan,
You are right, just now I have found this stupid problem. I add OpenFOAM 1.5.x/etc/barshrc in $HOME/.bashrc & first, then use ./Allwmake under the directory: OpenFOAM/OpenFOAM-1.5.x to compile it. It is running now. Thank you for your reply. Bin |
March 31, 2009, 17:17 |
#19 |
Hi, Håkan,
Update my condition: I can use solidParticleFoam as you suggested in wiki. It is impressive. Thank you. Bin |
April 20, 2009, 11:33 |
#20 |
Hi, Håkan and other Foamers,
After I get my flow field(steady-state), I use this flow field to move my particles. It works fine here. Now I want to generate particles continuously at each time step as well as move the previous generated particles. Do you have any suggestions for this? I am thinking about this now. Best regards, Bin |
Finite Area Classes and Surface related Utilities | philippose | OpenFOAM | 10 | December 9, 2011 12:42 |
Understanding tmp%2360T classes | nadine | OpenFOAM Running, Solving & CFD | 14 | January 22, 2009 10:25 |
Adding functionality to classes | sergio | OpenFOAM | 9 | March 13, 2008 06:18 |
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 | Amitava Majumdar | Main CFD Forum | 0 | January 5, 1999 13:00 |
