i have decided to open a new t
i have decided to open a new thread. To my openfoam-1.5 dev of 20/01/09 i did wclean in the icoFoam directory and once i did wmake again I got the following error:
+ wmake Making dependency list for source file icoFoam.C SOURCE=icoFoam.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/icoFoam.o In file included from /home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/Time.H:47, from /home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/finiteVolume/lnInclude/fvCFD.H:6 , from icoFoam.C:33: /home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/cpuTime.H:4:3 3: error: asm-generic/cputime.h: No such file or directory In file included from /home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/finiteVolume/lnInclude/fvCFD.H:6 , from icoFoam.C:33: /home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/Time.H:68: error: expected class-name before ',' token icoFoam.C: In function 'int main(int, char**)': icoFoam.C:103: error: 'class Foam::Time' has no member named 'elapsedCpuTime' make: *** [Make/linuxGccDPOpt/icoFoam.o] Error 1 any suggestion? |
What is the output of these 3
What is the output of these 3 commands?
> which g++ > g++ --version > cd $WM_PROJECT_DIR; svn info And what Linux distro are you using? Martin |
1)
/usr/bin/g++
2)
g++ (U
1)
/usr/bin/g++ 2) g++ (Ubuntu 4.3.2-1ubuntu12) 4.3.2 Copyright (C) 2008 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. 3) The program 'svn' is currently not installed. You can install it by typing: sudo apt-get install subversion -bash: svn: command not found actually i am using ubuntu 8.10 |
i finally managed to solve the
i finally managed to solve the problem compiling again openfoam-dev from scratch. In the installation section there is my post about the openfoam-1.5-dev installation to everybody. Thanks for all the help guys
Hi everybody,
I added H2 Fo
Hi everybody,
I added H2 Folder/Class to the existing liquid library of openFoam-1.5 . I tried to compile as http://openfoamwiki.net/index.php/Co...ropertiesLiqui d, but many errors, saying, .. /user/lib/../lib64/crt1.o: in function `_start`: (.text+0x20): undefined reference to `main' Make/linux64GccDpOpt/H2O.o: In function `Foam::thermophysicalFunction::type() const': H2O.Chttp://www.cfd-online.com/OpenFOAM_D...lipart/sad.gif.text._ZNK4Foam22thermophysicalFunction4typeEv[Foam::thermophysicalFunction::typ e() const]+0x3) : undefined reference to `Foam::thermophysicalFunction::typeName' Make/linux64GccDpOpt/H2O.o: In function `Foam::NSRDSfunc0::type() const': H2O.Chttp://www.cfd-online.com/OpenFOAM_D...lipart/sad.gif.text._ZNK4Foam10NSRDSFunction04typeEv[Foam::NSRDSfunc0::type() const]+0x3): undefined reference to 'Foam::NSRDSfunc0::typeName' Make/linux64GccDpOpt/H2O.o: In function `Foam::NSRDSfunc1::type() const': H2O.Chttp://www.cfd-online.com/OpenFOAM_D...lipart/sad.gif.text._ZNK4Foam22NSRDSfunction14typeEv[Foam::NSRDSfunc1::type() const]+0x3): undefined reference to 'Foam::NSRDSfunc1::typeName' Make/linux64GccDpOpt/H2O.o: In function `Foam::NSRDSfunc2::type() const': H2O.Chttp://www.cfd-online.com/OpenFOAM_D...lipart/sad.gif.text._ZNK4Foam22thermophysicalFunction4typeEv[Foam::NSRDSfunc2::type() const]+0x3): undefined reference to 'Foam::NSRDSfunc2::typeName' Make/linux64GccDpOpt/H2O.o: In function `Foam::NSRDSfunc4::type() const': H2O.Chttp://www.cfd-online.com/OpenFOAM_D...lipart/sad.gif.text._ZNK4Foam22thermophysicalFunction4typeEv[Foam::NSRDSfunc4::type() const]+0x3): undefined reference to 'Foam::NSRDSfunc4::typeName' Make/linux64GccDpOpt/H2O.o: In function `Foam::NSRDSfunc5::type() const': H2O.Chttp://www.cfd-online.com/OpenFOAM_D...lipart/sad.gif.text._ZNK4Foam22thermophysicalFunction4typeEv[Foam::NSRDSfunc5::type() const]+0x3): undefined reference to 'Foam::NSRDSfunc5::typeName' Make/linux64GccDpOpt/H2O.o: In function `Foam::NSRDSfunc6::type() const': H2O.Chttp://www.cfd-online.com/OpenFOAM_D...lipart/sad.gif.text._ZNK4Foam22thermophysicalFunction4typeEv[Foam::NSRDSfunc6::type() const]+0x3): undefined reference to 'Foam::NSRDSfunc6::typeName' Make/linux64GccDpOpt/H2O.o: In function `Foam::NSRDSfunc7::type() const': H2O.Chttp://www.cfd-online.com/OpenFOAM_D...lipart/sad.gif.text._ZNK4Foam22thermophysicalFunction4typeEv[Foam::NSRDSfunc7::type() const]+0x3): undefined reference to 'Foam::NSRDSfunc7::typeName' .. Any suggestion? Hamed |
Hi everybody,
I added H2 Fo
Hi everybody,
