-   -   Adding imaginary patch for calculation of average values (http://www.cfd-online.com/Forums/openfoam-solving/57931-adding-imaginary-patch-calculation-average-values.html)
bboonacker February 17, 2009 08:58
Hello OF'ers, I am simulati
Hello OF'ers,
I am simulating pipe flows and I have a question concerning the calculation of average velocities and pressures.
Is it possible to add something like an additional, imaginary, patch at a specified point in order to calculate the averages ?
I know it is possible within Paraview, but I am looking for something like patchAverage, although I do not want to use the Inlet or Outlet patch.
Thanks in advance,
Bart
antonio_ing February 17, 2009 10:20
hi Bart have a look in anot
hi Bart
have a look in another post regarding "pressure coefficients" in "Running / Solving / CFD". There someone suggested me to use probe points that save for each time you will store the value of velocity or pressure or whatever you want.
hope this helps
antonio
santos February 17, 2009 10:30
Hi Bart, Have a look at the
Hi Bart,
Have a look at the sample utility, that lies in $FOAM_UTILITIES/postProcessing/sampling/sample.
In that path you have a sampleDict dictionary, that I believe is self-explanatory.
Just place that dictionary in the system directory of your case, and make the necessary adjustments to get the values belonging to the plane your are interested in.
Regards,
Jose Santos
bboonacker February 20, 2009 06:13
Hello Jose, Thanks for the
Hello Jose,
Thanks for the tip, it works perfectly.
Now I only have to average the pressure on each surface and then I'm done http://www.cfd-online.com/OpenFOAM_D...part/happy.gif
Bart
Subodh June 1, 2009 23:00
Hi Bart,
Did you able to calculate average from sampled data for planes. Though my patch is not a plane but i have sampled data, and I want to calculate average value from it. Can you help me out ??
Thanks in advance
Subodh
