Torque in a sliding interface mesh
Old   February 11, 2009, 08:53
Default Hi foamers i would like to
antonio segalini
antonio_ing is on a distinguished road
Hi foamers
i would like to measure the torque in a certain patch which belongs to a rotating region. I simulate a turbulent flow (with a standard kepsilon model) around some rotating airfoils with a sliding interface method. How can i measure the torque?
thanks is advance
antonio_ing is offline   Reply With Quote
Old   February 12, 2009, 10:58
Default I have seen a thread that gave
Maruthamuthu Venkatraman
maruthamuthu_venkatraman is on a distinguished road
I have seen a thread that gave a small routine you can add it on Control file. It write both Force and moments , you should specify the moment centre.
Today i am outof office, If u feel difficult in searching the thread then i will post it on monday.
maruthamuthu_venkatraman is offline   Reply With Quote
Old   February 12, 2009, 11:09
Default I guess this is that thread!
maddalena's Avatar
maddalena
maddalena will become famous soon enough
maddalena is offline   Reply With Quote
Old   February 23, 2009, 04:19
antonio segalini
Hi foamers
thanks is advance
Old   February 23, 2009, 04:33
Default Hello Antonio, HAve a look
Hello Antonio,
HAve a look at it. Write them at the end of control file . Your forces and moments will be written in seperate folder. Remember to specify the axis of rotation of your rotor.
Hope this is what your are asking for ... Alsom set the patch name as you specified in the boundary files... for eg: Wall.
Good luck
functions // this one!
forces
type forces;
functionObjectLibs ("libforces.so"); //Lib to load
patches (building); // change to your patch name
rhoInf 1.225; //Reference density for fluid
CofR (0 0 0); //Origin for moment calculations
forceCoeffs
type forceCoeffs;
patches (building); //change to your patch name
rhoInf 1.225;
CofR (0 0 0);
liftDir (0 1 0);
dragDir (1 0 0);
pitchAxis (0 0 0);
magUInf 11.2;
lRef 45;
Aref 45;
Old   February 23, 2009, 04:36
Default thx i was unsure if this co
antonio segalini
thx
i was unsure if this code will work on rotating patches. I'll tell you soon... :-)
Old   February 23, 2009, 05:13
Default actually there is something st
antonio segalini
actually there is something strange since the torque is lower than expected and, also, this is a 2d geometry so the only non zero torque component should be Mz but in this case all the three torque components are comparable.
Old   February 23, 2009, 05:25
Default Just to make sure check the co
Just to make sure check the coordinates for the rotation axis. I used the above code for simple fixed cylinders and gave me reliable coeffcients. I hope it will work in the dev version also.
you can plot the coeffcients cd and cl over time and check for periodicity. Check your contours aswell. If all are correct then the above code need some more functional input for torque...
This is just a suggestion.
Old   February 23, 2009, 05:58
Default looking at the forces, the cen
antonio segalini
looking at the forces, the centre of rotation is correct (0 0 0) and i can obtain the same result with the forceCoeffs. but the problem remains... :-(
Mesh motion with sliding interface problem sebastian_neumann OpenFOAM Running, Solving & CFD 0 December 16, 2008 10:26
sliding mesh interface question Kyle FLUENT 0 February 26, 2008 10:36
Location of interface for sliding mesh Gopal FLUENT 1 July 14, 2005 05:30
error in defining periodic sliding mesh interface Flyeden FLUENT 1 November 11, 2003 23:33
Sliding Mesh Interface Error Greg Watkins FLUENT 3 April 17, 2001 11:44
