Hi, I'm using rhoTurbFoam to s
Hi, I'm using rhoTurbFoam to solve for supersonic flow. The solver works fine for mach number 1.0, but i get the error message that the max number of iterations is reached verytime i do something more than mach 1.0. I've attached the error message below.
--> FOAM FATAL ERROR : Maximum number of iterations exceeded#0 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) in "/home/jiaming/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/jiaming/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::hThermo<foam::puremixture<foam::consttranspo rt<foam::speciethermo<foam::hc onstthermo<foam::perfectgas> > > > >::calculate() in "/home/jiaming/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libbasicThermophysica lModels.so" #3 Foam::hThermo<foam::puremixture<foam::consttranspo rt<foam::speciethermo<foam::hc onstthermo<foam::perfectgas> > > > >::correct() in "/home/jiaming/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libbasicThermophysica lModels.so" #4 main in "/home/jiaming/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/rhoTurbF oam" #5 __libc_start_main in "/lib64/libc.so.6" #6 Foam::regIOobject::readIfModified() in "/home/jiaming/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/rhoTurbF oam" From function specieThermo<thermo>::T(scalar f, scalar T0, scalar (specieThermo<thermo>::*F)(const scalar) const, scalar (specieThermo<thermo>::*dFdT)(const scalar) const) const in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.4.1/src/thermophysicalModels/specie/lnInclud e/specieThermoI.H at line 83. FOAM aborting Cheers Jia |
Hia Jia,
do you found the tri
Hia Jia,
do you found the trick? I faced this error in dieselFoam, regards, Hamed |
I am also getting this
I am also getting this message when running rhoCentralFoam. My case has both subsonic and supersonic flow and seems to work fine but then always crashes with this error after a while. Does any one know what it means? Thanks Kieran |
Same Err
Hi..friends.
I am solving one case using rhoTurbFoam but after few iteration it stops with the same error report as mentioned above. I am not getting why this Err means. What I understood is there may be sudden Temp raise found this is causing Err. I am not sure. I tried to verify BCs and discretization schemes also but got no idea about Err cause. Pls..come forward and help to understand it. Thanks Mehulkumar |
shantha
1 Attachment(s)
hello friends,
i am facing some issues after 2 iter, please find attached log file Maximum number of iteration exceeded#0 Foam ::error::printStack(Foam::Ostream&) error. please help me any body, i found error after 2 iterations |
hi..jia_kok
Did you fix that issue? if it how did you do it? i am facing same problem, please help me on the same |
MOst probably your BC are wrong.
Look at rho ! Its too high ! That is leading to problem with time step continuity... recheck your BC and how do you initialize your domain? |
