August 23, 2007, 15:47 |
I am interested in i
Vinay Ramohalli Gopala
I am interested in implementing Mass and Heat transfer across the interface using VOF (interFoam solver), which requires an accurate description of the interfacial area in each cell. Can someone suggest a way to calculate the interfacial area using the present interFoam VOF implementation? Thanks in advance, |
August 24, 2007, 05:58 |
Hi Vinay
Check out this li
Rep Power: 18 |
Hi Vinay
Check out this link in the forum http://www.cfd-online.com/OpenFOAM_D...ges/1/172.html Regards Jaswinder |
February 26, 2009, 07:34 |
The links seems to be dead.
C
Fabian Roesler
Rep Power: 18 |
Can anybody post the correct link of the discussion? Thanks allot in advance. Regards Fabian |
February 17, 2010, 10:32 |
interface area
Roman Thiele
Rep Power: 20 |
Did you ever find a solution to the problem of calculating the interface area within the cell?
~roman |
July 31, 2010, 08:25 |
never found one
Roman Thiele
Rep Power: 20 |
Hej,
I tried finding a solution, but I in the end created a model to simulate and predict the size of the interface area. I assumed that the size of the cell is regular. Then calculated the area that is double diagonal within the a regular cell (in this case a cube then) and varied the size of the interface area with the amount of alpha1 within the cell, max at 0.5 alpha1 and full size of the double diagonal area. Of course this can be made better. Additional information that can be used within such a model can be the velocity, the angle at which the interface is within the cell and the irregularity of the cell.
~roman |
July 31, 2010, 10:50 |
mathematical method
Roman Thiele
Rep Power: 20 |
assume a regular cell. in the case of a hexahedral cell this means, a cube with sides of length a. This length is obtainable by using the volume of a cell,V , and taking the third root.
You can put a plane diagonally through the cube. The size of this plane is given by Amax =√(3) * V^(2/3) When the cell is now filled with phase 1, you can read the alpha1 value. The maximum area, Amax, is now varied based on the alpha1 value. with A = Amax*2 * alpha1; 0 ≤ α < 0.5 A = Amax*2(1-alpha1); 0.5 ≤ α ≤ 1 The code that I used for this is Code:
Foam::tmp<Foam::volScalarField> Foam::phaseChangeTwoPhaseMixtures::AlbaNovaInterface::interfaceArea() const { // return the interfacial area based on model for interfacial area // returns dimensions Area // model based on regular volume cells, taking the largest cut area // as maximum for area, linear increase and decrease with alpha const volScalarField& cellVolume = alpha1_.db().lookupObject<volScalarField>("cellVolu"); volScalarField limitedAlpha1 = min(max(alpha1_, scalar(0)), scalar(1)); const dimensionedScalar areaFactor("areaFactor",dimensionSet(0,2,0,0,0,0,0), 0.0); volScalarField interfaceArea = alpha1_ * areaFactor; volScalarField maxArea = alpha1_ * areaFactor; maxArea = sqrt(3.0)*pow(cellVolume,(2.0/3.0)); return tmp<volScalarField> ( (neg(limitedAlpha1-0.5)*maxArea*2.0*limitedAlpha1) + (pos(limitedAlpha1-0.5)*maxArea*(-2.0*( limitedAlpha1 - 1.0))) ); }
~roman Last edited by romant; July 31, 2010 at 16:36. Reason: missing factor in calculation for the area |
August 1, 2010, 05:29 |
create an accessible volume field
Roman Thiele
Rep Power: 20 |
Hej,
I created a volume field in createFields.H Code:
// create access for cell volumes during runtime // needed by AlbaNovaInterface volScalarField cellVolu ( IOobject ( "cellVolu", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), mesh, dimensionedScalar("zero", dimVolume, 0.0) ); cellVolu.internalField() = mesh.V();
~roman |
October 30, 2014, 03:43 |
Length of the interface
#11 |
Vignesh
Dear All,
I know this thread is old but, I would like to know how to calculate the length of the interface in interfoam ?
Thanks and Regards Vignesh |
October 30, 2014, 03:47 |
#12 |
Roman Thiele
Rep Power: 20 |
One way if determining the interface size has been described in the previous posts. A length would not be a real size for a cells, as a cell 3D and you need an area.
~roman |
October 30, 2014, 10:08 |
#13 |
Vignesh
Thank you !! Now i get it
June 8, 2015, 08:13 |
#14 |
HI Foamers,
I am trying to implement Roman's code but I have following error: PHP Code:
June 8, 2015, 10:18 |
#15 |
Roman Thiele
Rep Power: 20 |
I think to understand how the code is implemented, you need to take a look at how the other models for cavitationFoam are implemented. Different models could be chosen in version 1.7 for which this model was created. I am not sure what it looks like today (as of version 2.3 or 2.4).
The models that I implemented were not hard coded into the solver but where as all the other models selectable.
~roman |
September 1, 2015, 10:47 |
Calculating interface area of a jet
#16 |
HM
Rep Power: 11 |
Hi Foamers,
I am running some simulations on a jet impacting a quiescent pool with interFoam. I was wondering if there is any way that we can calculate the interfacial area of a jet at the impact location. Thanks in advance. |
September 1, 2015, 15:36 |
#17 | ||
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
September 1, 2015, 17:43 |
#18 |
HM
Rep Power: 11 |
Bruno thanks for the reply, but I am only interested in the interface area of the jet at the impinging location. The method described will calculate the interface area all over the pool and the bubbles beneath the surface, which I am not interested.
Thanks |
September 12, 2015, 15:38 |
#19 | |
Bruno Santos
Rep Power: 128 |
Greetings Hojjat,
Problem is that you want to calculate the impact area between two fluids of the same ... er, wait, is it a jet of a fluid different from the quiescent fluid in the pool? In other words: without a clear picture/image of what you're trying to calculate, I don't know if it's even possible at all. At best, I can imagine it would be possible to calculate the area in a cross section of the domain that is operating at a certain flow speed for a specific phase. Best regards, Bruno
Last edited by wyldckat; September 12, 2015 at 15:39. Reason: added more details to the initial description |
November 22, 2021, 06:10 |
#20 |
hari charan
Rep Power: 4 |
Hi Roman,
can I know where the code is added? I mean to which floder you added the code? Thanks and regards. |
[OpenFOAM] How to plot time vs distance traveled by the interface interFoam | asaha | ParaView | 9 | January 26, 2011 08:05 |
InterFoam freeSurface area calculation with sampleSurface | jaswi | OpenFOAM Post-Processing | 9 | December 10, 2009 11:07 |
How to calculate liquid volume as the interface moves for interFoam Solver | asaha | OpenFOAM Running, Solving & CFD | 25 | October 21, 2009 04:34 |
Problems calculating field gh with interFoam | cricke | OpenFOAM Running, Solving & CFD | 0 | December 10, 2007 07:17 |
How to access interface area in vof model??? | Asghari | FLUENT | 0 | April 16, 2007 08:12 |
