Home > Forums > OpenFOAM Running, Solving & CFD
Setting up multispecies buoyant simulation
Old   February 5, 2009, 10:05
Default Hi, Although experienced in
OliH
olih is on a distinguished road
Although experienced in CFD, I'm a newbie to OpenFOAM so this is probably a set of very simple questions for someone to answer.
Basically I'm trying to set up a multispecies, buoyant case (i.e. where the gas composition within each cell affects the density - not simply a passive scalar). It's steady, so I've started off with buoyantSimpleFoam but I'm not sure on the best way to edit this for multispecies simulations.
My main difficulty is not the implementation of the transport equations, but how to set up a multispecies simulation and how to get the correct thermodynamic behaviour.
Ideally in my 0 directory I want to have files with the names of the species (O2, N2 etc.)
Many thanks in advance for your help.
Oli
olih is offline   Reply With Quote
Old   February 5, 2009, 11:56
Default Hi Oli! The closes matches
Assistant Moderator
Bernhard Gschaider
Hi Oli!
The closes matches to what you want are probably reactingFoam (turn the reactions off if you don't need them) or twoLiquidMixingFoam (if you only got two species, am not sure whether it does temperature)
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   February 5, 2009, 12:24
Default Yes that was my other option -
OliH
Yes that was my other option - start with reactingFoam and strip it down, rather than buoyantFoam and building it up.
I take it that reactingFoam has the correct handling of buoyancy that i'm looking for, i.e. density a function of both temperature and composition?
Oli
Old   February 5, 2009, 13:27
Default Hi Oli! It has (correct den
Assistant Moderator
Bernhard Gschaider
Hi Oli!
It has (correct density), but I'm not sure whether it has gravitation
Bernhard
Old   February 6, 2009, 16:38
Default Not having much luck I'm afrai
OliH
Not having much luck I'm afraid.
I think I could make progress if I was confident of two things:
1) the correct thermophysical model
2) how to specify the species using speciesTable or similar.
Can anyone help me out on that?
Thanks,
Oli
Old   February 9, 2009, 13:50
Default Hi, Your case is like a reac
M. Mahdi Salehi
smehdi609 is on a distinguished road
Your case is like a reacting mixture without any chemical reaction. So, the easiest way is to use reactingFoam and delet the chemical source terms. For thermodynamic model, you can still use hcombustionThermo with a chemkin file. However, just write your speices in chem.in file.
smehdi609 is offline   Reply With Quote
Old   March 3, 2009, 05:15
Default Hi, I'm also beginner here.
Azura Ali
abigail is on a distinguished road
I'm also beginner here...i'm trying a simple natural convection case with the buoyantSimpleFoam and have few Questions ...
1. in the tutorials, air is being used as model. how can i make use of the other liquids that stated under src/thermophysicalModels/liquids ?
2. for RAS-turbulenceModel what should i do in order to use the SST-Model instead of k-e-Model
can someone plz help me?thanks...
abigail is offline   Reply With Quote
Thread Tools
Trackbacks are On
2-phase multispecies flow modeling rookie FLUENT 1 November 1, 2011 16:54
Setting up a simulation for a compression corner Serene FLUENT 0 November 6, 2007 11:49
multispecies mixing Sam CD-adapco 0 February 8, 2006 08:16
Multiphase multispecies problem zhou FLUENT 0 July 25, 2005 13:11
buoyant jet Qi Yuan FLUENT 0 February 13, 2001 07:49
