Pressure divergence with interTrackFoam
Old   March 2, 2009, 08:11
Default Hello, I am using interTra
Virginie Ehrlacher
virginie_e is on a distinguished road
I am using interTrackFoam to simulate the flow of a fluid which first slides along a slope and then falls freely in a basin. The simulation runs fine until a while. The pressure of the fluid at the point where the slope stops and the fluid falls freely begins to diverge. Could someone give me some advice about how I could fix this problem?
I am using laplaceFaceDecomposition solver for the mesh motion and I did not change the coefficients for the solving of U and p from the hydrofoil tutorial.
If you need some more information, just tell me.
Thank you a lot in advance
Virginie
virginie_e is offline   Reply With Quote
Old   March 2, 2009, 14:04
Default Could you post a few pictures?
Sandeep Menon
deepsterblue will become famous soon enough
Could you post a few pictures? Preferably wire-frame images.
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   March 3, 2009, 03:46
Default Hello Sandeep, Here are a
Virginie Ehrlacher
Hello Sandeep,
Here are a few pictures. There are the pressure plot, the velocity plot and a zoom on the part where the pressure diverges.
The inlet is the upper left corner, the outlet is the lower right corner. The fluid flows down the "spout" then falls freely over a bath of liquid tin. I simulated the tin with a boundary pressure condition over the free surface.
As you can see the pressure diverges right at the point where the fluid leaves the slope and falls freely. And there does not seem to be any mesh problems… They only come after a while. I wonder if I choose a wrong pressure solver… Could you please give me some advice about it? Thanks a lot.
Virginie
Old   March 3, 2009, 04:39
Default Here is my case directory if y
Virginie Ehrlacher
Here is my case directory if you want to have a look.
Here is what I do:
fluentMeshToFoam tinpressure.mah
makeFaMesh
interTrackFoam
Thank you for your help!
Virginie
Old   March 3, 2009, 04:49
Default Oups, sorry I did not atta
Virginie Ehrlacher
Oups,
sorry I did not attach the files correctly
tinpressurecopy.zip
tinpressure.msh.gz
Old   March 3, 2009, 04:58
Default Sorry I also forgot my library
Virginie Ehrlacher
Sorry I also forgot my library for the pressure condition on the free surface (p=0 above the tin level, otherwise p = rho*g*z basically)
linearTinPressurePerso.zip
Old   March 3, 2009, 14:53
Default I only see an entry for SIMPLE
Sandeep Menon
I only see an entry for SIMPLE in fvSolution - is this a steady-state type of simulation? You might want to have a time step restriction using the Courant number too. For bad meshes, you might want to increase the number of nonOrthogonal correctors.
Also, the mesh looks like it was obtained from a previous calculation. Surface tension might behave erratically if the surface normals are ill-behaved.
Sandeep Menon
Old   March 4, 2009, 03:20
Default Thank you Sandeep for your qui
Virginie Ehrlacher
Thank you Sandeep for your quick answer.
I have alreday tried to increase the number of nonOrthogonal correctors but I had the same divergence.
I will try though the time step restriction using the Courant number. That is a good idea.
Yes it is indeed a steady-state type of simulation. Is there a kind of option which I should set? If yes, what kind of option?
Anyway, thanks for your help.
Old   March 4, 2009, 05:07
Default Hello, I have tried to set
Virginie Ehrlacher
I have tried to set a time step restriction using the Courant number and to increase teh number of nonOrthogonal correctors (30) but I still get the same kind of error. Have you got some other ideas about what I should do?
Otherwise, do you know where I could find some documentation about all the available options that are implemented for SIMPLE? I have tried to search for it but I could not find anything.
Thank you for your time.
InterTrackFoam any information rajon OpenFOAM Running, Solving & CFD 30 January 1, 2016 16:27
Wall contact in interTrackFoam virginie_e OpenFOAM Running, Solving & CFD 2 November 8, 2011 11:52
SIMPLE loop in interTrackFoam virginie_e OpenFOAM Running, Solving & CFD 3 March 17, 2009 05:40
Divergence of trailing edge pressure? Bren Main CFD Forum 3 December 6, 2007 17:57
InterTrackFoam error kester OpenFOAM Running, Solving & CFD 10 November 8, 2007 02:55
