-   -   Problems with Fedora 9 and OpenMPI (http://www.cfd-online.com/Forums/openfoam-solving/57932-problems-fedora-9-openmpi.html)
harly January 15, 2009 14:43
Hi, I am having some troubl
I am having some trouble to get OpenFOAM to run over two or more PCs.
The problem is that I get the error:
bash: orted: command not found
and I already figured out, what the problem is:
My .bashrc is not sourced in the non-interactive bash shell when I use "mpirun".
The problem is, that I don't know how to fix the problem. I tried every hint I could find for that problem, that did not require root privileges. I don't know if there is an easy fix for that, but I would assume so, because in Ubuntu I just edited the .bashrc and it worked instantly.
If you need any further Information please ask.
Thank you for your help.
-harly
dkingsley January 15, 2009 15:29
you need to check your .bashrc
you need to check your .bashrc and see if you are outputting something to the console. If you are mpirun will stop sourcing the .bashrc on Fedora machines.
We solved this at my last place of employment by checking if the login was interactive in the .bashrc script. If it was not interactive we did not output to the console and that solved the mpirun issue. Unfortunatly I don't remember the syntax.
harly January 15, 2009 18:02
Hi, I tried the following:
if [ -z "$PS1" ]; then
PATH=$PATH:/home2/harlacher/OpenFOAM/
fi
just to check if it would work.
But "ssh client printenv |grep PATH" does not return "/home2/harlacher/OpenFOAM/"
Any ideas what else I could do ?
-harly
vkrishna February 19, 2009 07:15
I am running OF 1.5 in paralle
I am running OF 1.5 in paralled on two machines kidam and soorya. I get the following error :
Can somebody advice the reason for this
[soorya:05105] *** An error occurred in MPI_Waitall
[soorya:05105] *** on communicator MPI_COMM_WORLD
[soorya:05105] *** MPI_ERR_TRUNCATE: message truncated
[soorya:05105] *** MPI_ERRORS_ARE_FATAL (goodbye)
[soorya:05104] *** An error occurred in MPI_Waitall
[soorya:05104] *** on communicator MPI_COMM_WORLD
[soorya:05104] *** MPI_ERR_TRUNCATE: message truncated
[soorya:05104] *** MPI_ERRORS_ARE_FATAL (goodbye)
mpirun noticed that job rank 2 with PID 4565 on node kidambiHP219 exited on signal 15 (Terminated).
gschaider February 19, 2009 08:18
Could you be a bit more specif
Could you be a bit more specific WHEN this error appears (before/after the first timestep, didn't even see the OF-Logo .... )
The two most popular problems with MPI are:
- too small MPI_BUFFER_SIZE
- different OpenMPI-versions on the machines (I suspect that in your case: your "master" machine uses the OF-OpenMPI, the "slave" uses another - system installed - OpenMPI)
Berhard
vkrishna February 19, 2009 13:37
this problem happens after the
this problem happens after the first time step
. Also both machines used the same version of OpenMPI.. the one supplied with OF
gschaider February 19, 2009 16:04
Hi! Which solver? That migh
Hi!
Which solver? That might be an indication. For instance: if it is dieselFoam then a search for MPI_ERR_TRUNCATE might have gotten you two very interesting result. One of them would lead to the question "How do I install these 1.5.x-Bugfixes"
Bernhard
vkrishna February 19, 2009 23:42
the solver is sonicTurbFoam.
I am attaching the log for reference:
Exec : sonicTurbFoam -parallel
Date : Feb 19 2009
Time : 12:31:39
Host : soorya
PID : 5104
Case : /home/openfoam15/OpenFOAM/vijay-1.5/run/vayumach2clus
nProcs : 4
Slaves :
3
soorya.5105
kidambiHP219.4565
kidambiHP219.4566
Pstream initialized with:
floatTransfer : 1
nProcsSimpleSum : 0
commsType : nonBlocking
Create time
Create mesh for time = 0
Reading thermophysical properties
Selecting thermodynamics package hThermo<puremixture<consttransport<speciethermo<hc onstthermo<perfectgas>>>>>
1 additional process aborted (not shown)
---vijay
vkrishna February 19, 2009 23:47
Also the is the error messages
Also the is the error messages I get:
Thu Feb 19 12:31:36 IST 2009
nohup: appending output to `nohup.out'
Command exited with non-zero status 1
0.02user 0.01system 0:06.14elapsed 0%CPU (0avgtext+0avgdata 0maxresident)k
4752inputs+16outputs (27major+2408minor)pagefaults 0swaps
DSpreitz April 20, 2009 16:38
Harly,
thanks for your post. It was the last piece in my puzzle.
Dominic
Originally Posted by harly (Post 207451)
fi
-harly
harly April 23, 2009 17:46
Would you mind sharing what you managed to do with the information ?
Because I was not able to get my setup running (I blame fedora 9) because with ubuntu it worked out of the box.
- harly
DSpreitz May 3, 2009 04:18
Sorry it took me so long to reply. I put
source /home/user/OpenFOAM/OpenFOAM-1.5/etc/bashrc
fi
in my .bashrc. That way all the required OF environment variables are correctly loaded, when MPI logs in over SSH. At least that's my understanding of the concept with the inter- and non-interactive shells. Anybody correct me, if I am wrong here.
Hope this helps.
- harly
