TurbDyMFoam Unknown dynamicFvMesh type mixerFvMesh
Old   June 26, 2008, 09:41
Default Hi I tried to simulate a tu
David Hora
david is on a distinguished road
Hi
I tried to simulate a turbulent mixer2D (icoDyMFoam tutorial case) and got the following error:
--> FOAM FATAL ERROR : Unknown dynamicFvMesh type mixerFvMesh
Valid dynamicFvMesh types are :
7
dynamicBodyFvMesh
staticFvMesh
dynamicBoxFvMesh
subsetMotionSolverFvMesh
dynamicMotionSolverFvMesh
dynamicInkJetFvMesh
mixerGgiFvMesh
I'm using the dev version (14.5.08) from the powerlab webpage and had no problems with icoDyMFoam. Does anybody know why it doesn't work with turbDyMFoam?
Regards
david
david is offline   Reply With Quote
Old   June 27, 2008, 04:13
Default Once again, the solution is si
David Hora
Once again, the solution is simple. It's necessary to add the entry for the lengine lib in Make/options and to recompile turbDyMFoam.
I have another question concerning the boundary conditions. The tutorial case uses zeroGradient for pressure and movingWallVelocity for U, which means that the flux across the patch is zero. Isn't that completely wrong? I tried to use the type "calculated" but got the following error message:
gradientInternalCoeffs cannot be called for a calculatedFvPatchField on patch insideSlider of field U in file ....
You are probably trying to solve for a field with a default boundary condition.
From function calculatedFvPatchField<type>::gradientInternalCoef fs() const in file /home/hjasak/OpenFOAM/OpenFOAM-1.4.1-dev/src/finiteVolume/lnInclude/calculatedFv PatchField.C at line 187.
Is there a better solution?
Regards
david
Old   February 14, 2009, 09:19
Default hi guys i have installed o
antonio segalini
antonio_ing is on a distinguished road
hi guys
i have installed openFoam-1.5-dev version 02/02/09. and i have tried to recompile turbDyMFoam with the lengine but i always got this error:
SOURCE=turbDyMFoam.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/dynamicFvMesh/lnInclude -I/home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/dynamicMesh/lnInclude -I/home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/meshTools/lnInclude -I/home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/turbulenceModels/RAS -I/home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/transportModels -I/home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/turbDyMFoam.o
In file included from /home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/Time.H:47,
from /home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/finiteVolume/lnInclude/fvCFD.H:6 ,
from turbDyMFoam.C:34:
/home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/cpuTime.H:4:3 3: error: asm-generic/cputime.h: No such file or directory
In file included from /home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/finiteVolume/lnInclude/fvCFD.H:6 ,
/home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/Time.H:68: error: expected class-name before ',' token
turbDyMFoam.C: In function 'int main(int, char**)':
turbDyMFoam.C:153: error: 'class Foam::Time' has no member named 'elapsedCpuTime'
/home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/finiteVolume/lnInclude/readPISOC ontrols.H:3: warning: unused variable 'nCorr'
/home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/finiteVolume/lnInclude/readTimeC ontrols.H:40: warning: unused variable 'maxCo'
make: *** [Make/linuxGccDPOpt/turbDyMFoam.o] Error 1
any suggestion?
antonio_ing is offline   Reply With Quote
Old   February 14, 2009, 14:34
Default This specific line does not ma
Martin Beaudoin
mbeaudoin will become famous soon enough
This specific line does not make any sense:
>> /home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/cpuTime.H:4:3 3: error: asm-generic/cputime.h: No such file or directory <<
Under OpenFOAM-1.5-dev, cpuTime.H is no longer part of the library OpenFOAM, but is now located under the library OSspecific...
Did you, by any chance, extracted your 1.5-dev archive over an already existing 1.4.1-dev local copy?
You are also playing with a slightly outdated version of OF-1.5-dev.
If you plan to use openFoam-1.5-dev, I would strongly recommend that you restart from scratch by downloading and keeping in sync with the 1.5-dev version available from the Subversion repository on openfoam-extend.
You might also want to double check your compiler version...
Best of luck.
