Operator declaration in Thermophysical library
Old   March 12, 2009, 09:47
Default Hi, I'm just implementing r
Lena
lena is on a distinguished road
I'm just implementing real gas thermodynamics into the reactingFoam solver and I have some problems with the operator declaration in janafThermoI.H and janafThermo.H.
Up to now I made the following modifications:
I changed the standard Chemkin format of therm.inp to make it able to read the critical properties in addition to the standard values form the prescribed file.
Form those data I calculated two coefficients needed to get a 'real' density. One of those coefficients is temperature dependent, therefore I gave the memberfunction cellMixture in multiComponentMixture.C the temperature as an additional parameter and gernerated a new operator, which should calculate this second coefficient form the temperature. Unfortunately I didn't succeed in running this properly.
What I did is to copy the operator* like it is implemented in the standard version
template<class>
inline janafThermo<equationofstate> operator*
const scalar s,
const janafThermo<equationofstate>& jt
return janafThermo<equationofstate>
s*static_cast<const>(jt),
jt.Tlow_,
jt.Thigh_,
jt.Tcommon_,
jt.Tc_,
jt.pc_,
jt.omega_,
jt.bPR_,
jt.a0PR_,
jt.kappaPR_,
jt.highCpCoeffs_,
jt.lowCpCoeffs_
and defined an operator% which lookes a very similar. I added this operator in everyfile, where the operator* is also mentioned.
template<class>
inline janafThermo<equationofstate> operator%
const scalar T,
jt.Tlow_,
jt.Thigh_,
jt.Tcommon_,
jt.Tc_,
jt.pc_,
jt.omega_,
jt.bPR_,
jt.a0PR_*T,
jt.kappaPR_,
jt.highCpCoeffs_,
jt.lowCpCoeffs_
Compiling of the specie library is no problem, and I also can call this new operator in multicomponent mixture by, for example
mixture_ = T%speciesData[0];
without getting an error, but it doesn't do anything!!!
Is it possible that it is simply not allowed to redefine the % operator??? Is there any operator I could use instead?
Thanks a lot in advance!!!
Best regards,
Lena
lena is offline   Reply With Quote
How to use thermophysical data lasb OpenFOAM Running, Solving & CFD 1 September 23, 2010 09:36
Problem with the thermophysical ivanyao OpenFOAM Running, Solving & CFD 1 July 14, 2009 09:45
Thermophysical properties in a cylinder guilherme OpenFOAM Running, Solving & CFD 1 December 3, 2006 08:37
Boundary declaration Tadiwos CFX 4 August 22, 2001 09:12
thermophysical properties of ham Alex Ivancic Main CFD Forum 1 November 5, 1998 11:09
