I would like to perform s
I would like to perform simulations of multiphase combustion (something similar to diesel spray), using Eulerian approch to describe the condensed phase (fuel droplets). Where should I start? Thanks Antonio |
Hey Antonio!
I am also interested in the using LES approach instead of the RANS one to simulate the diesel spray. But it is very sad that I am not sure about how to solve "Y" because I don't know the equation when I choose LES. I used the method as below to solve the Y, but I am not sure about it. Would you like to help me to make sure the method? solve ( fvm::ddt(rho, Yi) + mvConvection->fvmDiv(phi, Yi) - fvm::laplacian(turbulence->muEff(), Yi) == dieselSpray.evaporationSource(i), // + kappa*chemistry.RR(i), mesh.solver("Yi") ); In fact, There is no combustion in my case, so I didn't care about the chemistry and I delete "kappa*chemistry.RR(i)".If I care about the Chemistry, how do treat the term of "kappa*chemistry.RR(i)", which is generated in the RAS? Thanks and best regards |