Martin
mbeaudoin is offline   Reply With Quote
Old   February 14, 2009, 17:07
Default actually it is an installation
antonio segalini
actually it is an installation from scratch. i have downloaded the packages from the powerlab server in croatia. i have been able to solve some cases (with solvers icoFoam and simpleFoam) but not compile. How can i check the compiler?
Old   February 15, 2009, 03:52
Default It may be your dependencies ar
Hrvoje Jasak
hjasak will become famous soon enough
It may be your dependencies are out of date. Try
wclean
wmake
one more time.
Hrv
Hrvoje Jasak
Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk
hjasak is offline   Reply With Quote
Old   February 15, 2009, 04:37
Default still i got the same error
antonio segalini
Making dependency list for source file turbDyMFoam.C
Old   February 15, 2009, 06:44
Default even if i do wclean and wmake
antonio segalini
even if i do wclean and wmake in icoFoam i got the same error so i'm not able to recompile the solvers.
Old   February 15, 2009, 13:31
Default You are missing a header cputi
Hrvoje Jasak
You are missing a header cputime.h that should come with the compiler:
- are you using the system compiler or the one from ThirdParty.
- is the compiler properly installed, eg. can you compile and run HelloWorld.cpp
- can you use the find or locate command to look for the missing header?
Hrv
Hrvoje Jasak
Old   February 15, 2009, 21:31
Default The problem is not with turbDy
Martin Beaudoin
The problem is not with turbDyMFoam, but with the library OpenFOAM.
Again, looking for cpuTime.H under /home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM is a sign that your initial setup is not right.
What happen if you do "wclean; wmake libso" under the directory /home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM before trying to compile turbDyMFoam?
Martin
Old   February 16, 2009, 00:36
Default with the wmake libso i got thi
  #11
antonio segalini
with the wmake libso i got this error at the end of the compiltaion (previously everything was right):
Making dependency list for source file graph/writers/jplotGraph/jplotGraph.C
SOURCE=global/global.Cver ; sed s/WM_PROJECT_VERSION/\"1.5-dev\"/ $SOURCE > Make/linuxGccDPOpt/global.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/cfduser-dev/OpenFOAM/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude -fPIC -pthread -c Make/linuxGccDPOpt/global.C -o Make/linuxGccDPOpt/global.o
SOURCE=global/dimensionedConstants/dimensionedConstants.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/cfduser-dev/OpenFOAM/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/dimensionedConstants.o
In file included from lnInclude/JobInfo.H:45,
from Make/linuxGccDPOpt/global.C:58:
lnInclude/cpuTime.H:4:33: error: asm-generic/cputime.h: No such file or directory
In file included from Make/linuxGccDPOpt/global.C:58:
lnInclude/JobInfo.H:68: error: 'cpuTime' does not name a type
In file included from Make/linuxGccDPOpt/global.C:82:
lnInclude/JobInfo.C: In member function 'void Foam::JobInfo::end(const Foam::word&)':
lnInclude/JobInfo.C:133: error: 'cpuTime_' was not declared in this scope
SOURCE=global/argList/argList.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/cfduser-dev/OpenFOAM/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/home/cfduser-dev/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/argList.o
make: *** [Make/linuxGccDPOpt/global.o] Error 1
make: *** Waiting for unfinished jobs....
from global/argList/argList.C:34:
In file included from global/argList/argList.C:34:
make: *** [Make/linuxGccDPOpt/argList.o] Error 1
cfduser-dev@antonio-laptop:~/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM$
Old   February 16, 2009, 16:30
Default i finally managed to solve the
  #12
antonio segalini
i finally managed to solve the problem compiling again openfoam-dev from scratch. In the installation section there is my post about the openfoam-1.5-dev installation to everybody. Thanks for all the help guys
TurbDyMFoam Application jdkummer OpenFOAM Installation 2 November 24, 2011 08:14
TurbDyMFoam for dummies antonio_ing OpenFOAM Running, Solving & CFD 6 September 24, 2010 08:16
Extending mixerFvMesh for more than ONE Sliding Interface jaswi OpenFOAM Running, Solving & CFD 5 March 3, 2009 11:24
[Gmsh] GmshToFoam and dynamicFvMesh axi case elorriaux OpenFOAM Meshing & Mesh Conversion 0 February 23, 2009 10:58
How to deal with fields of unknown type kar OpenFOAM 7 May 22, 2008 06:17
