-   -   Temporary deallocated error (http://www.cfd-online.com/Forums/openfoam-solving/57822-temporary-deallocated-error.html)
waynezw0618 March 10, 2009 11:35
hi everyone: i modify the tur
hi everyone:
i modify the turboFoam to add coriolis force and centrifugal force according to MRFsimpleFoam. and when i run the code it gives errors like:
temporary deallocated
From function T& tmp<t>::operator()()
in file /home/waynezw0618/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/tmpI.H at line 164.
FOAM aborting
what is the problem? how can i resolve it?
--------------------code-------------------------
#include "fvCFD.H"
#include "incompressible/singlePhaseTransportModel/singlePhaseTransportModel.H"
#include "incompressible/RASModel/RASModel.H"
#include "MRFZones.H"
#include "IFstream.H"
#include "OFstream.H"
int main(int argc, char *argv[])
# include "setRootCase.H"
# include "createTime.H"
# include "createMesh.H"
# include "createFields.H"
//# include "createAverages.H"
# include "initContinuityErrs.H"
Info<< "\nStarting time loop\n" << endl;
for (runTime++; !runTime.end(); runTime++)
Info<< "Time = " << runTime.timeName() << nl << endl;
# include "readPISOControls.H"
#include "readTimeControls.H"
#include "CourantNo.H"
#include "setDeltaT.H"
// Pressure-velocity PISO corrector
// Momentum predictor
tmp<fvvectormatrix> UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
+ turbulence->divDevReff(U)
mrfZones.addCoriolis(UEqn());
UEqn().relax();
solve(UEqn == -fvc::grad(p));
// --- PISO loop
for (int corr=0; corr<nCorr; corr++)
volScalarField rAU = 1.0/UEqn().A();
U = rAU*UEqn().H();
phi = (fvc::interpolate(U) & mesh.Sf())
+ fvc::ddtPhiCorr(rAU, U, phi);
mrfZones.relativeFlux(phi);
adjustPhi(phi, U, p);
// Non-orthogonal pressure corrector loop
for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
// Pressure corrector
fvScalarMatrix pEqn
fvm::laplacian(rAU, p) == fvc::div(phi)
pEqn.setReference(pRefCell, pRefValue);
pEqn.solve();
if (nonOrth == nNonOrthCorr)
phi -= pEqn.flux();
# include "continuityErrs.H"
U -= rAU*fvc::grad(p);
U.correctBoundaryConditions();
turbulence->correct();
//# include "calculateAverages.H"
runTime.write();
//# include "writeNaveragingSteps.H"
Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
<< " ClockTime = " << runTime.elapsedClockTime() << " s"
<< nl << endl;
Info<< "End\n" << endl;
return(0);
wayne
rob3rt July 31, 2010 04:05
Dear Wayne,
I am having a similar "temporary deallocated" problem like you had but only I'm using different solver.
How did you resolve that problem?
Kind Regards,
Robert.
dima June 6, 2011 04:58
hallo foamers, i am new to openfoam
got advanced knowlage in C, basic knowlage in C++ and basic knowlage in fluiddynamics
current i am modifying the rhoPisoaFoam (transient) solver, by implementing a porousZone like in rhoPorousSimpleFoam (steadystate)
source code is modified, mesh is modified(porouseZone in pitzDaily), porousZones file is included
partially it works, but with the following setting an error occurs
nUCorrectors 2; => sets pressureImplicitPorosity = true;
i located the error to the "+ fvc::ddtPhiCorr(trAU, rho, U, phi)" part of
phi =
fvc::interpolate(rho)
what is wrong, how could i resolve this error?
i thought about to do something like
if (pressureImplicitPorosity)
phi =
else
phi =
but is it correct in refer to the phi equation? its just a (transient) Corrector term, isn't it?
error message:
Create time
Create mesh for time = 0
Reading thermophysical properties
Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
Reading field rho
Reading field U
Creating turbulence model
Selecting turbulence model type RASModel
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
C3 -0.33;
sigmak 1;
sigmaEps 1.3;
Prt 1;
Creating field DpDt
Creating porous zone: porosity
Courant Number mean: 0 max: 0.126355
Starting time loop
Time = 1e-05
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for h, Initial residual = 0.55759, Final residual = 7.51342e-05, No Iterations 1
--> FOAM FATAL ERROR:
From function const T& tmp<T>::operator()() const
in file /home/dima/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude/tmpI.H at line 187.
FOAM aborting
#0 Foam::error::printStack(Foam::Ostream&) in "/home/dima/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/dima/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >::operator()() const in "/home/dima/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/rhoPorousPisoFoam"
#4 __libc_start_main in "/lib64/libc.so.6"
at /usr/src/packages/BUILD/glibc-2.11.2/csu/../sysdeps/x86_64/elf/start.S:116
i'm sorry for my not very good english :o , hope you could understand what i mean
i would be thankful for any kind of reply
with kind regards
Dima
rob3rt 0ng June 16, 2011 12:46
Hi Dima,
I think you should decrease both nOuterCorrectors and nCorrectors in system/fvSolution to 1.
Regards,
Robert
dima June 17, 2011 05:09
Hi Robert,
thank you for reply
i try the settings you suggested, but same error occurs
meanwhile i was advised of the rhoPorousMRFPimpleFoam (transient)
and there the above processes term is
set off in OF-1.7.1
    phi =
        fvc::interpolate(rho)*
        //+ fvc::ddtPhiCorr(rUA, rho, U, phi)
and set on in OF-2.0.0
    phi =
          + fvc::ddtPhiCorr(rAU, rho, U, phi)
so i will take a look to the new version
regards, Dima
TDidi January 12, 2012 12:06
I had the same problem with the error message: "temporary deallocated" after creating a new turbulent solver.
The problem was missing parenthesis after UEqn for the fvVectorMatrix. So I changed "UEqn" to "UEqn()". Hope it challenges your problem, too.
Friederike April 29, 2014 09:24
Thank you so much, Taieb! You saved me a lot of searching and trouble :D
