Dear All,
I am trying to si
Dear All,
I am trying to simulate blood flow(Newtonian) in the vessel tree(1 inlet, two outlets),the mesh is composed of 300,000 element(generated with Netgen). Due to the pulsatility of flow and a large diameter in one section of vessel, the reynolds number ranges from 800-2800. As it is already in the range of transitional flow, I would like to compare the results with icoFoam and turbFoam. I use timeVaringMappedFixedValue for inlet velocity, internal field is uniform 0 at time 0. With icoFoam, the simulation runs ok(so far so good). But with turbFoam, the courant number shooting up after a few time steps, I tried to decrease the time step to 1e-9, it takes longer time to run but still crash.Also ,I tried with different non-orthogonal correction (from 0-5), but it does not help either. Some output shows below: Time = 5e-08 Courant Number mean: 3.4715513e-06 max: 0.60734157 DILUPBiCG: Solving for Ux, Initial residual = 0.85196695, Final residual = 3.1267205e-06, No Iterations 17 DILUPBiCG: Solving for Uy, Initial residual = 0.96440528, Final residual = 2.7772291e-06, No Iterations 17 DILUPBiCG: Solving for Uz, Initial residual = 0.79241281, Final residual = 7.3940699e-06, No Iterations 18 DICPCG: Solving for p, Initial residual = 0.95210563, Final residual = 1.7064169e-06, No Iterations 1001 DICPCG: Solving for p, Initial residual = 1.6748541e-05, Final residual = 8.4640768e-07, No Iterations 8 DICPCG: Solving for p, Initial residual = 0.00071908555, Final residual = 9.3169688e-07, No Iterations 891 DICPCG: Solving for p, Initial residual = 0.0012949352, Final residual = 9.1814394e-07, No Iterations 882 DICPCG: Solving for p, Initial residual = 0.0020266284, Final residual = 9.9997889e-07, No Iterations 77 DICPCG: Solving for p, Initial residual = 0.00088922452, Final residual = 9.6729688e-07, No Iterations 34 DICPCG: Solving for p, Initial residual = 0.00046604245, Final residual = 9.6719301e-07, No Iterations 44 DICPCG: Solving for p, Initial residual = 0.00017580701, Final residual = 9.8750237e-07, No Iterations 17 time step continuity errors : sum local = 0.0017074431, global = -1.3930901e-05, cumulative = -1.3930901e-05 DICPCG: Solving for p, Initial residual = 0.00031818805, Final residual = 9.7682202e-07, No Iterations 39 DICPCG: Solving for p, Initial residual = 0.0020054737, Final residual = 9.8841476e-07, No Iterations 834 DICPCG: Solving for p, Initial residual = 0.0015531438, Final residual = 9.8870886e-07, No Iterations 132 DICPCG: Solving for p, Initial residual = 0.00099694405, Final residual = 9.9800042e-07, No Iterations 98 DICPCG: Solving for p, Initial residual = 0.00036951027, Final residual = 9.9217062e-07, No Iterations 25 DICPCG: Solving for p, Initial residual = 0.00015456831, Final residual = 9.7291974e-07, No Iterations 33 DICPCG: Solving for p, Initial residual = 9.8850384e-05, Final residual = 9.7703745e-07, No Iterations 21 DICPCG: Solving for p, Initial residual = 3.7944695e-05, Final residual = 9.8717719e-07, No Iterations 13 time step continuity errors : sum local = 0.0020294417, global = 0.00050316706, cumulative = 0.00048923616 DICPCG: Solving for p, Initial residual = 0.00044148951, Final residual = 9.9891514e-07, No Iterations 35 DICPCG: Solving for p, Initial residual = 0.00058423109, Final residual = 9.8994051e-07, No Iterations 77 DICPCG: Solving for p, Initial residual = 0.0011570549, Final residual = 9.9388321e-07, No Iterations 48 DICPCG: Solving for p, Initial residual = 0.00059720437, Final residual = 9.5799576e-07, No Iterations 49 DICPCG: Solving for p, Initial residual = 0.00031756011, Final residual = 9.7824997e-07, No Iterations 28 DICPCG: Solving for p, Initial residual = 0.00013516959, Final residual = 9.7732753e-07, No Iterations 27 DICPCG: Solving for p, Initial residual = 5.7604893e-05, Final residual = 9.54122e-07, No Iterations 9 DICPCG: Solving for p, Initial residual = 1.9040262e-05, Final residual = 9.85252e-07, No Iterations 5 time step continuity errors : sum local = 0.0019502308, global = 0.00035723113, cumulative = 0.00084646729 DICPCG: Solving for p, Initial residual = 0.00025788581, Final residual = 9.5539493e-07, No Iterations 48 DICPCG: Solving for p, Initial residual = 0.00040909549, Final residual = 9.4801664e-07, No Iterations 50 DICPCG: Solving for p, Initial residual = 0.00062587092, Final residual = 9.7425662e-07, No Iterations 54 DICPCG: Solving for p, Initial residual = 0.00029854348, Final residual = 9.8320313e-07, No Iterations 23 DICPCG: Solving for p, Initial residual = 0.00018829853, Final residual = 9.4855736e-07, No Iterations 26 DICPCG: Solving for p, Initial