Home > Forums > OpenFOAM Running, Solving & CFD
patchIntegrate over a specified patch
Old   February 14, 2009, 11:04
Default Hello, in my case I want to
booz is on a distinguished road
in my case I want to integrate over the patch "outlet".
Any idea how I can do this with openFoam?
Thanks and best regards
Khaled
booz is offline   Reply With Quote
Old   February 16, 2009, 03:52
Default Hi Khaled, try the utility
kbr
Kerstin
kbr is on a distinguished road
Hi Khaled,
try the utility "patchIntegrate":
patchIntegrate <root> <case> <fieldname> <patchname>.
Kerstin
kbr is offline   Reply With Quote
Old   February 16, 2009, 05:01
Default Hi Kerstin, first thanks. I
Hi Kerstin,
first thanks. I tried this, but it doesn´t work.
My case is "caseGeometrie", the fieldname is "p" for pressure and the patchname is "outlet".
So i triesd with
pathchIntegrate . caseGeometrie.p.outlet
But it output an error message.
Regards,
Khaled
Old   February 16, 2009, 05:10
Default Hi Khaled, just try pat
kbr
Kerstin
Hi Khaled,
just try
patchIntegrate 'name of the directory your case is located' caseGeometrie p outlet
If it doesn't work put the error message in your thread, please.
Kerstin
Old   February 16, 2009, 05:18
kbr
Kerstin
Hi Khaled,
just try
Kerstin
Default Hi Kerstin well here is th
Hi Kerstin
well here is the error message:
:~/OpenFOAM/studi8-1.4.1/tutorials$ patchIntegrate object caseGeomtrie p outlet
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4.1 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : patchIntegrate object caseGeomtrie p outlet
Date : Feb 16 2009
Time : 10:19:27
Host : fed-lin44
PID : 12011
Root : object
Case : caseGeomtrie
Nprocs : 1
--> FOAM FATAL ERROR : patchIntegrate: Cannot open case directory "object/caseGeomtrie"
FOAM exiting
Khaled
Old   February 16, 2009, 05:21
Default Hi Khaled, maybe there's on
kbr
Kerstin
Hi Khaled,
maybe there's only a mistake in writing, isn't it? Have a look on your case name: 'caseGeomtrie'
Kerstin
Old   February 16, 2009, 05:39
Default Oh, thanks a lot. That was the
Oh, thanks a lot. That was the mistake!
Now it is running.
Regards,
Khaled
Old   April 17, 2009, 15:06
Default How to do the patch integrate
Vishal Nandigana
nandiganavishal is on a distinguished road
I have a square geometry and would like to calculate the average velocity across the channel at different points along my channel.. Hence I would to integrate the velocity across the channel to calculate the average values.. May I know how exactly we should do this..
Kindly do the needful
Regards
Vishal Nandigana
nandiganavishal is offline   Reply With Quote
Old   May 20, 2016, 13:50
Default 2 Outlets in one patch
Daniel
dpermacaroni is on a distinguished road
Hello everyone,
Situation: I'm simulating a Fluidic oscilaltor (see image in attachment taken from google) with pimpleFoam.
For pre-processing, I used "icem cfd" to make the geometry, export it as a fluent-file and then imported it to openFoam.
The most important property I need to analize is the frequency of the oscillation. For that, I thought I could plot de integration of the velocity field over the time on each "output" using patchIntegrate.
Problem: I defined the two outlets of the oscillator (right side of image) as one patch named "output" in icem. So when I use patchIntegrate, it integrates the velocity over both outlets.
Posibilities: I thought of 3, though I'm not sure if they can be implemented. If you think of more, they are very welcome!
1. Define a region when using patchIntegrate. Does the patch has to be devided in regions beforehand? How to define the "regions"?
2. Use a tool from paraview to plot the massflow through a part of the "outlet"-patch. How is the tool called?
3. Extract the cell velocity-data from the time-directories of the desired region "outlet" and make the integration mannually. (no clue how to do that)
Thanks a lot in advance for your help
dpermacaroni is offline   Reply With Quote
Thread Tools
Trackbacks are On
HELP NEEDED HOW TO MAP VALUES FROM PATCH OF ONE MESH TO PATCH OF ANOTHER MESH mkraposhin OpenFOAM Running, Solving & CFD 3 September 4, 2011 09:42
patch value laure FLUENT 0 June 6, 2007 10:14
VOF Patch Adour FLUENT 0 April 5, 2007 05:01
patch lu FLUENT 2 September 4, 2003 03:48
Patch Eric FLUENT 5 December 1, 2000 11:14