residual = 8.5377075e-05, Final residual = 9.6900945e-07, No Iterations 15 DICPCG: Solving for p, Initial residual = 3.7474851e-05, Final residual = 9.3843777e-07, No Iterations 11 DICPCG: Solving for p, Initial residual = 1.4316395e-05, Final residual = 8.5426812e-07, No Iterations 7 time step continuity errors : sum local = 0.001607798, global = 0.00039511268, cumulative = 0.00124158 DILUPBiCG: Solving for epsilon, Initial residual = 0.143052, Final residual = 0.035359121, No Iterations 1001 bounding epsilon, min: -6.7958532e+22 max: 9.5183686e+22 average: 1.9702049e+17 DILUPBiCG: Solving for k, Initial residual = 0.99554838, Final residual = 0.89722782, No Iterations 1001 bounding k, min: -3.9062716e+20 max: 4.361143e+20 average: -1.1420505e+14 DILUPBiCG: Solving for T, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for T, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for T, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for T, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for T, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for T, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for T, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for T, Initial residual = 0, Final residual = 0, No Iterations 0 ExecutionTime = 540.23 s ClockTime = 4978 s Time = 5.5e-08 Courant Number mean: 5.8934015 max: 2100091.5 [3] #0 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [3] #1 Foam::sigFpe::sigFpeHandler(int)[2] #0 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [2] #1 Foam::sigFpe::sigFpeHandler(int)[0] #0 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [0] #1 Foam::sigFpe::sigFpeHandler(int)[1] #0 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [1] #1 Foam::sigFpe::sigFpeHandler(int) in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [1] #2 [4] #0 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [4] #1 Foam::sigFpe::sigFpeHandler(int) in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [4] #2 [5] #0 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [5] #1 Foam::sigFpe::sigFpeHandler(int) in "/vol/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [5] #2 __restore_rt at sigaction.c:0 As I am new to turbulent flow, may I know how to estimate the initial value for k and epsilon? Following the User Manual, I set the internal field for k is 0.00225 and for epsilon is 0.004. I am not sure if I estimate reasonablly, the geometry is about 8cm and average diameter is about 6mm, inlet flow velocity changes from 0.2m/s to 0.8m/s. Could some body give me help? Thanks in advance!! vivien |
Hi vivien,
You could try u
Hi vivien,
You could try using simpleFoam to see if the problem is with your k and epsilon initiation. I don't think there is problem with these initiations. You needn't go that low with dt. You could alternatively try oodles, which is a LES solver. You could set a constant inlet and try simpleFoam. These are few things you could do to guess what the issue might be. http://www.cfd-online.com/OpenFOAM_D...part/happy.gif Prapanj |
One more suggestion: Check if
One more suggestion: Check if you are consistent with your dimensions. Check if you use the dimensions of velocity consistent with your convertToMeter value.
Viven,
The choice of linear
Viven,
The choice of linear/limitedLinear/upwind for the k and epsilon interpolation within the fvSchemes file plays a vital role here. Try playing with these. Also I would set dt to a really small number and use adaptive time stepping to gradually ramp the courant number up to a control target (typically 1) once the fields have stabilised. Greg. |
Hi Vivien,
I wouldn't expec
Hi Vivien,
I wouldn't expect that k-epsilon model is adequate for your case, considering you are in laminar/transitional regime. If you are able to use icoFoam without your Courant number exploding, you are ok. If you really need to use turbulence models, look for low-Re turbulence models, such as V2F (you'll find it here in the Message Board). In that case, your mesh should have an adequate resolution at the walls (y+<1). Regards, Jose Santos |
Hi Vivien
If you in your co
Hi Vivien
If you in your controlDict write something like this: writeControl adjustableRunTime; writeInterval 0.05; Then the solver will adapt the time steps, to write with an interval of 0.05 seconds. Best regards, Niels |
Hi Niels,
Thanks a lot.
Hi Niels,
Thanks a lot. i previously use timestep(1e-8), writeInterval 20. when I change to use adjustableRunTime, I did not change writeInterval, but I get my first result at time instance 0.00025614707, second result at 0.00035482559, seems still write result after 20 time steps... Vivien |
